【求教】自己写了一个3*4矩阵键盘,按键显示相应数值的程序,不能实现功能,求指导。
#include
unsigned char ledchar[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};   //共阳极数码管
unsigned char keybuf[3][4]={{0,0,0,0},{0,0,0,0},{0,0,0,0}};      //按键值缓存数组
sbit IN_1=P2^6;                    //3行
sbit IN_2=P2^5;
sbit IN_3=P2^4;
sbit OUT_1=P2^3;               //4列
sbit OUT_2=P2^2;
sbit OUT_3=P2^1;
sbit OUT_4=P2^0;
void main()
    unsigned char i,j;
    unsigned char backup[3][4]={{0,0,0,0},{0,0,0,0},0,0,0,0}};     //按键值备份
    EA=1;
    TMOD=1;
    TH0=0xFC;                    //1ms扫描一次按键
    TL0=0x67;
    ET0=1;
    TR0=1;
    P0=ledchar[0];
    while(1)
        for(i=0;i<=3;i++)
            for(j=0;j<=4;j++)
                if(backup[i][j]!=keybuf[i][j])                        //有按键按下
                    if(backup[i][j]==1)                               //按键按下并弹起
                        P0=ledchar[i*4+j+1];
                    backup[i][j]=keybuf[i][j];
void InterruptTimer0() interrupt 1
    static unsigned char keyin=0;
    static unsigned char keyout[3][4]={ {0x00, 0x00, 0x00, 0x00},{0x00, 0x00, 0x00, 0x00},{0x00, 0x00, 0x00, 0x00},   };
    static unsigned char i=0;
    TH0=0xFC;
    TL0=0x67;
    keyout[keyin][0]=(keyout[keyin][0]<<1)|OUT_1;                       //消抖
    keyout[keyin][1]=(keyout[keyin][1]<<1)|OUT_2;
    keyout[keyin][2]=(keyout[keyin][2]<<1)|OUT_3;
    keyout[keyin][3]=(keyout[keyin][3]<<1)|OUT_4;
    for(i=0;i<=4;i++)        //判断键值,0为弹起,1为按下
        if((keyout[keyin][i]&0x0f)==0x00)
            keybuf[keyin][i]=0;
        else if((keyout[keyin][i]&0x0f)==0x0f)
            keybuf[keyin][i]=1;
keyin++;
keyin=keyin&0x02;                                              //keyin值为0,1,2
switch(keyin)
    case 0:IN_1=1;IN_2=0;IN_3=0;break;
    case 1:IN_1=0;IN_2=1;IN_3=0;break;
    case 2:IN_1=0;IN_2=0;IN_3=1;break;
     default : break;}
全部回复(2)
矩阵键盘的电路图,JP4接P2口,JP4的1到8对应P2口的0到7.
@戴眼镜的小鸟
[图片]矩阵键盘的电路图,JP4接P2口,JP4的1到8对应P2口的0到7.
实际效果就是这样,大部分按键没反应,一两个按键反应就是数码管全亮。
望大神看看程序哪里有问题,指正一下。感激不尽。
