什么是可插式A型设备?什么是可插式B型设备?
按照电源连接方式分,什么是可插式A型设备?什么是可插式B型设备?
全部回复(2)
aaaabort
这个问题对于950来讲,看定义如下:
PLUGGABLE EQUIPMENT TYPE A
equipment that is intended for connection to a MAINS SUPPLY via a non-industrial plug and
socket-outlet or a non-industrial appliance coupler, or both.
PLUGGABLE EQUIPMENT TYPE B
equipment that is intended for connection to a MAINS SUPPLY via an industrial plug and socketoutlet
or an appliance coupler, or both, complying with IEC 60309 or with a comparable national standard.
从定义来看,一个是非工业用,一个是工业类用.
@aaaabort
这个问题对于950来讲,看定义如下:PLUGGABLEEQUIPMENTTYPEAequipmentthatisintendedforconnectiontoaMAINSSUPPLYviaanon-industrialplugandsocket-outletoranon-industrialappliancecoupler,orboth.PLUGGABLEEQUIPMENTTYPEBequipmentthatisintendedforconnectiontoaMAINSSUPPLYviaanindustrialplugandsocketoutletoranappliancecoupler,orboth,complyingwithIEC60309orwithacomparablenationalstandard.从定义来看,一个是非工业用,一个是工业类用.
right
