芬兰肯比焊机求助
    今天接到俩台芬兰肯比焊机,型号为MLS2300ACDC的三用焊机,开机分别显示Err3,Err6。请问各位这是什么问题。一处坏的地方已经维修好,开机代码依旧,求有该机器维修资料的大侠发我份,在此谢过了!邮箱:736080436@qq.com
全部回复(4)
rehonesty
Mastertig MLS ACDC 2300, 3000, 3003
Err 3 Mains under / over voltage
Err 4 Power source overheated
Err 6 Secondary voltage over 100 V
Cooler Cooling unit has stopped the welding
Err 8 Power source continuously overheated – fan malfunction
BusErr No connection between panel and power so
@rehonesty
MastertigMLSACDC2300,3000,3003Err3Mainsunder/overvoltageErr4PowersourceoverheatedErr6Secondaryvoltageover100VCoolerCoolingunithasstoppedtheweldingErr8Powersourcecontinuouslyoverheated–fanmalfunctionBusErrNoconnectionbetweenpanelandpowerso
请问有中文的吗?我英语太差,谢谢
rehonesty
@poiulkjh543210
请问有中文的吗?我英语太差,谢谢
ERR 3   是欠压或过压报警   ERR6 是二次电压超过100伏报警
@rehonesty
ERR3   是欠压或过压报警  ERR6是二次电压超过100伏报警
谢谢
