本文以一个13.8V 20A的汽车铅酸电池充电器变压器计算过程为例,来说明正激变压器的计算过程
1、相關規格参数(SPEC):
INPUT: AC 180V~260V 50Hz
OUTPUT: DC 13.8V (Uomax=14.7V) 20A
Pout: 274W (Pomax=294W)
η≧80%, fs: 60KHZ;
主电路拓扑采用单管正激 自冷散热
2、選擇core材質.決定△B
选择PC40材质Core,考虑到是自冷散热的方式,取ΔB=0.20T
3、確定core AP值.決定core規格型號.
AP=AW×Ae=(Ps×104)/(2×ΔB×fs×J×Ku)
Ps : 變壓器傳遞視在功率 ( W) Ps=Po/η+Po (正激式)
Ps=294/0.8+294=661.5W
J : 電流密度 ( A) .取400 A/cm2
Ku: 銅窗占用系數. 取0.2
AP=(661.5×104)/(2×0.20×60×103×400×0.2)≈3.4453 cm2
選用CORE ER42/15 PC40.其參數為:
AP=4.3262cm4 Ae=194 mm2 Aw=223mm2 Ve=19163mm3
AL=4690±25% Pt=433W (100KHz 25℃)
4、計算Np Ns.
(1). 計算匝比 n = Np /Ns 設 Dmax= 0.4
n = Np / Ns = Vi / Vo = [Vin(min) ×Dmax]/ (Vo+Vf)
Vf :二极管正向壓降 取1V
Vin(min)=180×0.9×√2-20=209 VDC
Vin(max)=260×√2=370VDC
n=(209*0.4)/(13.8+0.7)=5.766 取5.5
CHECK Dmax
Dmax=n(Vo+Vf)/Vin(min)= 5.5
(13.8+1)/209=0.3868≈0.387
Dmin=n(Vo+Vf)/Vin(max)= 5.5
(13.8+1) /370=0.218
(2). 計算Np
Np=Vin(min) ×ton/(ΔB×Ae)
Ton:MOS管导通时间 ton= Dmax/ fs=0.387/60×103=6.33uS
Np = (209×6.33)/( 0.20×194)=34.1 取34TS
(3). 計算Ns
Ns = Np / n = 34÷5.5=6.18 取整为6 TS
(4). CHECK Np (以Ns驗算Np)
Np = Ns×n = 6×5 .5=33TS 取 Np = 33TS
(5).確定NR
NR = Np= 33TS
(6). CHECK ΔB之選擇合理性.
ΔB=[Vin(min) ×Dmax×Ts]/ (Np×Ae)
=(209×6.33)/ (33×194)=0.2067T
(1). 求初級線徑dwp:
Ip = Pi / VL = Po / (η×Dmax×VIN) =294/(0.80×0.38×209) = 4.63 A
Iprms= Ip×√D =4.63 ×√0.38 = 2.854A
Awp = I/J = 2.854/5 = 0.571mm2
dwp=√(4Awp/π)=√(4×0.571/3.14)=0.853mm
Φ0.9mm orΦ0.55mm×4
(2). 求NR繞組線徑dwR.
NR =33TS L = N2×AL
L = 332×4690×0.75 = 3.83mH
Im = Vin(min) ×ton / L = (209×6.33) / (3.83×103) ≈ 0.345A
AWN = 0.345 / 5 = 0.0691mm2
dwN=√(4×0.0691/3.14) =0.235mm 取Φ0.28mm
(3). 求繞組Ns之線徑dws
Isrms=16×√0.35=9.47A (设计输出电流最大为16A)
Aws= I / J=9.47÷5=1.9 mm2
查ER42/15 BOBBIN幅寬27.5mm±0.3mm.考虑扣除挡墙約6mm,則有
27.5 - 6=21.5mm之可繞寬度,預留適當空間(1.5mm) , W=20mm
則:
dws=√(4Aws/π)=√(4×1.9/3.14)= 1.56mm
选用Φ0.40mm×16
6、计算副边输出储能电感的感量
Lo=Vo×(1-Dmin)÷(0.2×Io×Fs)
=13.7×(1-0.218)÷(0.2×20×60×103)
=10.7134÷(240×103)
=45μH
研发工程师的工具箱 |
智慧生活 创新未来 |
