Comprehensive Pressure Transmitter Portfolio has Scope to Attend to OEM Requirements
2017-11-17 01:12 来源:West Control Solutions 编辑:电源网
Brighton, UK – 16th November 2017: In order to support its long established process controller product line, West Control Solutions has made significant upgrades to its pressure transmitters/transducers offering.
Based on either thin-film or micro-electro-mechanical system (MEMS) sensing technologies, these high performance devices have been introduced through the company’s PMA product range. They are optimized for use in uncompromising industrial environments - with industry leading resilience to shock, vibration and humidity, plus extensive temperature ranges, all being supported. Their elevated reliability characteristics are underlined by the fact that they are supplied with a 3-year warranty.
Targeted specifically at use in hydraulic systems and heavy machinery, the 3100 Series and 3200 Series both maintain heightened degrees of stability and ensure ongoing repeatability of acquired data. Supporting measurement ranges up to 2,200 bar, these devices have an integrated thermal compensation mechanism - which enhances overall accuracy and means that less accompanying electronics is required for signal conditioning (thereby reducing the system’s total bill of materials costs). As a consequence of their rugged construction, they are able to withstand extreme pressure spikes. An extensive array of different electrical and pressure connection options are available, as well as a wide variety of electrical outputs. The vast majority of application requirements can thus be addressed through procurement off-the-shelf products, without the need for any modifications.
Benefiting from an innovative MEMS-based sensing arrangement, the members of the 3500 Series deliver a compelling combination of price and performance. They are capable of determining relatively small changes in pressure even at low pressure values (covering a range up to 40 bar), with an accuracy of 0.2% full scale and minimal thermal drift. Each unit comprises a micro-machined silicon diaphragm with piezo-resistive elements situated at its edges. The cavity that separates the silicon diaphragm on the MEMS sensor component and the external diaphragm is filled with synthetic oil. Supplied in a small form factor with 316L stainless steel wetted parts, these technologically advanced devices are highly suited to refrigeration systems, medical instrumentation, heating ventilation air conditioning (HVAC) systems and gas analysis equipment. They have ultra-fast responsiveness (1 ms) and draw only 4.5 mA of current during operation (thereby keeping the related power consumption to a minimum).
The company’s P30-2 pressure transducers have been developed in order to provide precise gauge pressure measurements in modern industrial applications. Measurement ranges available begin at -200 … 200 mbar and extend all the way up to -1 … 40 bar. Each device has an AISI 316L stainless steel housing that ensures operational robustness. These transducers can be specified with either a 0 … 10 V (3-wire) or a 4 … 20 mA (2-wire) output configuration. They are optimized for installation in hydraulic systems, industrial pumps, compressed air apparatus, filling/weighing machines, level measurement equipment and packaging machines.
Likewise the devices comprised within the P40-2 pressure transducer offering also have AISI 316L stainless steel construction and support measurement ranges that go from -125 … 125 mbar all the way up to -1 … 400 bar. These units come with a 4 … 20mA (2-wire) output signal and a high accuracy of 0.3%. Different process connection with an internal diaphragm is available. Alternatively a flush-mount design, which is highly suited to use with viscous and solids-bearing media, can be chosen.
A variety of compact designs and heavy duty housings are offered, thereby allowing these devices to be implemented in even the most space-constrained of application settings. All confirm to IP67 protection from liquid ingress, with the P40-2 being IP68 rated. Furthermore, they exhibit prolonged working lifespans (with above 100M operation cycles being expected).
2024慕尼黑上海电子展精彩回顾
2024.06技术专题
