【电源网】AEM (美商AEM科技) 推出Fuse、ESD解决方案:
AME(安茂微电子)推出AME4210电源管理解决方案:
AME4210 90mW, 700mA/1.1A/1.5A/2A High-Side Power Switches with Flag
一、Features:
1、Built-In N-Channel MOSFET with Typically 90mW
2、Output Can Be Forced Higher Than Input (Off-State)
3、Low Supply Current: 50uA Typical at Switch On State 1uA Typical at Switch Off State
4、Input Voltage Ranges: 2V to 5.5V
5、Equal to USB Specifications
6、Open-Drain Fault Flag Output
7、Hot Plug-In Application (Soft-Start)
8、1.7V Typical Under-Voltage Lockout (UVLO)
9、OCP & OTP Protection
10、Reverse Current Flow Blocking (no body diode)
