各位前輩,大家好!
小弟最近遇到公司需申請塑膠粒UL認證的問題!
1.不知有前輩知道塑膠QMFZ2的認證須參考哪些安規標準?
2.聽說塑膠有分RTI等級,若是我司要申請105℃等級的認證,需要經過什麼測試、以及UL會測試哪些項目?
如94V0、CTI、HAI、HWI...等
麻煩各位前輩幫忙指導一下,如有資料也不吝分享~謝謝!
請教關於塑膠粒UL認證測試的內容!
全部回复(21)
1.QMFZ2的產品需按UL94(Maybe UL1694/723)做測試,但可能會參照到UL746A/B/C/D/E或ASTM的標準.
Materials may be classified based on burning tests conducted in accordance with ANSI/UL 94, "Test for Flammability of Plastic Materials for Parts in Devices and Appliances," ANSI/UL 1694, "Tests for Flammability of Small Polymeric Component Materials," and ANSI/UL 723, "Test for Surface Burning Characteristics of Building Materials."
2.RTI:
RTI Elec — Electrical RTI, associated with critical insulating properties.
RTI Mech Imp — Mechanical Impact RTI, associated with critical impact resistance, toughness, elongation and flexibility properties.
RTI Mech Str — Mechanical Strength (Mechanical without Impact) RTI, associated with critical mechanical strength and structural integrity where impact resistance, resilience and flexibility may not be essential.
3.關於94V0--就是滿足UL94的V0等級耐燃等級
4.CTI:
Comparative Tracking Index (CTI; ASTM D3638 ) — Expressed as that voltage which causes tracking after 50 drops of 0.1 percent ammonium chloride solution have fallen on the material. The results of testing the nominal 3 mm thickness are considered representative of the material's performance in any thickness.
The above characteristics and dielectric strength, volume resistivity and other electrical and mechanical properties may be determined by means of the applicable ASTM and/or UL specification in ANSI/UL 746A, "Polymeric Materials - Short Term Property Evaluations."
5.HAI:
High- Current Arc Ignition (HAI; ANSI/UL 746A ) — Performance is expressed as the number of arc rupture exposures (standardized as to electrode type and shape and electric circuit) that are necessary to ignite a material when they are applied at a standard rate on the surface of the material.
6.HWI:Hot-Wire Ignition (HWI; ASTM D3874, IEC 60695-2-20 ) — Performance is expressed as the mean number of seconds needed to either ignite standard specimens or to burn through the specimens without ignition.
2.RTI:
4.CTI:
5.HAI:
@fasten
1.QMFZ2的產品需按UL94(MaybeUL1694/723)做測試,但可能會參照到UL746A/B/C/D/E或ASTM的標準.MaterialsmaybeclassifiedbasedonburningtestsconductedinaccordancewithANSI/UL94,"TestforFlammabilityofPlasticMaterialsforPartsinDevicesandAppliances,"ANSI/UL1694,"TestsforFlammabilityofSmallPolymericComponentMaterials,"andANSI/UL723,"TestforSurfaceBurningCharacteristicsofBuildingMaterials."2.RTI:RTIElec—ElectricalRTI,associatedwithcriticalinsulatingproperties.RTIMechImp—MechanicalImpactRTI,associatedwithcriticalimpactresistance,toughness,elongationandflexibilityproperties.RTIMechStr—MechanicalStrength(MechanicalwithoutImpact)RTI,associatedwithcriticalmechanicalstrengthandstructuralintegritywhereimpactresistance,resilienceandflexibilitymaynotbeessential.3.關於94V0--就是滿足UL94的V0等級耐燃等級4.CTI:ComparativeTrackingIndex(CTI;ASTMD3638)—Expressedasthatvoltagewhichcausestrackingafter50dropsof0.1percentammoniumchloridesolutionhavefallenonthematerial.Theresultsoftestingthenominal3mmthicknessareconsideredrepresentativeofthematerial'sperformanceinanythickness.Theabovecharacteristicsanddielectricstrength,volumeresistivityandotherelectricalandmechanicalpropertiesmaybedeterminedbymeansoftheapplicableASTMand/orULspecificationinANSI/UL746A,"PolymericMaterials-ShortTermPropertyEvaluations."5.HAI:High-CurrentArcIgnition(HAI;ANSI/UL746A)—Performanceisexpressedasthenumberofarcruptureexposures(standardizedastoelectrodetypeandshapeandelectriccircuit)thatarenecessarytoigniteamaterialwhentheyareappliedatastandardrateonthesurfaceofthematerial.6.HWI:Hot-WireIgnition(HWI;ASTMD3874,IEC60695-2-20)—Performanceisexpressedasthemeannumberofsecondsneededtoeitherignitestandardspecimensortoburnthroughthespecimenswithoutignition.
