Static Test | PS/OFF | Low | Full Load |
Inrush Current Test | 浪涌電流測試 | High | Full Load |
Turn on&Sequence Test | 開機時間<2500ms | Normal | Full Load |
Static Test | PS/ON | Low | Full Load |
Turn on&Sequence Test (Rise Time) | Rise Time<20ms | Normal | Full Load |
Input/Output Test | PF&輸入電流測試 | Low | Full Load |
Turn on&Sequence Test (PG) | PG(輸出電壓上升到規格下限到PG開始有的時間)100-500ms | Normal | Full Load |
Hold Up&Sequence Test (Power Fall) | PG下降后輸出電壓保持時間>1ms | Low | Full Load |
Input/Output Test | PF&輸入電流測試 | Low | Min Load |
Hold Up&Sequence Test | Hold Up(電源掉電后輸出電壓保持時間>16ms) | Low | Full Load |
TTL/Relay Preup | |||
Noise Test | 滿載紋波測試 | Low | Full Load |
Noise Test | 最小載紋波測試 | Low | Min Load |
Noise Test | 3.3V 最大載紋波測試 | Low | 3.3V Max |
Noise Test | 5V最大載紋波測試 | Low | 5V Max |
Noise Test | 12V最大載紋波測試 | Low | 12V Max |
Voltage Regulation Test | 改變輸入電壓及3.3V&5V負載測試 | Low,Low | 3.3V Max,5VMax |
Voltage Regulation Test | 改變輸入電壓及12V&5V負載測試 | Low,Low | 12V Max,5V Max |
Voltage Regulation Test | 改變輸入電壓及3.3V&12V負載測試 | Low,Low | 3.3V Max,12VMax |
Voltage Regulation Test | 改變輸入電壓及負載測試 | Low,Low | 3.3V&5VMax,Full Load |
Total Regulation Test | 每組輸入電壓,負載同時改變測試 | Low,Low | Full Load,20%Full Load |
Dynamic Test | 低壓滿載動態測試 | Low | Full Load; Dyn Load1 |
Dynamic Test | 低壓滿載動態測試 | Low | Min Load; Dyn Load2 |
Power Efficiency Test | 低壓full load效率測試 | Low | Full Load |
Power Efficiency Test | 低壓full load效率測試 | Low | 50% Full Load |
Power Efficiency Test | 低壓full load效率測試 | Low | 20% Full Load |
Overshoot Voltage Test | 開機瞬間最大電壓測試 | Low | Min Load |
OCP Tesst | 12V OCP | Low | 12V Max |
OCP Tesst | 3.3V OCP | Low | 3.3V Max |
OCP Tesst | 5V OCP | Low | 5V Max |
OVP/UVP Test | 12V OVP | Low | Full Load |
OPP test | Low | Full Load | |
Noise Test | 滿載紋波測試 | High | Full Load |
Noise Test | 滿載紋波測試 | High | Min Load |
Noise Test | 滿載紋波測試 | High | 3.3V Max |
Noise Test | 滿載紋波測試 | High | 5V Max |
Noise Test | 滿載紋波測試 | High | 12V Max |
OCP Tesst | 12V OCP | High | 12V Max |
OVP/UVP Test | 12V OVP | High | Full Load |
OCP Tesst | 3.3V OCP | High | 3.3V Max |
Short Circuit Test | 3.3V SCP | High | Full Load |
OCP Tesst | 5V OCP | High | 3.3V Max |
Short Circuit Test | 5V SCP | High | Full Load |
OPP test | OPP | High | Full Load |
OVP/UVP Test | 5V OVP | High | Full Load |
Short Circuit Test | 12V SCP | High | Full Load |
Overshoot Voltage Test | 開機瞬間最大電壓測試 | High | Min Load |
Power Efficiency Test | 低壓full load效率測試 | High | Full Load |
Power Efficiency Test | 低壓full load效率測試 | High | 50% Full Load |
Power Efficiency Test | 低壓full load效率測試 | High | 20% Full Load |
Dynamic Test | 低壓滿載動態測試 | High | Full Load; Dyn Load1 |
Static Test | PS/ON | High | Full Load |
