- 手头有只台达服务器电源不知道怎么启动 型号:DPS-500EBA
- 通电有5v输出,不知道怎么才能启动?
- 主要IC 有IR2110S,CD4011和ML4824CS2
- 主要想利用12V改制13.8V做通信电源使用!
- 请看图
求解 手头有只台达服务器电源不知道怎么启动 型号:DPS-500EBA???
全部回复(1)
我也类似的,不过我是700W,测了下各脚电压,谁给分析下,可能的启动是短接哪几个脚。
1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | |
1 | ~~ | -0.67 | -0.67 | -0.67 | -5 | 0 | -2.8 | -5 | -0.67 | -16 | -5 | 0 | 0 | 0 | 0 |
2 | ~~ | ~~ | 0.07 | 0.07 | -4.3 | -4.3 | -2.15 | -4.3 | 0.07 | -15.7 | -4.4 | 0 | 0 | 0.67 | 0.67 |
3 | ~~ | ~~ | ~~ | 0 | -4.3 | -4.3 | -2.2 | -4.3 | 0 | 0 | -4.5 | 0 | 0 | 0.6 | 0.6 |
4 | ~~ | ~~ | ~~ | ~~ | -4.3 | -4.3 | -2.5 | -4.3 | 0 | -12.5 | -4.5 | 0 | 0 | 0.6 | 0.6 |
5 | ~~ | ~~ | ~~ | ~~ | ~~ | 0 | 2.16 | 0 | 4.4 | -12.3 | 0.1 | 0 | 0 | 5 | 5 |
6 | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | 2.15 | 0 | 2.23 | -14 | -2.26 | 0 | 0 | 2.8 | 2.8 |
7 | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | 0 | 2.23 | -14.1 | 0.1 | 0 | 0 | 5 | 5 |
8 | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | 4.4 | -12.6 | -0.1 | 0 | 0 | 5 | 5 |
9 | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | -15.8 | -4.5 | 0 | 0 | 0.6 | 0.6 |
10 | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | 10.66 | 0.4 | 0.4 | 15.73 | 15.6 |
11 | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | 0.3 | 0.3 | 5 | 5 |
12 | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | 0 | 0 | 0 |
13 | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | 0 | 0 |
14 | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | 0 |
15 | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ | ~~ |