仔細一看,樓主還是台灣同胞(簽名如下),難得:
來自對岸的同袍~
來自對岸的同袍~
@fasten
謝謝FASTEN大哥的說明~這樣有比較清楚了!謝謝
@fasten
是在台灣還是大陸工作?請看清第1點,測試程序要看你可能選用的標準了.每個標準有不同的測試程序.可能要根據你的產品用途來確定可能會選用的標準,另你還得定位你的產品是不是就是要申請V-0等級的耐燃等級.
歡迎台灣同胞過我們的安規認證論壇來交流技術!絕無廣告!
http://fasten.uu1001.com
@xiangarmy
谁说的UL62?UL62是软线的,风马牛不相及.
我可以提供符合UL94或UL1694的测试设备,foresight169@163.com
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/50/1170336125.jpg');}" onmousewheel="return imgzoom(this);">
塑料认证导则,来自UL网站:
Plastics - Component
The materials covered under this category are incomplete in certain constructional features or restricted in performance capabilities and are intended for use as components of complete equipment submitted for investigation rather than for direct separate installation in the field. THE FINAL ACCEPTANCE OF THE COMPONENT IS DEPENDENT UPON ITS INSTALLATION AND USE IN EQUIPMENT SUBMITTED TO UNDERWRITERS LABORATORIES INC.
GENERAL
This category covers materials that have been tested in accordance with established methods to define their properties in order to facilitate investigation of their use in end-use product applications. The tests may include the determination of material flammability (burning characteristics), ignition characteristics from various thermal and electrical sources, electrical tracking and other electrical characteristics, physical and mechanical characteristics, and analytical tests. In addition, the effect of long-term exposure to elevated temperature (air-oven aging), water, ultraviolet light, cold, etc., on property retention may be investigated. Levels of performance characteristics required for a particular end-use product application are intended to be in accordance with the requirements of the end-use product standard. Due to space limitations, only a limited number of property values may be presented in the individual Recognitions. Additional properties may be found in the UL iQ™ for Plastics database at www.ul.com, or in the individual Reports.
In those cases where the materials have the same performance characteristics, with the exception of weathering resistance, they are tabulated together as a group with each material designation separated by a comma. The individual Recognitions may include alternate designations as well as materials that are basically similar in composition but differ by some minor variation, such as molecular weight, lubricants, colorants, etc.
The colors shown thereon are as pigmented by the material manufacturer; unless otherwise indicated, the property values are for the unpigmented (Natural color) material. Refer to Flame-retardant and/or Color Concentrates (QMQS2) and ANSI/UL 746D, "Polymeric Materials - Fabricated Parts," for limitations on the use of concentrates by the part molder or processor. The following abbreviations may be used in the individual Recognitions to represent the material color:
Colors
Abbreviation Color
AL Aluminum
ALL
-AO
-AT Any color
- Any color (opaque only)
- Any color (transparent only)
AM Amber
BG Beige
BK Black
BL Blue
BN Brown
BZ Bronze
CL Clear
GD Gold
GN Green
GY Gray
IV Ivory
NC Natural (No pigmentation)
OL Olive
OR Orange
PK Pink
RD Red
SM Smoke
TN Tan
VT Violet
WT White
YL Yellow
Flammability
ANSI/UL 94 small-scale test data does not pertain to building materials, furnishings and related contents. ANSI/UL 94 small-scale test data is intended solely for determining the flammability of plastic materials used in the components and parts of end-use product devices and appliances, where the acceptability of the combination is determined by UL.
