2nd November 2017 - Complementing its standard Optomax liquid level switch offering, SST Sensing’s Optomax Industrial Glass devices are targeted at installation within harsh industrial environments. Thanks to their stainless steel construction and glass sensor tip, these single point liquid level switches exhibit elevated operational robustness. As a result, these devices are highly suited to applications where they are exposed to extreme temperatures (up to 125°C) and high pressures (up to 600bar).
The switch can detect the presence or absence of almost any liquid type, whether it is oil or water based. As an infra-red (IR) signal is used, the device is not impaired by the effects of ambient light, nor is its accuracy affected by foam when in air or by small bubbles when in liquid. An array of different N and P type output configurations can be specified - allowing the sinking or sourcing of up to 1A of current at supply voltage ranges from 4.5V to 15.4VDC or 8V to 30VDC (thus optimising it for integration within modern industrial automation systems). These also allow the output to be configured so that either a high or low signal corresponds to a wet or dry state respectively. Options for connecting to inductive loads or digital interfaces are also available.
Relying on the same optoelectronic technology as the other devices in the Optomax family, the Optomax Industrial Glass switches each comprise an IR emitter and a phototransistor. When the sensor tip is in air, the IR emitter and phototransistor are optically coupled to one another (with the light emanating from the emitter being internally reflected off the inside of the tip). If, however, the tip becomes immersed in a liquid, some of the IR signal will be dispersed rather than being reflected. The change in this signal will trigger a reaction from the built-in microcontroller connected to the phototransistor. Via this mechanism, the switch offers a highly accurate and responsive way of detecting the presence of liquid.
Since they are free of moving parts, the sensors do not require ongoing maintenance. Their low-profile construction allows them to be integrated into small spaces, as well as tanks with stirrers and agitators. They can be mounted in horizontal or vertical orientations.
About SST Sensing Ltd
For over a decade, SST Sensing Ltd has been developing and manufacturing fluid and gas sensing solutions. These are used to satisfy a broad range of demanding industrial, aviation, medical, transportation and domestic applications. The company’s extensive portfolio of products is made up of optical liquid level sensors, ZrO2 and luminescence based oxygen sensors/analysers, CO2 sensors and CO2 air quality monitors.
Microchip与韩国智能硬件公司IHWK合作开发模拟计算平台,加速边缘AI/ML推理 | 23-09-14 13:58 |
Microchip模拟嵌入式SuperFlash®技术助力存算一体创新企业 成功解决边缘语音处理难题 | 22-03-01 13:09 |
Microchip推出模拟嵌入式SuperFlash®技术,助力AI应用程序系统架构实施 | 19-08-12 12:45 |
SST和SK hynix system ic扩大嵌入式技术的应用范围 | 18-12-13 10:08 |
SST推出螺纹型氧气传感器进一步巩固用户便利性 | 18-02-22 09:55 |
2024慕尼黑上海电子展精彩回顾 |
2024.06技术专题 |
