焊接英汉词典(zt)
actual weld-throat thick-ness焊缝厚度
all-around weld整周焊缝
all-around weld (整周焊缝)环焊缝
angle butt weld斜对接焊
angle weld角焊
appearance of weld焊缝成形
arc-seam weld电弧缝焊
arc-spot weld电弧点焊
arc-weld电弧焊
aspect ratio of weld焊缝成形系数
at weld edge在焊缝边上
attachment weld连接焊缝
automatic spot weld自动点焊法
automatic weld自动焊接
axis of a weld焊缝中心线; 焊接轴线
axis of weld焊缝轴线; 焊接轴线
back of weld焊缝背面
backing groove of weld焊缝反面坡口
backing weld底焊; 底焊焊缝
bare metal arc weld裸焊条电弧焊
bead weld珠焊; 堆焊
bead-on-plate weld堆焊焊缝
beading weld凸焊
beam-to-beam weld梁间焊接; 梁式引线焊接
block sequence weld分段多层焊
bond weld钢轨接头焊接
bridge seam weld桥缝焊接; 桥线焊
brize weld硬焊
butt weld对接焊缝
butt weld ends对头焊接端
butt-weld碰焊; 平式焊接; 对头焊接
butt-weld in the downhand position对接平焊
butt-weld joint对头焊接
butt-weld pipe mill对焊管轧机
button spot weld按电钮点焊
cap weld最后焊层; 盖面焊缝
carbon content of weld materials焊接材料的碳含量
cast-weld construction铸焊结构
caulk weld填缝焊
caulking weld密实焊缝
chain intermittent fillet weld链式分段角焊; 并列间断角焊缝
全部回复(8)
chain intermittent weld并列焊接
circular weld环形焊缝
circumferential weld环缝; 环焊缝
cleft weld裂口焊
closed weld底边无缝焊; 无间隙焊缝
closed-chamber fusion weld闭室熔焊
cluster weld丛聚焊缝
coil weld卷板对接焊; 卷板对接焊; 板卷焊
cold weld冷压接
commutator-controlled weld换向控制焊接
complete penetration butt weld贯穿对焊
composite weld紧密焊缝; 强度密封焊缝
concave filled weld凹形角焊缝
concave filler weld凹角焊
concave fillet weld凹面填角焊
concave weld凹焊缝; 凹面焊; 凹形焊缝; 轻型焊
connective weld联系焊缝
continuous butt-weld mill连续式炉焊管机组
continuous fillet weld连续(填)角焊缝; 连续角焊缝; 连续贴角焊
continuous weld连续焊缝
continuous weld process连续式炉焊管法
contour weld特形焊接
convex fillet weld凸角焊缝; 凸形角焊缝
convex weld凸焊缝; 凸形焊缝
copper weld wire包铜钢丝
corner flange weld单卷边角焊缝
corner weld角焊
corner-flange weld卷边角焊缝; 卷边角焊缝
crack of weld焊部裂纹
cross weld十字交叉焊缝; 横向焊缝
cross-wire weld十字焊
crotch weld楔接锻接; 楔接焊接
cup weld带盖板焊缝
depth of weld焊接深度
dissimilar weld metal不同的焊接金属; 不同金属的焊接
distance between the toes of a weld焊缝宽度
double groove weld双面坡口焊缝
double-bevel groove weld双斜边坡口焊缝; 双斜坡口焊
double-flanged butt weld双弯边对接焊缝
double-V groove weld双斜边坡口焊缝; 双斜坡口焊
downhand weld平焊缝
duplex spot weld双点点焊接头
edge joint weld边缘焊
edge weld端接焊; 端接焊缝; 端面焊缝; 对边焊
electric resistance weld mill电阻焊管机
electric weld-pipe mill电焊管机
electric-weld pipe mill电焊管机
emporary weld临时点定焊缝
excess weld metal焊缝补强金属; 补强; 补强焊料; 补强金属
excess weld metal(焊缝的)余高
explosive weld爆炸焊接
face of weld焊缝表面; 焊接面
fibrous weld纤维状焊缝
field weld现场焊接
filler weld填角焊缝
fillet weld角焊缝; 填角焊; 贴角焊
fillet weld in normal shear (搭接接头的)正面角焊缝
fillet weld in parallel shear侧面角焊缝; 侧面填角焊
fillet weld in the flat position角接平焊; 水平角焊缝