TEST NAME (per ANSI/UL 94)
Horizontal Burning Test
20 mm Vertical Burning Test Thin Material Vertical Burning Test Horizontal Burning Foamed Material Test
500 Watt (125 mm) Vertical Test
Flame Rating Hierarchy — V-0 VTM-0 — More Severe 5VA
— V-1 VTM-1 HF-1 ↑
— V-2 VTM-2 HF-2 5VB
HB — — HBF Less Severe
Thermal Endurance
The temperature below which a class of critical property will not be unacceptably compromised through chemical thermal degradation, over the reasonable life of an electrical product (relative to a reference material having a confirmed, acceptable corresponding performance) is defined as the Relative Thermal Index (RTI). More than one RTI may be appropriate for a given material depending on the property requirements for a given application. In certain cases, higher temperatures are permitted if so specified by the end-use product standard.
Resistance to Ignition and Tracking Properties
Performance may be investigated with respect to electrical track resistance, ability to resist ignition from electrical sources, and other electrical properties. In order to avoid an excessive level of implied precision and bias, material performances for several tests are recorded as Performance Level Categories (PLC), based on the mean test results (rather than recording the exact numerical results), as indicated in the table following the test description.
HWI Range
Mean Ignition Time (in sec) Assigned
PLC
120 and longer 0
60 through 119 1
30 through 59 2
15 through 29 3
7 through 14 4
Less than 7 5
HAI Range
Mean Number of Arcs
to Cause Ignition Assigned
PLC
120 and greater 0
60 through 119 1
30 through 59 2
15 through 29 3
Less than 15 4
High-Voltage Arc Tracking Rate (HVTR; ANSI/UL 746A ) — Denoted as the rate, in mm/min, that a tracking path can be produced on the surface of the material under standardized test conditions. A notation is made if ignition on the material takes place. The results of testing the nominal 3 mm thickness are considered representative of the material's performance in any thickness.
HVTR Range
(in mm/min) Assigned
PLC
0 through 10 0
10.1 through 25.4 1
25.5 through 80 2
80.1 through 150 3
Greater than 150 4
High-Voltage, Low-Current Arc Resistance (D495; ASTM D495 ) — Expressed as the number of seconds that a material resists the formation of a surface conducting path when subjected to an intermittently occurring arc of high voltage, low current characteristics. The results of testing the nominal 3 mm thickness are considered representative of the material's performance in any thickness.
D495 Range
Mean Time of Arc Resistance
(in sec) Assigned
PLC
420 and longer 0
360 through 419 1
300 through 359 2
240 through 299 3
180 through 239 4
120 through 179 5
60 through 119 6
Less than 60 7
CTI Range
Tracking Index
(in volts)
Assigned
PLC
600 and greater 0
400 through 599 1
250 through 399 2
175 through 249 3
100 through 174 4
Less than 100 5
In addition to minimum electrical and ignition test levels, materials that are used in applications involving support or contact with current-carrying parts are also required to display a minimum stability (heat distortion, moisture resistance, dimensional stability and mold stress) performance level, as described in ANSI/UL 746C, "Polymeric Materials - Use in Electrical Equipment Evaluations."
CONDITIONS OF ACCEPTABILITY
Unless specified otherwise in the individual Recognitions, consideration is to be given to the following Conditions of Acceptability when these components are employed in the end-use equipment:
1. Material traceability for parts covered under Fabricated Parts (QMMY2).
2. Material identification for a device employing parts molded of these materials should specify the parts' wall thickness, color, material identification, and traceability.
3. Materials must meet applicable requirements concerning the molding and fabricating of finished parts as described in ANSI/UL 746D, "Polymeric Materials - Fabricated Parts." This includes, but is not limited to, the restricted use of regrind thermoplastic material to amounts less than 25% unless specified in the individual Recognitions.
4. Unless otherwise indicated, suitability for use when exposed to weathering, oils, soaps, chemicals, x-rays, and the like has not been determined.
