求助:如何才能得到DC5V?(+20)
最近我想做个控制板,我不想直接输入AC220V(市电), 如果输入是我们市电的火线的话,输出能不能得到DC5V?怎样才能得到呢?希望大家能提点建议.
全部回复(23)
自己顶一下,快沉了
shower
不明白,不就是AC-DC模块么
@shower
不明白,不就是AC-DC模块么
不可能就这样简单吧?AC-DC模块也得有AC输入吧,我这里只能用AC的火线输入,不知能行不?
hutushen
@241388
一根线?
@hutushen
一根线?
嗯,一进一出.
temp1234
@241388
嗯,一进一出.
Simply using a Current Xfer and plus diode, register, a buck cap. then using a low-droup regulator to obtain 5Vdc!
Thanks
temp1234
For power measurement? or power meter?
This way only can get small power, so your circuit should be very low power operation, and need good protection as the Power line (220VAC ) short!!
Good luck!!
Bye
tonfee
就单火线吗?没有零线?
@tonfee
就单火线吗?没有零线?
是的
tonfee
@241388
是的
不知道啊,搞不懂!
temp1234
Dear 241388,
The circuit is the same as aux-power in PFC stage!
@temp1234
Dear241388,Thecircuitisthesameasaux-powerinPFCstage!
Hello! Can send a your schematic diagram, I first do this, a little not too understands.
temp1234
@241388
Hello!Cansendayourschematicdiagram,Ifirstdothis,alittlenottoounderstands.
Sorry! I think you have to discuss this project with your boss.
I don't know how to post data to this BBS system!
So I can only give you some hints, so you need help form someone who can face to face discussion all technology issues with you! Because this project has a lot issues to be solved in the practice!
so, good luck!
@temp1234
Sorry!Ithinkyouhavetodiscussthisprojectwithyourboss.Idon'tknowhowtopostdatatothisBBSsystem!SoIcanonlygiveyousomehints,soyouneedhelpformsomeonewhocanfacetofacediscussionalltechnologyissueswithyou!Becausethisprojecthasalotissuestobesolvedinthepractice!so,goodluck!
If lets you make the technical support to us to be possible? Or is provides a good plan to me. Where person are you? Will speak Chinese? Keeps your contact method.
temp1234
@241388
Ifletsyoumakethetechnicalsupporttoustobepossible?Orisprovidesagoodplantome.Wherepersonareyou?WillspeakChinese?Keepsyourcontactmethod.
Sorry! I am not in China, Speak Chinese? Yes!
I don't have enough time to make technical support!
Try to find some one in your area, but this project is hard but very good for enhance you ability of power conversion!
Try your Peofessor!!
@temp1234
Sorry!IamnotinChina,SpeakChinese?Yes!Idon'thaveenoughtimetomaketechnicalsupport!Trytofindsomeoneinyourarea,butthisprojectishardbutverygoodforenhanceyouabilityofpowerconversion!TryyourPeofessor!!
已删
@temp1234
你每次都说英文
@太原艾亦特
你每次都说英文
一根火线做电源,那位外国朋友的意思是不是说“这是毫不可能的!”.一根线做电源,没有零线输入,电流从哪里入?
“目前还没有这个技术!“
Plexus 是一家新加坡代理商,在电信行业耕耘多年,目前我司代理了美国ZILKER Digital-DC 芯片解决方案,在此向您隆重推荐,本系列IC 搭配少数外部器件能够容易设计出,具有高效率、高可靠性、高稳定性等特点,输入从 3V-14V输出5V 到0.6V 6A 到60A 全系列非隔离同步整流并联多相控制模块,该产品具有PMBUS SMBUS 控制接口,是真正意义上的DIGITAL DC并且是 PMBus 规范 的定制者和倡导者,为电信新一代POL电源的稳定性和易使用性提供了可能.目前此标准正渐渐被电信电源所采用,台达、爱立信、泰科等都是我们的用户,华为目前也表示以后会有更多的设备采用.
当今的高级电子器件具有在不同电压涉及多个电压轨的复杂电源要求.ZILKER Labs 的digital DC 器件是唯一适用于解决这些复杂系统电源挑战的器件.Digital-DC IC 为高度整合的高性能数字电源解决方案,旨在成为可轻松加以结合并可适应要求的通用构建模块.ZILKER Labs 的digital DC 产品将世界一流的数字电源转换架构与电源管理逻辑完美结合在单块IC 中.他们需要最少的外部电路,从而简化了设计流程.DIGITAL DC 技术将智能内置到了硅片中,可使用户通过简单的引脚设定或使用电源管理总线(PMBus)命令轻松配置这些器件,无需进行编程,DIGITAL DC 产品适应众多工作情况,可使系统设计人员使用一个供应商的部件完成整个设计.
