为什么我用一个最基本的buck型DC/DC来仿真,最近没办法成功,跳出这样的提示要怎么办呐?
there is no devices in this circuit.1103254473.sch
pspice9.1仿真请教!菜菜鸟上路!
全部回复(3)
参考以下试试:
BUCK WITH RATIO CONVERTER -- STEP CHANGE IN LOAD (buckstep.cir)
**** CIRCUIT DESCRIPTION
**************** OUTPUT IS V(3) ***************************
**************** CIRCUIT PARAMETERS *******************
.PARAM VS=50
.PARAM L=1MH
.PARAM RL=0.4
.PARAM C=100UF
.PARAM RESR=0.5
.PARAM R=4
.PARAM D=.4
.PROBE
.TRAN 10uS 6MS UIC
**************** CIRCUIT DESCRIPTION ************
VS 1 0 {VS}
L 2 2a {L} IC=4.5
RL 2a 3 {RL}
C 3 3a {C} IC=18.2
RESR 3a 0 {RESR}
R 3 0 {R}
XSWITCH 1 0 2 PWM
********** AVERAGED SWITCH MODEL *******
.SUBCKT PWM A P C
GAP A X VALUE {D*I(VC)} ; controlled current source Dic
ECP X P VALUE={D*V(A,P)} ; controlled voltage source Dvap
VC X C 0 ; to measure ic for controlled current source
.ENDS
***************STEP CHANGE IN LOAD****************
RSTEP 5 0 4
SSTEP 3 5 20 0 SMOD
VCONT 20 0 PULSE(-1 1 2MS 1NS 1NS 10MS 20MS) ; change load resistance at 2ms
.MODEL SMOD VSWITCH(RON=.001 VON=.1 VOFF=-.1)
.END
**** 10/26/04 11:53:35 *********** Evaluation PSpice (Nov 1999) **************
**** Voltage Controlled Switch MODEL PARAMETERS
SMOD
RON 1.000000E-03
ROFF 1.000000E+06
VON .1
VOFF -.1
JOB CONCLUDED
TOTAL JOB TIME .02
1103791625.dat
.PARAM VS=50
.PARAM L=1MH
.PARAM RL=0.4
.PARAM C=100UF
.PARAM RESR=0.5
.PARAM R=4
.PARAM D=.4
.PROBE
.TRAN 10uS 6MS UIC
VS 1 0 {VS}
L 2 2a {L} IC=4.5
RL 2a 3 {RL}
C 3 3a {C} IC=18.2
RESR 3a 0 {RESR}
R 3 0 {R}
XSWITCH 1 0 2 PWM
.SUBCKT PWM A P C
.ENDS
RSTEP 5 0 4
SSTEP 3 5 20 0 SMOD
.END
SMOD
RON 1.000000E-03
ROFF 1.000000E+06
VON .1
VOFF -.1
JOB CONCLUDED
TOTAL JOB TIME .02
1103791625.dat