5. Investigation of parts for other properties in accordance with the applicable UL end-use product standard and/or requirements outlined in ANSI/UL 746C.
Additional Conditions of Acceptability may be found in the individual Recognition Report available from the manufacturer.
GENERIC MATERIAL SYMBOLS
The generic material symbols are based upon the terminology developed in the International Organization for Standardization publications ISO 1043, "Plastics - Symbols and Abbreviated Terms," and ISO 1629, "Rubber and Latices - Nomenclature."
FOAMED MATERIALS
Materials that have been foamed with the introduction of a chemical blowing agent or inert gas may have significantly different properties than the unfoamed or solid material form; therefore, ratings that are established for solid (unfoamed) material do not automatically apply to the foamed version of that same material.
MATERIALS FOR USE IN SPECIAL ENVIRONMENTS
Investigation of materials for specific end-use product applications where requirements exist for the retention of properties after exposure to certain critical operating and/or environmental conditions may be indicated in the individual Recognitions.
COLUMN HEADING ABBREVIATIONS
The following abbreviations may be used in the column headings in the individual Recognitions:
Abbreviation Term
Flame Class ANSI/UL 94 Flammability Classification
Material Dsg Material Designation
Col Color
Min Thk Minimum Thickness
Thk Rg Thickness Range
Den Range g/cc Density Range, g/cc
Elec Electrical
RP Radiant Panel
RTI Relative Temperature Index
HWI Hot-Wire Ignition
HAI High Current Arc Ignition
HVTR High Voltage Arc Tracking Rate
D495 Arc Resistance
CTI Comparative Tracking Index
Mech Mechanical
Tnsl Tensile
Elong Elongation
Str Strength
Imp Impact
RELATED PRODUCTS
Refer to the following for components manufactured under other product categories:
Polymeric Materials - Filament-wound Tubing, Industrial Laminates, Vulcanized Fiber, and Materials for Use in Fabricating Recognized Printed Wiring Boards (QMTS2)
Coatings for Use on Recognized Printed Wiring Boards (QMJU2)
Metallized Parts (QMRX2)
Supplier Components for Use in the Fabrication of Metallized Parts (QMSS2)
Systems, Electrical Insulation (OBJY2)
Polymeric Adhesive Systems, Electrical Equipment (QOQW2)
Mold-release Lubricants (QMSX2)
GENERAL
Colors
Abbreviation Color
AL Aluminum
ALL
-AO
-AT Any color
AM Amber
BG Beige
BK Black
BL Blue
BN Brown
BZ Bronze
CL Clear
GD Gold
GN Green
GY Gray
IV Ivory
OL Olive
OR Orange
PK Pink
RD Red
SM Smoke
TN Tan
VT Violet
WT White
YL Yellow
Flammability
— V-1 VTM-1 HF-1 ↑
Thermal Endurance
HWI Range
PLC
120 and longer 0
60 through 119 1
30 through 59 2
15 through 29 3
7 through 14 4
Less than 7 5
HAI Range
Mean Number of Arcs
PLC
120 and greater 0
60 through 119 1
30 through 59 2
15 through 29 3
Less than 15 4
HVTR Range
PLC
0 through 10 0
10.1 through 25.4 1
25.5 through 80 2
80.1 through 150 3
Greater than 150 4
D495 Range
(in sec) Assigned
PLC
420 and longer 0
360 through 419 1
300 through 359 2
240 through 299 3
180 through 239 4
120 through 179 5
60 through 119 6
Less than 60 7
CTI Range
Tracking Index
(in volts)
Assigned
PLC
600 and greater 0
400 through 599 1
250 through 399 2
175 through 249 3
100 through 174 4
Less than 100 5
FOAMED MATERIALS
Abbreviation Term
Col Color
Elec Electrical