fillet weld in the horizontal position横向角焊缝
fillet weld size焊角尺寸; 填角焊缝尺寸
flame weld火焰焊接
flange weld卷边焊缝; 卷边焊缝
flange-to-web weld卷边焊缝; 卷边焊缝
flanged butt weld弯边对接焊
flanged edge weld卷边焊; 卷边焊
flash butt weld闪光焊
flash weld闪速对焊
flat faced fillet weld平顶角焊缝焊接
flat fillet weld平角焊
ing of fillet weld角焊缝平焊; 船形角焊
flush fillet weld平角焊
flush weld削平补强的焊缝; 平焊接; 无加强高的焊缝
forge weld锻焊焊缝
forged weld (焊后锻压的)锻压焊缝
form factor of the weld焊缝成形系数
formation of weld焊缝成形
front fillet weld正侧面填角焊缝; 正面填角焊
front(al) fillet weld正面角焊缝
full fillet weld满角焊缝; 全角焊
full penetration butt weld满对接焊
full weld满焊
full-fillet weld满角焊
full-sized weld全尺寸焊缝
full-strength weld (与母材等强)等强焊缝
gap weld特殊点焊; 双极单点焊
gas-pressure weld气压焊
girth weld环形焊缝
gravity weld倚焊
groove weld坡口焊; 坡口焊缝; 有坡口焊缝; 凹槽焊
groove-weld joint有坡口焊接接头
hammer weld锻焊
hand weld手焊焊缝
height of reinforcement of weld加强焊缝高度
helical-weld pipe螺旋焊管
high performance weld flux高性能焊剂
horizontal fillet weld横向角缝焊接
horizontal weld横向焊缝
horizontal-vertical fillet weld横向垂直角焊缝
hot weld encapsulation热焊封袋
hydraulic automatic weld液压自动焊接
hydraulic weld process液压焊接法
inclined weld斜焊
inconel weld单面焊缝
incorrect weld profile焊缝形状不对
incorrect weld size焊缝尺寸不对
induction weld mill感应焊管机
inside corner weld内角焊接
inside fillet weld内角焊接
inside weld内焊缝
insufficient or excess reinforcement of weld加强焊缝不足或过量
intermittent fillet weld间断角缝焊接; 断续角焊缝
intermittent weld断续焊; 断续焊缝
jam weld对接焊; 对头焊接
lap fillet weld搭接角焊缝
laser (beam) weld (ing)激光焊
lateral weld侧焊; 侧面焊缝
leg of a fillet weld角焊缝; 角焊缝焊脚
leg of fillet weld圆角焊肉厚
length of weld焊缝长度
light closing weld轻连续焊接
light fillet weld轻型填角焊; 小填角焊
light weld轻焊缝
Lincoln weld埋弧自动焊
longitudinal fillet weld纵向角焊
longitudinal weld纵向焊缝
longitudinal weld (焊接用语)纵缝
loose weld脱焊
main weld主焊缝
mash seam weld压薄缝焊; 滚压焊
mash weld点焊; 点压焊
melt thru weld熔透焊缝
melt-through weld透溶焊
melten weld pool焊接熔池
melting through weld熔透焊缝
miter weld平顶角焊缝; 斜接角焊缝
molten weld metal熔融焊接金属
mulitple impulse weld多脉冲焊缝
multilayer weld多层焊缝
multipass weld多道焊缝
multiple arc weld多弧焊缝
multiple-electrode submerged arc weld多电极埋弧焊
multiple-pass weld多道焊缝; 多路焊接
multirun weld多道焊缝
nonpressure thermit weld不加压热剂焊缝
normal weld正常焊接
oblique fillet weld斜交角焊缝; 斜角焊接
one-pass weld单层焊缝
open butt weld开口对接焊
open weld留间隙焊缝; 空隙焊
outside weld外焊缝
over weld过焊
overhead fillet weld仰焊角焊缝
overhead weld仰焊
oversize weld超尺寸焊缝
oxygen weld氧气焊接
parallel-arc weld并列弧焊
patch weld补焊; 补孔焊缝
Peltier's cross weld珀耳帖交叉焊接
penetration weld熔透焊缝
percussion weld冲击焊缝; 冲击焊接
periphera weld环形焊缝
pitch of weld焊缝接距; 焊线距
plain butt weld无坡口对接焊; 平头对接焊缝
plasma-arc weld等离子弧焊接
