ZXGD3103-多口充电器方案(同步整流IC)骊微电子
zxgd3103我们公司已大批量应用于7.1A,6.1A多口充电器方案,性能相当不错,外围简洁
产品描述:   The ZXGD3103 is intended to drive MOSFETS configured as ideal diode replacements. The device is comprised of a differential amplifier detector stage and high current driver. The detector monitors the reverse voltage of the MOSFET such that if body diode conduction occurs a positive voltage is applied to the MOSFET’s Gate pin.   Once the positive voltage is applied to the Gate the MOSFET switches on allowing reverse current flow. The detectors’ output voltage is then proportional to the MOSFET Drain-Source reverse voltage drop and this is applied to the Gate via the driver. This action provides a rapid turn off as current decays.
产品特点: Proportional Gate Drive  Turn-off propagation delay 15ns and turn-off  time 20ns.  etector threshold voltage ~10mV Standby current 5mA  Suitable for Discontinuous Mode (DCM),  Critical Conduction Mode (CrCM) and Continuous Mode (CCM) operation  5-15V VCC range  QQ2880603803
应用领域:   Flyback Converters in:  Adaptors  LCD Monitors  Server PSU’s  Set Top Boxes  LCD TV   Resonant Converters   LED TV   High power Adaptors   Street Lighting   ATX psu
全部回复(14)
xg0725
5V10A 12A的方案由没有?发至:xg0725@163.com,谢谢
leweitech
@xg0725
5V10A12A的方案由没有?发至:xg0725@163.com,谢谢
嗯,好的
xg0725
@leweitech
嗯,好的
你先把既有的多口 6.1A  7.1A USB充电器方案发给我  xg0725@163.com  谢谢
qyxd168
5V10A 12A的方案已请发给我下。谢谢
2647514003@QQ.COM
@qyxd168
5V10A12A的方案已请发给我下。谢谢2647514003@QQ.COM
5V 4.8A 方案请发给我下。谢谢779211361@QQ.COM
有没有5V4.8A的方案发我一份124094197@qq.com,谢谢。
tjh7378
有需要COOL-MOS的可以联系我,QQ2428389718;免费提供样品,可大幅降低产品温升,提高产品可靠性。
wymyong
方案请发给我下。谢谢414358857@QQ.COM
12zm
发资料给我2389351088@qq.com
leweitech
@qyxd168
好的,已发送
leweitech
@电源好爱好者
好的,已发送
leweitech
@12zm
好的已发送
leweitech
@wymyong
好的,已发送
picq
发资料给我511572703@qq.com