RP Radiant Panel
D495 Arc Resistance
Mech Mechanical
Tnsl Tensile
Elong Elongation
Str Strength
Imp Impact
RELATED PRODUCTS
@hohoben
塑料认证导则,来自UL网站:Plastics-ComponentThematerialscoveredunderthiscategoryareincompleteincertainconstructionalfeaturesorrestrictedinperformancecapabilitiesandareintendedforuseascomponentsofcompleteequipmentsubmittedforinvestigationratherthanfordirectseparateinstallationinthefield.THEFINALACCEPTANCEOFTHECOMPONENTISDEPENDENTUPONITSINSTALLATIONANDUSEINEQUIPMENTSUBMITTEDTOUNDERWRITERSLABORATORIESINC.GENERALThiscategorycoversmaterialsthathavebeentestedinaccordancewithestablishedmethodstodefinetheirpropertiesinordertofacilitateinvestigationoftheiruseinend-useproductapplications.Thetestsmayincludethedeterminationofmaterialflammability(burningcharacteristics),ignitioncharacteristicsfromvariousthermalandelectricalsources,electricaltrackingandotherelectricalcharacteristics,physicalandmechanicalcharacteristics,andanalyticaltests.Inaddition,theeffectoflong-termexposuretoelevatedtemperature(air-ovenaging),water,ultravioletlight,cold,etc.,onpropertyretentionmaybeinvestigated.Levelsofperformancecharacteristicsrequiredforaparticularend-useproductapplicationareintendedtobeinaccordancewiththerequirementsoftheend-useproductstandard.Duetospacelimitations,onlyalimitednumberofpropertyvaluesmaybepresentedintheindividualRecognitions.AdditionalpropertiesmaybefoundintheULiQ™forPlasticsdatabaseatwww.ul.com,orintheindividualReports.Inthosecaseswherethematerialshavethesameperformancecharacteristics,withtheexceptionofweatheringresistance,theyaretabulatedtogetherasagroupwitheachmaterialdesignationseparatedbyacomma.TheindividualRecognitionsmayincludealternatedesignationsaswellasmaterialsthatarebasicallysimilarincompositionbutdifferbysomeminorvariation,suchasmolecularweight,lubricants,colorants,etc.Thecolorsshownthereonareaspigmentedbythematerialmanufacturer;unlessotherwiseindicated,thepropertyvaluesarefortheunpigmented(Naturalcolor)material.RefertoFlame-retardantand/orColorConcentrates(QMQS2)andANSI/UL746D,"PolymericMaterials-FabricatedParts,"forlimitationsontheuseofconcentratesbythepartmolderorprocessor.ThefollowingabbreviationsmaybeusedintheindividualRecognitionstorepresentthematerialcolor:ColorsAbbreviationColorALAluminumALL-AO-ATAnycolor-Anycolor(opaqueonly)-Anycolor(transparentonly)AMAmberBGBeigeBKBlackBLBlueBNBrownBZBronzeCLClear GDGoldGNGreenGYGrayIVIvory NCNatural(Nopigmentation)OLOlive OROrangePKPinkRDRedSMSmoke TNTan VTVioletWTWhiteYLYellowFlammabilityMaterialsmaybeclassifiedbasedonburningtestsconductedinaccordancewithANSI/UL94,"TestforFlammabilityofPlasticMaterialsforPartsinDevicesandAppliances,"ANSI/UL1694,"TestsforFlammabilityofSmallPolymericComponentMaterials,"andANSI/UL723,"TestforSurfaceBurningCharacteristicsofBuildingMaterials."ANSI/UL94small-scaletestdatadoesnotpertaintobuildingmaterials,furnishingsandrelatedcontents.ANSI/UL94small-scaletestdataisintendedsolelyfordeterminingtheflammabilityofplasticmaterialsusedinthecomponentsandpartsofend-useproductdevicesandappliances,wheretheacceptabilityofthecombinationisdeterminedbyUL. TESTNAME(perANSI/UL94)HorizontalBurningTest20mmVerticalBurningTestThinMaterialVerticalBurningTestHorizontalBurningFoamedMaterialTest 