plug weld塞焊焊缝
point of weld焊接点
point weld点焊
poor weld劣质焊缝; 有缺陷的焊缝
porous weld多孔焊缝; 疏松焊缝
positioned weld平位焊缝; 暂焊
post weld annealed (PWA)焊后退火
poured weld铸焊焊缝
powder weld process粉末焊接法
practice weld试验焊缝
pressure weld压焊
pressure-controlled weld压力控制焊接
pressure-tight weld气密焊; 密封焊道
principal weld主要焊缝
profile of fillet weld填角焊缝轮廓
progress of weld焊向
projection weld凸焊; 凸焊焊缝
projection weld machine凸点电阻焊机
pulsating weld脉冲接触焊
push weld挤焊
quilting weld钉焊
reinforced butt weld补强的对接焊缝; 补强式对接焊缝
reinforced weld加强焊接
reinforcement of weld焊缝加厚; 补强金属; 加强焊缝
resistance weld pipe电阻焊管
resonance butt weld谐振式对接焊
restarting a weld再引弧
ripple weld鳞状焊缝
rivet weld电铆; 电铆焊缝
root face of weld焊缝根部钝边
root gap of weld焊缝根部间隙
root of weld焊缝根部; 焊根
root opening of weld焊缝根部间隙
root radius of weld焊缝坡口根部半径
sagged weld下垂焊缝
scarf weld楔口焊接
seal weld填焊; 致密焊缝; 密封焊; 密封焊道; 密封焊缝
sealing weld封焊
seam weld滚焊
semi-automatic arc weld半自动电弧焊
sequence weld timer序列焊接时间调节器
shallow weld浅焊
shop weld工厂焊接
shot weld点焊
shoulder of weld焊缝根部钝边
side fillet weld侧面角焊缝; 侧面填角焊缝; 侧面贴角焊
side lap weld侧边搭接焊; 弯边搭焊缝
side weld侧焊缝; 边焊
single lap weld单搭接焊
single strap butt weld单面盖板对接焊
single-bevel groove weld单斜角槽焊
single-fillet weld单边角接焊缝
single-pass weld单道焊
site weld现场焊接; 安装焊; 安装焊接
size of a fillet weld焊角尺寸
size of weld焊件的大小; 焊区尺寸
skew weld斜焊
skin weld表面焊接
sleeve weld套筒焊接
slip-weld hanger卡瓦焊接套管挂
slot weld槽塞焊; 长孔焊; 开槽搭焊缝; 切口焊缝
ing slotted weld槽焊
slotted lap weld切口搭接焊
smooth fillet weld平填角焊缝
socket weld ends承插焊接端
soft-weld铜镍焊条合金
solvent weld溶剂焊接
space of intermittent weld断续焊缝间距; 断续焊间距
spiral weld螺旋形焊缝
spiral weld-pipe mill螺旋焊管机
spot weld焊点
spot weld bonding胶结点焊
spot weld nugget点焊熔核
spreading weld宽缝焊接; 加宽的焊缝
square butt weld平头对接焊缝
square groove weld无坡口槽焊
staggered intermittent fillet weld (ing)交错断续角焊
staggered intermittent weld交错断续焊缝; 交错间断焊
staggered plug weld交错塞焊
standard reinforced fillet weld标准加强角焊缝
stick-out weld未熔合点焊接头
stitch-and-seam weld点线焊
straight butt weld无坡口对接接头
strapped weld搭板对接焊缝
strength weld受载焊缝; 强固焊接; 承载焊缝; 高强度焊接
structural weld强固焊缝
surface of weld焊缝表面
surface weld表面焊缝
surface weld metal buildup表面焊缝金属的形成
synthetic apparatus for weld thermal cycle焊接热循环模拟装置
T weld丁字接头焊缝
T-filled weld丁字形角焊
T-fillet weld丁字接头角焊缝
tack weld定位焊点; 定位焊缝; 临时点焊; 预焊; 平头焊接
(welding)定位焊
tandem arc weld前后弧焊
temporary weld临时点固焊缝
tension weld受拉焊缝
test weld试焊
throat depth (thickness) of fillet weld角焊缝厚度
throat of fillet weld凹角焊喉; 填角焊缝喉长
throat of weld凹角焊喉
tight weld密封焊接; 致密焊缝
tight-strong weld密实强固焊缝
toe of the weld焊缝边界
toe of weld焊趾
toe weld趾部焊缝
torch weld气焊焊缝
