1 Scope
This specification give data about power supply usable to charge 40 cells alcaline batteries(碱性电池).
2 Technical data
Power: 100w
Output voltage:65v+/-0.5v
Output current:1.5a+/-0.1a
Current ripple:<30%
Input voltage:90 to 132vac
Temperature range:-20℃ to +70℃
The power supply will be used as a current generator 30v until 65v.
The current load will be constant current or pulsed current with duration
0.1s and variable periods .
The current overshoot at beginning of pulse must be less than 0.03As.
The voltage overshoot must be less than 5v.
The output characteristics will be:
3 Standards
Safety compliant with UL,CSA and Telecom standard
EMC compliant with UL,CSA and Telecom standard
4 Protections
Protection against internal short-circuit
Protection against output short-circuit
Protection against wrong polarity
Protection against overheating
5 Plug
2 pins IEC 320 or 3 pins IEC320 connector
6 Output connector
To be confirmed
7 Dimensions
As small as possible :<35ⅹ75ⅹ130mm