500Watt(125mm)VerticalTestFlameRatingHierarchy—V-0VTM-0—MoreSevere5VA—V-1VTM-1HF-1↑↑↑—V-2VTM-2HF-25VBHB——HBFLessSevereThermalEnduranceThetemperaturebelowwhichaclassofcriticalpropertywillnotbeunacceptablycompromisedthroughchemicalthermaldegradation,overthereasonablelifeofanelectricalproduct(relativetoareferencematerialhavingaconfirmed,acceptablecorrespondingperformance)isdefinedastheRelativeThermalIndex(RTI).MorethanoneRTImaybeappropriateforagivenmaterialdependingonthepropertyrequirementsforagivenapplication.Incertaincases,highertemperaturesarepermittedifsospecifiedbytheend-useproductstandard.RTIElec—ElectricalRTI,associatedwithcriticalinsulatingproperties.RTIMechImp—MechanicalImpactRTI,associatedwithcriticalimpactresistance,toughness,elongationandflexibilityproperties.RTIMechStr—MechanicalStrength(MechanicalwithoutImpact)RTI,associatedwithcriticalmechanicalstrengthandstructuralintegritywhereimpactresistance,resilienceandflexibilitymaynotbeessential.ResistancetoIgnitionandTrackingPropertiesPerformancemaybeinvestigatedwithrespecttoelectricaltrackresistance,abilitytoresistignitionfromelectricalsources,andotherelectricalproperties.Inordertoavoidanexcessivelevelofimpliedprecisionandbias,materialperformancesforseveraltestsarerecordedasPerformanceLevelCategories(PLC),basedonthemeantestresults(ratherthanrecordingtheexactnumericalresults),asindicatedinthetablefollowingthetestdescription.Hot-WireIgnition(HWI;ASTMD3874,IEC60695-2-20)—Performanceisexpressedasthemeannumberofsecondsneededtoeitherignitestandardspecimensortoburnthroughthespecimenswithoutignition.HWIRangeMeanIgnitionTime(insec)AssignedPLC120andlonger060through119130through59215through2937through144Lessthan75High-CurrentArcIgnition(HAI;ANSI/UL746A)—Performanceisexpressedasthenumberofarcruptureexposures(standardizedastoelectrodetypeandshapeandelectriccircuit)thatarenecessarytoigniteamaterialwhentheyareappliedatastandardrateonthesurfaceofthematerial.HAIRangeMeanNumberofArcstoCauseIgnitionAssignedPLC120andgreater060through119130through59215through293Lessthan154High-VoltageArcTrackingRate(HVTR;ANSI/UL746A)—Denotedastherate,inmm/min,thatatrackingpathcanbeproducedonthesurfaceofthematerialunderstandardizedtestconditions.Anotationismadeifignitiononthematerialtakesplace.Theresultsoftestingthenominal3mmthicknessareconsideredrepresentativeofthematerial'sperformanceinanythickness.HVTRRange(inmm/min)AssignedPLC0through10010.1through25.4125.5through80280.1through1503Greaterthan1504High-Voltage,Low-CurrentArcResistance(D495;ASTMD495)—Expressedasthenumberofsecondsthatamaterialresiststheformationofasurfaceconductingpathwhensubjectedtoanintermittentlyoccurringarcofhighvoltage,lowcurrentcharacteristics.Theresultsoftestingthenominal3mmthicknessareconsideredrepresentativeofthematerial'sperformanceinanythickness.D495RangeMeanTimeofArcResistance(insec)AssignedPLC420andlonger0360through4191300through3592240through2993180through2394120through179560through1196Lessthan607ComparativeTrackingIndex(CTI;ASTMD3638)—Expressedasthatvoltagewhichcausestrackingafter50dropsof0.1percentammoniumchloridesolutionhavefallenonthematerial.Theresultsoftestingthenominal3mmthicknessareconsideredrepresentativeofthematerial'sperformanceinanythickness.CTIRangeTrackingIndex(involts)AssignedPLC600andgreater0400through5991250through3992175through2493100through1744Lessthan1005Theabovecharacteristicsanddielectricstrength,volumeresistivityandotherelectricalandmechanicalpropertiesmaybedeterminedbymeansoftheapplicableASTMand/orULspecificationinANSI/UL746A,"PolymericMaterials-ShortTermPropertyEvaluations."Inadditiontominimumelectricalandignitiontestlevels,materialsthatareusedinapplicationsinvolvingsupportorcontactwithcurrent-carryingpartsarealsorequiredtodisplayaminimumstability(heatdistortion,moistureresistance,dimensionalstabilityandmoldstress)performancelevel,asdescribedinANSI/UL746C,"PolymericMaterials-UseinElectricalEquipmentEvaluations."CONDITIONSOFACCEPTABILITYUnlessspecifiedotherwiseintheindividualRecognitions,considerationistobegiventothefollowingConditionsofAcceptabilitywhenthesecomponentsareemployedintheend-useequipment:1.MaterialtraceabilityforpartscoveredunderFabricatedParts(QMMY2).2.Materialidentificationforadeviceemployingpartsmoldedofthesematerialsshouldspecifytheparts'wallthickness,color,materialidentification,andtraceability.3.MaterialsmustmeetapplicablerequirementsconcerningthemoldingandfabricatingoffinishedpartsasdescribedinANSI/UL746D,"PolymericMaterials-FabricatedParts."Thisincludes,butisnotlimitedto,therestricteduseofregrindthermoplasticmaterialtoamountslessthan25%unlessspecifiedintheindividualRecognitions.4.Unlessotherwiseindicated,suitabilityforusewhenexposedtoweathering,oils,soaps,chemicals,x-rays,andthelikehasnotbeendetermined.5.InvestigationofpartsforotherpropertiesinaccordancewiththeapplicableULend-useproductstandardand/orrequirementsoutlinedinANSI/UL746C.AdditionalConditionsofAcceptabilitymaybefoundintheindividualRecognitionReportavailablefromthemanufacturer.GENERICMATERIALSYMBOLSThegenericmaterialsymbolsarebasedupontheterminologydevelopedintheInternationalOrganizationforStandardizationpublicationsISO1043,"Plastics-SymbolsandAbbreviatedTerms,"andISO1629,"RubberandLatices-Nomenclature." FOAMEDMATERIALSMaterialsthathavebeenfoamedwiththeintroductionofachemicalblowingagentorinertgasmayhavesignificantlydifferentpropertiesthantheunfoamedorsolidmaterialform;therefore,ratingsthatareestablishedforsolid(unfoamed)materialdonotautomaticallyapplytothefoamedversionofthatsamematerial.MATERIALSFORUSEINSPECIALENVIRONMENTSInvestigationofmaterialsforspecificend-useproductapplicationswhererequirementsexistfortheretentionofpropertiesafterexposuretocertaincriticaloperatingand/orenvironmentalconditionsmaybeindicatedintheindividualRecognitions.COLUMNHEADINGABBREVIATIONSThefollowingabbreviationsmaybeusedinthecolumnheadingsintheindividualRecognitions:AbbreviationTermFlameClassANSI/UL94FlammabilityClassificationMaterialDsgMaterialDesignationColColorMinThkMinimumThicknessThkRgThicknessRangeDenRangeg/ccDensityRange,g/ccElecElectricalRPRadiantPanelRTIRelativeTemperatureIndexHWIHot-WireIgnitionHAIHighCurrentArcIgnitionHVTRHighVoltageArcTrackingRateD495ArcResistanceCTIComparativeTrackingIndexMechMechanicalTnslTensileElongElongationStrStrengthImpImpactRELATEDPRODUCTSRefertothefollowingforcomponentsmanufacturedunderotherproductcategories:PolymericMaterials-Filament-woundTubing,IndustrialLaminates,VulcanizedFiber,andMaterialsforUseinFabricatingRecognizedPrintedWiringBoards(QMTS2)CoatingsforUseonRecognizedPrintedWiringBoards(QMJU2)MetallizedParts(QMRX2)SupplierComponentsforUseintheFabricationofMetallizedParts(QMSS2)Systems,ElectricalInsulation(OBJY2)PolymericAdhesiveSystems,ElectricalEquipment(QOQW2)Flame-retardantand/orColorConcentrates(QMQS2)Mold-releaseLubricants(QMSX2)
请问哪位前辈,能告诉我LDPE MG70的塑胶粒有UL认证不?