total amount of weld fumes焊接发尘量
transverse fillet weld横向角焊缝; 正面角焊
transverse weld横向焊缝
trial weld试验焊接
undercut weld底切焊接
undressed weld (增加焊缝)未加工焊缝
unequal fillet weld焊脚不等的角焊缝
unfitness of butt weld焊缝对口错边量
union-melt weld埋弧焊
unload weld非承载焊缝
unspaced butted weld无间隙对接焊缝
upgrading of boiler weld锅炉焊缝加强
vertical fillet weld立焊角焊缝
vertical weld立焊
weak weld不强固焊缝
weaving weld横向摆动焊缝
weld焊; 焊接的; 补焊
weld all around围焊
weld appearance焊缝外观
weld assembly焊接组件
weld back-up焊缝背垫
weld backing焊缝衬垫
weld bead焊缝; 熔敷焊道
weld bead height焊缝高度
weld beading焊瘤
weld bond熔合线
weld bridge seam搭桥焊缝; 桥接焊缝
weld cap焊帽
weld center line焊缝中心线
weld collar加强焊缝焊瘤
weld crack焊接裂纹
weld crater熔池
weld crosswise交叉焊接
weld decay焊缝腐蚀; 焊接接头晶间腐蚀; 焊接侵蚀; 焊接区晶间腐蚀
weld decay (焊接后)敏化区腐蚀
weld defect焊接缺陷
weld delay time焊接延迟时间
weld deposit堆焊
weld deposits cleaning焊接熔敷金属清理
weld edge焊缝边缘; 焊缝表面边缘
weld edgewise沿边焊接
weld flange connection焊接法兰连接
weld flash焊瘤
weld flaw焊接缺陷
weld flush焊缝隆起
weld fumes焊接烟尘
weld gage焊缝检查规; 焊缝卡规
weld gauge焊缝量规
weld heat input焊接热输入; 焊接线能量
weld holder焊接夹持架; 焊接架
weld inspection焊缝质量检验; 焊接检查
weld interface焊缝界面; 焊接界面
weld interval焊接时间
weld is accepted焊缝合格
weld jig焊接夹具
weld joint焊缝
weld junction熔焊线; 熔合线
weld layer焊接层
weld length焊缝长度
weld line焊缝线; 焊缝轴线; 焊接线; 焊线
weld machined flush削平补强的焊缝
weld mark焊缝符号; 焊缝记号; 焊接痕; 熔缝
weld mesh crate焊接网格
weld metal焊缝金属; 焊接金属
weld metal buildup surface金属堆焊表面
weld metal composition焊接金属组成
weld metal cracking焊缝裂纹
weld metal zone焊缝金属区; 焊接金属熔化区
weld nugget焊点熔核
weld on bottom底焊
weld overlap重叠区
weld pass焊接通道
weld penetration焊缝熔深; 焊透深度
weld period焊接时间
weld pitch焊缝距
weld porosity焊缝气孔
weld preheating焊前预热
weld preparation焊缝坡口加工
weld puddle熔池
weld reinforcement焊缝补强; 焊缝加强; 焊接补强
weld repairs焊接修补
weld ripple焊缝波纹
weld root焊件剖口; 焊接根
weld root opening gap焊缝根部间隙
weld root reinforcement焊缝反面加强
weld rotation焊缝转角
weld seam pipe焊缝管
weld shape焊缝形状
weld shielding焊接区保护; 焊接熔池保护
weld slope焊缝倾角
weld spacing焊点距; 焊缝间距
weld strain焊接应变
weld strength焊接强度
weld surface焊缝表面
weld swell焊缝隆起
weld thickness焊缝厚度
weld time焊接时间; 焊接通电时间; 接触焊通电时间
weld toxic gases焊接有害气体
weld trimmer焊缝清理机
weld up焊补
weld wheel conditioner焊轮调节器
weld width焊缝宽度
weld wire包铜钢丝
weld zone焊缝区; 焊接区
weld-form factor焊缝形状系数
weld-fusion line焊缝熔合线
weld-in nozzle焊入式喷嘴
weld-interval timer焊接间隔记时器
weld-shrunk cylinder包扎式圆筒
weld-shrunk multilayered cylinder包扎式多层圆筒; 多层包扎式圆筒
weld-throat thickness depth焊缝厚度
window type restraint weld cracking test窗口拘束焊缝抗裂试验; 窗形拘束抗裂试验
zigzag intermittent fillet weld锯齿形断续角焊缝; 锯齿形断续角焊缝
zone of weld焊缝表面
这是我在焊接版的第一个贴,若这些东东有人需要我再发,不需要我就删了.
