MOS管的驱动问题请教各位高手有图
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/44/1156348232.gif');}" onmousewheel="return imgzoom(this);">
全部回复(42)
alex2720
A点的波形500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/44/1156308907.gif');}" onmousewheel="return imgzoom(this);">
alex2720
@alex2720
A点的波形[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/44/1156308907.gif');}"onmousewheel="returnimgzoom(this);">
B点不接MOS管时的波形500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/44/1156309311.gif');}" onmousewheel="return imgzoom(this);">
alex2720
@alex2720
B点不接MOS管时的波形[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/44/1156309311.gif');}"onmousewheel="returnimgzoom(this);">
B点接上MOS管后的波形500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/44/1156309466.jpg');}" onmousewheel="return imgzoom(this);">
protose
@alex2720
赶上直播了?
问题在哪里?
alex2720
@alex2720
B点接上MOS管后的波形[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/44/1156309466.jpg');}"onmousewheel="returnimgzoom(this);">
输出的结果500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/44/1156309704.gif');}" onmousewheel="return imgzoom(this);">
protose
@alex2720
好像是你的自举电容太小了点哦.在B点解一个2nF左右的电容试试,看是否驱动正常,如果不正常的话可能就是自举电容比较小.正常的话就换一个MOSFET.
alex2720
@protose
赶上直播了?问题在哪里?
为何接了MOS管后变形那么大
alex2720
@protose
电容为2.2uF的,低位输出都一样????
alex2720
@protose
赶上直播了?问题在哪里?
快复我啦!!高手!!!
alex2720
@protose
我试下先,多谢高手指点!
protose
@alex2720
我试下先,多谢高手指点!
要先把mosfet断开哦.
alex2720
@protose
要先把mosfet断开哦.
试了在B接了个2nF电容,驱动不正常,加大了自举电容2.2uF两个,都不正常,换了个47uF都是一样,后来换了个9N90的IGBT都是不正常.
protose
@alex2720
第8楼的图看,好像下面的驱动信号也不对哦,这个有点不怎么明白.mosfet driver的VDD端的电路是什么样的?有没有接电阻?
alex2720
@protose
第8楼的图看,好像下面的驱动信号也不对哦,这个有点不怎么明白.mosfetdriver的VDD端的电路是什么样的?有没有接电阻?
对呀!就是上下都不正常呀!这个图是MOSFET管输出的.我现在估计是IR2101的驱动力不足.一楼的图我以更新过你可以看一下.
protose
@alex2720
看来应该是2101的驱动能力不够所造成的.驱动电流太小了,才130mA.
alex2720
@protose
我查过IRFP460的输入电容有4200pF的
wjoyn
@alex2720
130MA电流是太小了
可以加一级电流放大看看是否是驱动电流不足造成
alex2720
@wjoyn
130MA电流是太小了可以加一级电流放大看看是否是驱动电流不足造成
我换了对5N60,输入电容只有500pF,果然正常.结果是驱动电流不够所致.如果要驱动IRFP460的话,可能要用到IR2181才可以了,它的驱动电流有1.5A.如果要用变压器来做驱动的话,应该怎样计算?
@alex2720
快复我啦!!高手!!!
不就是因为mosfet输入电容影响的吗
alex2720
@求知星际
不就是因为mosfet输入电容影响的吗
你不如过两个月才说!!晕
alex2720
另一个问题:这个电路是做一个输入AC220/50W/60KHz输出为AC15KV的高压电源的,请问各位高手,在高压变压T1处应用什么方做吸收?
wjoyn
@alex2720
可以用2181,变压器1:1就可以了
也可以加光耦驱动
wjoyn
@alex2720
还没看明白
alex2720
@wjoyn
还没看明白
输入为:AC220V/50Hz,输出为:50W/60KHz/AC15KV
123liuxiao
@alex2720
高手多多赐教啊
怎么能做好电源专业翻译工作
alex2720
@123liuxiao
高手多多赐教啊怎么能做好电源专业翻译工作
学多点专有名词
alex2720
@wjoyn
可以用2181,变压器1:1就可以了也可以加光耦驱动
后来我我换了IR2181终于解决了,但是输出就有呢问题了!我是接了电视用的高压包来试的,请赐教!
alex2720
@alex2720
这个是0死区时MOS的输出电压500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/44/1156919877.jpg');}" onmousewheel="return imgzoom(this);">
alex2720
2006-08-30 14:40
@alex2720
这个是0死区时MOS的输出电压[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/44/1156919877.jpg');}"onmousewheel="returnimgzoom(this);">
这个是死区百分之三十时MOS输出的电压500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/44/1156920023.jpg');}" onmousewheel="return imgzoom(this);">
alex2720
2006-08-30 14:43
@alex2720
这个是死区百分之三十时MOS输出的电压[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/44/1156920023.jpg');}"onmousewheel="returnimgzoom(this);">
这应该怎样处理,急急急!!!!!
