求几篇ieee的文章,有资源的兄弟姐妹请伸手帮下忙,谢谢了
1\\Ing-Jen Lee, Dan Y. Chen, Yan-Pei Wu, and Cliff Jamerson, "Modeling of control loop behavior of magamp post regulation," IEEE Trans. on Power Electronics, vol. 5, no. 4, pp. 476 -483, Oct. 1990.
2\\C. H. Yang, D. Y. Chen, C. Jamerson, and Y. P. Wu, "Stabilizing magamp control loop by using an inner-loop compensation," IEEE Trans. on Power Electronics, vol. 6, pp.419-429, July 1991.
3\\A. Fontán, S. Ollero, E. de la Cruz, J. Sebastián, Peak Current Mode Control Applied to the
Forward Converter with Active Clamp, IEEE 1998
4\\ Qiong Li, F. C. Lee, Design Considerations of the Active Clamp Forward Converter with
Current Mode Control during Large-Signal Transient, IEEE 2000;
谢谢了,如果有资源的兄弟姐妹请帮忙下载下,共享出来,或者发邮件到postmenow02@163.com
全部回复(2)
postme
@provento
不用谢.2776941218686412.pdf2776941218686471.pdf2776941218686554.pdf2776941218686678.pdf
OMG,以为账号被盗,被人发文章呢;这些文章都找到了;还是要衷心的感谢一下
