Features
Low dark current Auto black level calibration
Two wire serial interface, 16-bit address and 8-bit data
Support output format: YCbCr (4:2:2), RGB565, RGB555, RGB444, Raw and JPEG
Support image size: HD (1280 by 720) and any size from scaling down
Lens shading correction
Automatic control functions: Auto-Exposure control (AE) and Auto-White Balance (AWB)
Including: Sharpness, noise reduction, defect correction, gamma, color saturation adjustment.
Specical effects included.
Embedded 1.5V regulator for core power
Target module size: 6.0mm x 6.0mm MIPI interface
需要規格書的請聯繫我
授權電源品牌ST,FSC,DIODES,ON,TI,NXP,TOSHIBA, RICHTECK, INFINEON二三極管,MOSFET, 整流橋,IGBT,光耦,可控硅,肖特基,電源管理IC
