全手工打做LED点阵屏_汉字的转动
先上几幅视频截图
全部回复(13)
截错屏了500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/55/1854061183682621.bmp');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/55/1854061183682633.bmp');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/55/1854061183682643.bmp');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/55/1854061183682653.bmp');}" onmousewheel="return imgzoom(this);">
@water1120211
截错屏了[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/55/1854061183682621.bmp');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/55/1854061183682633.bmp');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/55/1854061183682643.bmp');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/55/1854061183682653.bmp');}"onmousewheel="returnimgzoom(this);">
顶,支持!希望你能成为单片机高高手.
@water1120211
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/55/1854061183990178.jpg');}" onmousewheel="return imgzoom(this);">
@ghsdwf
精神可嘉!能否说说热转印制版是如何做的?哎,自己想搞点玩意,PCB成了大问题.热转印制版工序如何?材料是否易得?成本如何?学习中.
材料准备不复杂但是做得漂亮也不容易,特别是第一次,
首先准备一张热转印纸,热转印纸就是像贴纸相撕下来那层滑滑的纸,如果买不不到热转印纸(网上有邮购),就到广告公司那里向他们要那些做广告剩下来的的那些废纸也是行的
然后把PCB打印在热转印纸上(一定要用激光的,而且不是每台激光打印机都行的,并且打印这个极容易打坏你的打印机)
第三步是转印,把打印好纸固定在铜板上,用转热机过上两遍,如果没有热转印机就用熨斗加热转印也行(我是用熨斗的),建义把熨斗的温度调到"棉"或者"麻"
再就是让板子凉下来就可以撕掉那块纸了,要慢慢的撕,小习那个炭粉也撕掉了,如果有些线转印的不太理想就用油性笔补画在板子上
最后就能腐蚀了,我们一般用FECL3的,其它的没试过,所以不知道效果好不好.
如果想知道更多,可以加我入我的Q群:41562574
祝你成功!
祝你成功!
@water1120211
新屏预览
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/55/1854061184341697.bmp');}" onmousewheel="return imgzoom(this);">
照得不太好看,有空再照一个
照得不太好看,有空再照一个
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/78/2459211244011880.jpg');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/78/2459211244011898.jpg');}" onmousewheel="return imgzoom(this);">
买了个二手双色屏,不会玩,请师傅指点!
买了个二手双色屏,不会玩,请师傅指点!
@fgw0319
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/78/2459211244011880.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/78/2459211244011898.jpg');}"onmousewheel="returnimgzoom(this);">买了个二手双色屏,不会玩,请师傅指点!
红色绿色双色屏,5mm管径,尺寸483*240mm,32*64/F0.50
共32个74hc595,32个uln2803,32个ao4801,4个74hc138,4个74hc245
引脚说明:
R:红色输入;
CK:串行时钟(595、11脚);
ST: 寄存器时钟(595,12脚);
G: 绿色输入;
D: 译码器输入(138、4脚)
C: 译码器输入(138、3脚)
B: 译码器输入(138、2脚)
A: 译码器输入(138、1脚)
GND
引脚说明:
R:红色输入;
CK:串行时钟(595、11脚);
ST: 寄存器时钟(595,12脚);
G: 绿色输入;
D: 译码器输入(138、4脚)
C: 译码器输入(138、3脚)
B: 译码器输入(138、2脚)
A: 译码器输入(138、1脚)
GND
