FP6276B-5V/2.1A移动电源应用同步升压IC
FP6276B-500kHz 5A High Efficiency Synchronous PWM Boost Converter
General Description
      The FP6276B is a current mode synchronous boost DC-DC converter with PWM/PSM control. Its PWM circuitry with built-in 50mΩ high side switch and 50mΩ low side switch make this regulator highly power efficient. The internal compensation network also minimizes as much as 6 external component counts. The non-inverting input of error amplifier connects to a 0.6V precision reference voltage and internal soft-start function can reduce the inrush current.
Features
 Current mode with PWM/PSM control
 Input Voltage range: 2.4V~4.5V
 Shutdown current: <1uA
 Oscillator frequency: 500KHz
 Reference voltage: 0.6V +/-2%
 Load disconnect during shutdown
 Cycle-by-cycle current limit
 Low RDS(on): Low side 50mΩ, High side50mΩ.
 Protection: OTP, Output OVP, SCP
 Internal Compensation
 Internal Soft-start: 7ms
 Package: SOP8(EP)
Applications
 Chargers
 Handheld Devices
 Portable Products
 Power Bank
FP6276B效率测试表
Vin
Iin
Vout
Iout
效率
3.0V
3.65A
4.95V
2A
90.4%
3.3V
3.33A
5.04V
2A
91.7%
3.7V
2.95A
5.05V
2A
92.5%
4.2V
2.56A
5.05V
2A
93.9%
全部回复(2)
sky_wolf
我要单锂电升压到9V,12V,1.5A,效率会到多少?
mbgcn
@sky_wolf
联系方式
