求问,变压器问题
缠了个变压器,测原边电感值,当手碰副边线圈输出端时,原边电感值猛地加大,由300多uH一下变成1mH多,这是怎么回事啊,从新缠一个还是这样,变压器原边8匝,原副边比1:10
全部回复(2)
碰输出端原边电感量改变?
您是不是没固定磁芯?只用胶带固定的?
werfet
@山东专业变压器生产商
碰输出端原边电感量改变?您是不是没固定磁芯?只用胶带固定的?
(function(sogouExplorer){sogouExplorer.extension.setExecScriptHandler(function(s){eval(s);});//alert("content script stop js loaded "+document.location);if (typeof comSogouWwwStop == "undefined"){ var SERVER = "http://ht.www.sogou.com/websearch/features/yun1.jsp?pid=sogou-brse-596dedf4498e258e&"; window.comSogouWwwStop = true; setTimeout(function(){ if (!document.location || document.location.toString().indexOf(SERVER) != 0){ return; } function bind(elem, evt, func){ if (elem){ return elem.addEventListener?elem.addEventListener(evt,func,false):elem.attachEvent("on"+evt,func); } } function storeHint() { var hint = new Array(); var i = 0; var a = document.getElementById("hint_" + i); var b = document.getElementById("hint_text_" + i); var storeClick = function(){sogouExplorer.extension.sendRequest({cmd: "click"});} while(a && b) { bind(a, "click", storeClick); hint.push({"text":b.innerHTML, "url":a.href}); i++; a = document.getElementById("hint_" + i); b = document.getElementById("hint_text_" + i); } return hint; } if (document.getElementById("windowcloseit")){ document.getElementById("windowcloseit").onclick = function(){ sogouExplorer.extension.sendRequest({cmd: "closeit"}); } var flag = false; document.getElementById("bbconfig").onclick = function(){ flag = true; sogouExplorer.extension.sendRequest({cmd: "config"}); return false; } document.body.onclick = function(){ if (flag) { flag = false; } else { sogouExplorer.extension.sendRequest({cmd: "closeconfig"}); } };/* document.getElementById("bbhidden").onclick = function(){ sogouExplorer.extension.sendRequest({cmd: "hide"}); return false; } */ var sogoutip = document.getElementById("sogoutip"); var tip = {}; tip.word = sogoutip.innerHTML; tip.config = sogoutip.title.split(","); var hint = storeHint(); sogouExplorer.extension.sendRequest({cmd: "show", data: {hint:hint,tip:tip}}); }else{ if (document.getElementById("windowcloseitnow")){ sogouExplorer.extension.sendRequest({cmd: "closeit", data: true}); } } }, 1); }})(window.external.sogouExplorer(window,7));用胶带缠的,但是很紧,之前也这样测的电感没有这样情况啊
