• 1
【得捷之选】+MAX78000图像任务+开发环境搭建
# 开发环境搭建
## 0.创建目录
mkdir /opt/MAX78000
## 1.准备工作
#### 1.1.下载工程
git clone https://github.com/MaximIntegratedAI/ai8x-training.git
git clone https://github.com/MaximIntegratedAI/ai8x-synthesis.git
#### 1.2 支持平台: linux
sudo apt-get install -y make build-essential libssl-dev zlib1g-dev \
  libbz2-dev libreadline-dev libsqlite3-dev wget curl llvm \
  libncurses5-dev libncursesw5-dev xz-utils tk-dev libffi-dev liblzma-dev \
  libsndfile-dev portaudio19-dev
sudo apt-get install gcc-arm-none-eabi
## 2.创建虚拟环境并且激活
conda create -n MAX78000 python==3.10
## 3.训练模型
cd /opt/MAX78000/ai8x-training/
pip install -r requirements.txt
检测cuda:./check_cuda.py
pip install -r requirements-cu11.txt
训练命令:
1. scripts/train_mnist.sh
2. python train.py --lr 0.1 --optimizer SGD --epochs 20 --deterministic --compress policies/schedule.yaml --model ai85net5 --dataset MNIST --confusion --param-hist --pr-curves --embedding --device MAX78000 "$@"
## 4.移动训练日志
mv logs /opt/MAX78000/ai8x-synthesis
## 5.模型量化
cd /opt/MAX78000/ai8x-synthesis
python quantize.py /opt/MAX78000/ai8x-synthesis/logs/2024.03.07-172658/qat_best.pth.tar /opt/MAX78000/ai8x-synthesis/logs/2024.03.07-172658/proj_q8.pth.tar --device MAX78000
## 6.量化后的模型的评估
python train.py --model ai85net5 --dataset MNIST --confusion --evaluate --exp-load-weights-from /opt/MAX78000/ai8x-synthesis/logs/2024.03.07-172658/proj_q8.pth.tar -8 --device MAX78000 "$@"
## 7.模型转换(AI8Xize)
python ai8xize.py --verbose --test-dir demos --prefix ai85-mnist-02 --checkpoint-file /opt/MAX78000/ai8x-synthesis/logs/2024.03.07-172658/proj_q8.pth.tar --config-file networks/mnist-chw-ai85.yaml --device MAX78000 --compact-data --softmax
全部回复(1)
本帖的MAX78000FTHR, 得捷官网购买连接如下:
https://www.digikey.cn/zh/products/detail/analog-devices-inc-maxim-integrated/MAX78000FTHR/13549063?WT.z_header=search_go&s=N4IgTCBcDaILIEEAaB2AHABiwMQCoAkAlEAXQF8g
关于购买有任何问题,大家可以随时联系我哦(微信:18522870362)
