Designing The inductance of the transformer primary side Lm:
Lm= (Vdc min * Dmax)square / (2 Pin * Fs * Krf)
Where Lm- primary inductance
F s- switching frequency
Krf- ripple factor in full load & min input voltage.
Key rule:
For discontinuous mode , set krf =1
For continuous mode, set kef < 1
If you are making flyback converter to be operated in CCM mode, just prefer to set krf between 0.25 – 0.5 for universal input range & krf = 0.4 – 0.8 for European input range.
这个是老外写的资料,是大于1还是等于1阿?
