请问saber的环境变量SABER_DATA_PATH的值是多少,知道的麻烦告知一下
全部回复(4)
下面是关于环境变量SABER_DATA_PATH和AI_SC
模板和元件放在此环境变量定义的目录中,saber仿真引擎也是从这里找模板和元件信息的,在AI_SCH_PATH里找SYMBOL信息.另外SABER_DATA_PATH是一系列目录列表.任何用户自定义的库都应该在此变量中定义其DIRECTORY.在AI_SCH_PATH中定义其SYMBOL相应的目录.
Templates and components are found by the saber simulator using the SABER_DATA_PATH environment variable.
the SABER_DATA_PATH is a colon-separated list of directories.Any custom libraries intended for use by others
at your site should be stored in a directory that is part of SABER_DATA_PATH.
if such a directory does not exist.you should crete one and add its path to this variable.
How the Applications Find Files
1068788194.doc
1068788194.doc
@lzgjxh
下面是关于环境变量SABER_DATA_PATH和AI_SC模板和元件放在此环境变量定义的目录中,saber仿真引擎也是从这里找模板和元件信息的,在AI_SCH_PATH里找SYMBOL信息.另外SABER_DATA_PATH是一系列目录列表.任何用户自定义的库都应该在此变量中定义其DIRECTORY.在AI_SCH_PATH中定义其SYMBOL相应的目录.TemplatesandcomponentsarefoundbythesabersimulatorusingtheSABER_DATA_PATHenvironmentvariable.theSABER_DATA_PATHisacolon-separatedlistofdirectories.AnycustomlibrariesintendedforusebyothersatyoursiteshouldbestoredinadirectorythatispartofSABER_DATA_PATH.ifsuchadirectorydoesnotexist.youshouldcreteoneandadditspathtothisvariable.HowtheApplicationsFindFiles1068788194.doc
顶一个,说得好
