TL494的Multisim的模型出现问题
我在网上下载 TL494的Multisim的模型仿真过程中出现下列问题,请教高手如何解决?谢谢!error in C:\USERS\ASUS\APPDATA\LOCAL\TEMP\02.CIR.cir(129):d1ogr1 v1_4 11 $generic
error in C:\USERS\ASUS\APPDATA\LOCAL\TEMP\02.CIR.cir(130):d1ogr2 11 v4_5 $generic
error in C:\USERS\ASUS\APPDATA\LOCAL\TEMP\02.CIR.cir(138):d2ogr1 v1_4 12 $generic
error in C:\USERS\ASUS\APPDATA\LOCAL\TEMP\02.CIR.cir(139):d2ogr2 12 v4_5 $generic
error in C:\USERS\ASUS\APPDATA\LOCAL\TEMP\02.CIR.cir(142):d1 13 fb $generic
error in C:\USERS\ASUS\APPDATA\LOCAL\TEMP\02.CIR.cir(181):d2 -s1 et1 $generic
error in C:\USERS\ASUS\APPDATA\LOCAL\TEMP\02.CIR.cir(182):d3 -s2 et2 $generic
error in C:\USERS\ASUS\APPDATA\LOCAL\TEMP\02.CIR.cir(184):.model $generic:xda1 d (bv=500 cjo=2.5p is=8n m=100m n=2 rs=400m tt=1n vj=700m)
全部回复(1)
jerry.li
在另个电脑中仿真出现error in D:\CIRCUI~1.0\02.CIR.cir(68):d1 13 17 $generic
error in D:\CIRCUI~1.0\02.CIR.cir(69):d2 14 17 $generic
error in D:\CIRCUI~1.0\02.CIR.cir(112):.model $generic:xu1 d (is=8n n=2 bv=500 rs=400m tt=1n cjo=2.5p vj=700m m=100m)
Instrument operation performed   (2013, May 30, Thursday, 09:19:09)
|   Instrument Analysis:Transient Analysis
|   |   Plot title:
|   |   Analysis settings
|   |   |   Initial Conditions:Automatically generate initial conditions
|   |   |   Starting time (TSTART):0
|   |   |   Stop time (TSTOP):1e+030
|   |   |   Plotting increment (TSTEP):automatically calculated (less than:1e+030)
|   |   |   Maximum time step (TMAX):automatically calculated (less than:1e+030)
|   |   Perform consistency check
|   |   Variables from analysis
|   |   |   Show device values at the end of the simulation
|   |   Representation as SPICE commands
|   |   |   begin-scope page
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   set rshunt = 1e+012
|   |   |   -param hrange 0 1e+030
|   |   |   save
|   |   |   tran  -env-options 1e-005 1e+030 0 1e-005 auto_ic auto_tstep auto_tmax
|   |   |   if-error end-scope audit-log-show
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
|   |   Multisim Default Analysis Options
|   |   |   Truncation error overestimation factor: 7
|   |   |   Upper transient iteration limit: 100
|   |   |   Enable convergence assistance for code models
|   |   |   Shunt resistance from analog nodes to ground: 1e+012
|   Output from instrument analysis
|   |   singular matrix:  check nodes be1_ti0:xu1#branch and $:xu1----in2
|   |    starting Gmin stepping
|   |    Gmin step failed
|   |    Gmin stepping failed
|   |    starting source stepping
|   |    source stepping failed
|   |    DC operating point failed. Resimulating with UIC.
|   |    TRAN:  Timestep too small; initial timepoint:trouble with ($generic:xu1) d1:xu1
|   |    doAnalyses: timestep too small
|   |   tran simulation(s) aborted
Instrument operation performed   (2013, May 30, Thursday, 09:19:13)
|   |   Plot title:
|   |   Analysis settings
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   save
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
|   |    Gmin step failed
Instrument operation performed   (2013, May 30, Thursday, 09:19:18)
|   |   Plot title:
|   |   Analysis settings
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl4 = 100
|   |   |   set method = "gear"
|   |   |   set convlimit
|   |   |   save
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
|   |   Custom Analysis Options
|   |   |   Integration method: gear
|   |    Gmin step failed
Instrument operation performed   (2013, May 30, Thursday, 09:19:23)
|   |   Plot title:
|   |   Analysis settings
|   |   |   Initial Conditions:Zero initial conditions
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   save
|   |   |   tran  -env-options 1e-005 1e+030 0 1e-005 zero_ic auto_tstep auto_tmax
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
Instrument operation performed   (2013, May 30, Thursday, 09:19:27)
|   |   Plot title:
|   |   Analysis settings
|   |   |   Plotting increment (TSTEP):0.0001
|   |   |   Maximum time step (TMAX):0.0001
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   save
|   |   |   tran  -env-options 0.0001 1e+030 0 0.0001 zero_ic
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
Instrument operation performed   (2013, May 30, Thursday, 09:19:30)
|   |   Plot title:
|   |   Analysis settings
|   |   |   Plotting increment (TSTEP):0.001
|   |   |   Maximum time step (TMAX):0.001
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   save
|   |   |   tran  -env-options 0.001 1e+030 0 0.001 zero_ic
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
Instrument operation performed   (2013, May 30, Thursday, 09:19:33)
|   |   Plot title:
|   |   Analysis settings
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set reltol = 0.01
|   |   |   set trtol = 7
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   save
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
|   |   |   Relative error tolerance: 0.01
Instrument operation performed   (2013, May 30, Thursday, 09:19:35)
|   |   Plot title:
|   |   Analysis settings
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   set rshunt = 1e+009
|   |   |   save
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
|   |   |   Shunt resistance from analog nodes to ground: 1e+009
Instrument operation performed   (2013, May 30, Thursday, 09:19:38)
|   |   Plot title:
|   |   Analysis settings
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   set rshunt = 1e+008
|   |   |   save
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
|   |   |   Shunt resistance from analog nodes to ground: 1e+008
Instrument operation performed   (2013, May 30, Thursday, 09:19:42)
|   |   Plot title:
|   |   Analysis settings
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   set rshunt = 1e+007
|   |   |   save
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
|   |   |   Shunt resistance from analog nodes to ground: 1e+007
Instrument operation performed   (2013, May 30, Thursday, 09:19:45)
|   |   Plot title:
|   |   Analysis settings
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl1 = 200
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   save
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
|   |   |   DC iteration limit: 200
Instrument operation performed   (2013, May 30, Thursday, 09:19:47)
|   |   Plot title:
|   |   Analysis settings
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl1 = 300
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   save
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
|   |   |   DC iteration limit: 300
Instrument operation performed   (2013, May 30, Thursday, 09:19:50)
|   |   Plot title:
|   |   Analysis settings
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set gmin = 1e-007
|   |   |   set trtol = 7
|   |   |   set itl1 = 300
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   save
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
|   |   |   Minimum conductance: 1e-007
Instrument operation performed   (2013, May 30, Thursday, 09:19:53)
|   |   Plot title:
|   |   Analysis settings
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl1 = 300
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   save
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
Instrument operation performed   (2013, May 30, Thursday, 09:19:56)
|   |   Plot title:
|   |   Analysis settings
|   |   |   Plotting increment (TSTEP):1e-005
|   |   |   Maximum time step (TMAX):1e-005
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl1 = 300
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   save
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
