FCI, a leading supplier of connectors and interconnect systems, announced today the release of the Griplet™ miniature IDC connector for wire-to-board terminations.
FCI’s new Griplet™ connector offers a robust solution for miniature IDC Wire-to-Board connections. The low profile and compact design makes Griplet™ an ideal connector where space is tight and ease of installation is important. Each connector has a height of 3.7mm and a footprint of 4.0mm x 6.1mm.
Specially designed for a stackable pitch up to 12 positions, the common housings are available to secure and protect terminated components. Griplet™ provides a highly reliable connection, and is suitable in harsh and industrial market applications where direct connection between individual wires and PCB are required.
“The Griplet™ accommodates multiple wire sizes which reduces the total applied cost versus solder or crimp process” comments Fabrizio Stango, Commercial Portfolio Director at FCI. “And custom made housings are available for automatic pick and place processes”.
Griplet™ connectors supports various wire-to-board applications such as industrial and instrumentation, automation controls, sensors, LED lighting, white goods and automotive.
FCI推出 GCS™ 低电阻镀层技术 | 15-05-14 16:34 |
FCI扩充RotaConnect® 解决方案 | 15-05-12 16:43 |
FCI扩展Pwr TwinBlade® 系列 | 15-03-11 16:59 |
FCI推出25Gb/秒板载收发器 | 15-02-04 17:01 |
FCI推出低功率SFP+SR收发器 | 15-02-03 16:20 |
2024慕尼黑上海电子展精彩回顾 |
2024.06技术专题 |
