寻求帮助有关开关电源IC资料翻译!
when the FB voltage is between 1.4 V and 0.5 V, the controller is commanding an excess of energy to be transferred to the load which in turn, drives the error higher and FB lower. When FB reaches 0.5 V, OUT pulses are terminated and do not resume until FB reaches 0.7 V. In this mode, the converter operates in hysteretic control with the OUT pulse terminated at a fixed CS voltage level of 0.4 V.
大XIA,在这句话中,drives the error higher and FB lower这段和the converter operates in hysteretic control with the OUT pulse terminated at a fixed CS voltage level of 0.4 V. 这句不知怎么译为妙,请赐教!
全部回复(0)
