求大侠帮忙设计这个高频变压器
Specifications :
- Output voltage : 5 kiloVolts peak minimum.
- DC input voltage on primary coil : 24VDC seems standard but I can adapt my circuitry to any standard voltage available.
- Output power : 10 Watts or less.
- Operating frequency : 20KHz minimum.
- Number of coils : primary and one high voltage secondary without any internal diode. I can accept other secondary windings but I do not need them.
- Audible noise : As low as possible since it may be used at audible frequencies.
- Application : Ozone generator.
全部回复(0)