挹江
@☆来不及☆
reinforcedbuttweld补强的对接焊缝;补强式对接焊缝reinforcedweld加强焊接reinforcementofweld焊缝加厚;补强金属;加强焊缝resistanceweldmill电阻焊管机resistanceweldpipe电阻焊管resonancebuttweld谐振式对接焊restartingaweld再引弧rippleweld鳞状焊缝rivetweld电铆;电铆焊缝rootfaceofweld焊缝根部钝边rootgapofweld焊缝根部间隙rootofweld焊缝根部;焊根rootopeningofweld焊缝根部间隙rootradiusofweld焊缝坡口根部半径saggedweld下垂焊缝scarfweld楔口焊接sealweld填焊;致密焊缝;密封焊;密封焊道;密封焊缝sealingweld封焊seamweld滚焊semi-automaticarcweld半自动电弧焊sequenceweldtimer序列焊接时间调节器shallowweld浅焊shopweld工厂焊接shotweld点焊shoulderofweld焊缝根部钝边sidefilletweld侧面角焊缝;侧面填角焊缝;侧面贴角焊sidelapweld侧边搭接焊;弯边搭焊缝sideweld侧焊缝;边焊singlelapweld单搭接焊singlestrapbuttweld单面盖板对接焊single-bevelgrooveweld单斜角槽焊single-filletweld单边角接焊缝single-passweld单道焊siteweld现场焊接;安装焊;安装焊接sizeofafilletweld焊角尺寸sizeofweld焊件的大小;焊区尺寸skewweld斜焊skinweld表面焊接sleeveweld套筒焊接slip-weldhanger卡瓦焊接套管挂slotweld槽塞焊;长孔焊;开槽搭焊缝;切口焊缝ingslottedweld槽焊slottedlapweld切口搭接焊smoothfilletweld平填角焊缝socketweldends承插焊接端soft-weld铜镍焊条合金solventweld溶剂焊接spaceofintermittentweld断续焊缝间距;断续焊间距spiralweld螺旋形焊缝spiralweld-pipemill螺旋焊管机spotweld焊点spotweldbonding胶结点焊spotweldnugget点焊熔核spreadingweld宽缝焊接;加宽的焊缝squarebuttweld平头对接焊缝squaregrooveweld无坡口槽焊staggeredintermittentfilletweld(ing)交错断续角焊staggeredintermittentweld交错断续焊缝;交错间断焊staggeredplugweld交错塞焊standardreinforcedfilletweld标准加强角焊缝stick-outweld未熔合点焊接头stitch-and-seamweld点线焊straightbuttweld无坡口对接接头strappedweld搭板对接焊缝strengthweld受载焊缝;强固焊接;承载焊缝;高强度焊接structuralweld强固焊缝surfaceofweld焊缝表面surfaceweld表面焊缝surfaceweldmetalbuildup表面焊缝金属的形成syntheticapparatusforweldthermalcycle焊接热循环模拟装置Tweld丁字接头焊缝T-filledweld丁字形角焊T-filletweld丁字接头角焊缝tackweld定位焊点;定位焊缝;临时点焊;预焊;平头焊接(welding)定位焊tandemarcweld前后弧焊temporaryweld临时点固焊缝tensionweld受拉焊缝testweld试焊throatdepth(thickness)offilletweld角焊缝厚度throatoffilletweld凹角焊喉;填角焊缝喉长throatofweld凹角焊喉tightweld密封焊接;致密焊缝tight-strongweld密实强固焊缝toeoftheweld焊缝边界toeofweld焊趾toeweld趾部焊缝torchweld气焊焊缝totalamountofweldfumes焊接发尘量transversefilletweld横向角焊缝;正面角焊transverseweld横向焊缝trialweld试验焊接undercutweld底切焊接undressedweld(增加焊缝)未加工焊缝unequalfilletweld焊脚不等的角焊缝unfitnessofbuttweld焊缝对口错边量union-meltweld埋弧焊unloadweld非承载焊缝unspacedbuttedweld无间隙对接焊缝upgradingofboilerweld锅炉焊缝加强verticalfilletweld立焊角焊缝verticalweld立焊weakweld不强固焊缝weavingweld横向摆动焊缝weld焊;焊接的;补焊weldallaround围焊weldappearance焊缝外观weldassembly焊接组件weldback-up焊缝背垫weldbacking焊缝衬垫weldbead焊缝;熔敷焊道weldbeadheight焊缝高度weldbeading焊瘤weldbond熔合线weldbridgeseam搭桥焊缝;桥接焊缝weldcap焊帽weldcenterline焊缝中心线weldcollar加强焊缝焊瘤weldcrack焊接裂纹weldcrater熔池weldcrosswise交叉焊接welddecay焊缝腐蚀;焊接接头晶间腐蚀;焊接侵蚀;焊接区晶间腐蚀welddecay(焊接后)敏化区腐蚀welddefect焊接缺陷welddelaytime焊接延迟时间welddeposit堆焊welddepositscleaning焊接熔敷金属清理weldedge焊缝边缘;焊缝表面边缘weldedgewise沿边焊接weldflangeconnection焊接法兰连接weldflash焊瘤weldflaw焊接缺陷weldflush焊缝隆起weldfumes焊接烟尘weldgage焊缝检查规;焊缝卡规weldgauge焊缝量规weldheatinput焊接热输入;焊接线能量weldholder焊接夹持架;焊接架weldinspection焊缝质量检验;焊接检查weldinterface焊缝界面;焊接界面weldinterval焊接时间weldisaccepted焊缝合格weldjig焊接夹具weldjoint焊缝weldjunction熔焊线;熔合线weldlayer焊接层weldlength焊缝长度weldline焊缝线;焊缝轴线;焊接线;焊线weldmachinedflush削平补强的焊缝weldmark焊缝符号;焊缝记号;焊接痕;熔缝weldmeshcrate焊接网格weldmetal焊缝金属;焊接金属weldmetalbuildupsurface金属堆焊表面weldmetalcomposition焊接金属组成weldmetalcracking焊缝裂纹weldmetalzone焊缝金属区;焊接金属熔化区weldnugget焊点熔核weldonbottom底焊weldoverlap重叠区weldpass焊接通道weldpenetration焊缝熔深;焊透深度weldperiod焊接时间weldpitch焊缝距weldporosity焊缝气孔weldpreheating焊前预热weldpreparation焊缝坡口加工weldpuddle熔池weldreinforcement焊缝补强;焊缝加强;焊接补强weldrepairs焊接修补weldripple焊缝波纹weldroot焊件剖口;焊接根weldrootopeninggap焊缝根部间隙weldrootreinforcement焊缝反面加强weldrotation焊缝转角weldseampipe焊缝管weldshape焊缝形状weldshielding焊接区保护;焊接熔池保护weldslope焊缝倾角weldspacing焊点距;焊缝间距weldstrain焊接应变weldstrength焊接强度weldsurface焊缝表面weldswell焊缝隆起weldthermalcycle焊接热循环weldthickness焊缝厚度weldtime焊接时间;焊接通电时间;接触焊通电时间weldtoxicgases焊接有害气体weldtrimmer焊缝清理机weldup焊补weldwheelconditioner焊轮调节器weldwidth焊缝宽度weldwire包铜钢丝weldzone焊缝区;焊接区weld-formfactor焊缝形状系数weld-fusionline焊缝熔合线weld-innozzle焊入式喷嘴weld-intervaltimer焊接间隔记时器weld-shrunkcylinder包扎式圆筒weld-shrunkmultilayeredcylinder包扎式多层圆筒;多层包扎式圆筒weld-throatthicknessdepth焊缝厚度windowtyperestraintweldcrackingtest窗口拘束焊缝抗裂试验;窗形拘束抗裂试验zigzagintermittentfilletweld锯齿形断续角焊缝;锯齿形断续角焊缝zoneofweld焊缝表面
要好好学学,多谢捧场.
@挹江
要好好学学,多谢捧场.
呵,挹江斑竹,我刚开始接触焊接,多多指教哦
@☆来不及☆
能不能给我传一份呀?
谢谢
shiningstar123@163.com
@shining4569
能不能给我传一份呀?谢谢shiningstar123@163.com
你要什么就这样说呗,发在论坛里大家才能共享啊
laserwang
你的这些东西还是有用的
