AlphaSGT™系列产品适用于各种AC-DC变换器的同步整流,例如电脑适配器和手机快速充电器。作为新一代60V和100V器件,其导通内阻比上一代降低了30%,提高了电源效率。此外,AlphaSGT™系列集成了软恢复二极管,轻松应对电压应力和传导辐射设计。
The AlphaSGT series is designed to address the secondary-side synchronous rectification in AC/DC converters, such as Adapter and Cell phone quick charger.
The AlphaSGT series improves on-resistance by 30% which reduces conduction losses and allows lower case temperatures during heavy load operation. In addition to the performance benefits, this device has been designed with a soft recovering body diode to reduce the induced voltage stress as well as Radiation of EMI.
更多资料可前往下载https://www.dianyuan.com/download/55570.html
2024慕尼黑上海电子展精彩回顾 |
2024.06技术专题 |
