For the point 5 in fail comment, it is base on constructional requirement instead of testing. Per UL 962 and CSA C22.2 No. 12, the components shall be used in accordance with its rating established for the intended conditions of use. The rating of the conductors shall be suitable for the temperature and voltages encountered. As the voltage encountered by the trigger wire is 3000V, it shall be rated min. 3000 V instead of 600V.
这是我们产品FAIL的一项,请大家能给予说明!!多谢!!
有一项不明白,请大家过来看看!!
全部回复(6)
精华推荐 换一换