众所周之现在的电信电源要求很高,举例:
1 尤其是板载设备上会用到2到5个不同输出的电源,为了系统稳定需要不同的启动时间和上升斜率,精确的软启动和终止我们通过提前对PMBUS的编程 可以控制完成
2 多相并联,由于目前很多板载DDR3 用1V 电压会达到60A以上,为了提高可靠性,客户对动态调整率有很高的要求,我们通过多相和我们专利方法能够很好的完成是输出稳定达到客户要求.
3 控制功能 ,通过PMBUS 可以调节所要求的输出电流电压、启动时间、上升斜率等重要功能
4 监控通过PMBUS 可监控温度、电压、电压的行踪、电流、实现可编程过功率保护、电压保护、电流保护等功能
5 外围分立器件少,提高了可靠性,降低了成本.
以上特点能为用户提供高性能的解决方案,使用方便,维护实现网络化,省力省时是电源以后的必然趋势.
什么是 Digital-DC?
Digital-DC 是一种创新的混合信号电源转换与管理架构,其将高效的小型同步降压控制器、自适应驱动器以及关键电源与热管理功能结合到一个 IC 中.Digital-DC 器件还将 I2C/SMBus 硬件界面与全面服从 PMBus 规范相结合,其中包括支持 100 多个 PMBus 命令.
什么是 PMBusTM?
PMBus 是一种电源管理协议,可使用户通过 I2C 或 SMBus™ 硬件界面轻松配置及监控 DC-DC 转换器电路的各个方面.Digital-DC 器件支持 100 多个 PMBus 命令.有关 PMBus 规范及更多信息,请访问正式的 PMBus 网站:http://pmbus.org/.
Digital-DC 器件是否具有电压边限功能?
有.通过切换 MGN 针脚可限制 Digital-DC的输出边限.默认限制可设为 ±5%,但可使用 PMBus 命令可修改为低至 ±1% 或修改为高至 +10%/-100%.+10% 的边限为硬件限制,可防止敏感电路受到过压情况的影响.
Digital-DC 器件是否具有电压跟踪功能?
有.通过将以下器件的 VTRK 针脚连接到将被跟踪的输出,任何 Digital-DC 器件均可跟踪其他任何电源.跟踪可同时进行(仅在上升或下降过程中所有电压均相互跟踪),或可按比例进行(一个电压以特定百分比跟踪另一个电压).该比例默认为执行跟踪的器件按照 DDR 内存应用的要求以被跟踪电压的 50% 进行跟踪.可使用分压器修改该比例.
您能否在不修改硬件的情况下重新配置用于跟踪的部件或按照其自身目标进行调节?
可以,所有 Digital-DC 部件均可使用简单的 PMBus 命令加以修改,使其在以特定百分比跟踪另一个电压或以自身目标电压进行调节之间变化.如果将必要的跟踪输入电压连接结合到板设计中,则无需进行硬件更改.ZL2105 可作为 VTT 终端电源,这样它可进行 50% 的跟踪(或 100% 跟踪)以及汲入/提供电流.
Digital-DC 器件是否具有系统监控功能?
有.Digital-DC 器件可监控各种输入和输出参数以及电源转换参数.可监控的部分参数列表包括输入电压、输出电压、输出电流、内部温度、外部器件温度、开关频率、占空比、MOSFET 停滞时间及风扇速度.如欲索取可监控的完整参数列表,请与工厂联系.
ZL2005 产品介绍:
具有驱动器及POLA/DOSA 调节的Digital-DC 同步降压 DC-DC 控制器,它是一款创新的数字电源转换管理IC 6*6mm QFN 封装
应用:电信设备、存储设备、高密度服务器、FPGA DSP ASIC 电源DDR内存电源
电源转换特性:
●    具有自适应MOSFET 驱动的同步降压控制器
●使用引脚带或电阻连接的简单器件配置
●VADJ引脚可使用业界标准方法配置输出电压
●兼容PTH08T220/T240(16A/10A)电源模块
●DOSA第二代12A/20A 电源模块
●自适应死区时间控制
●±1%输出电压精度
●200K-1.4Mhz
●支持时钟同步与相位交叉
●到预偏压负载的软启动
电源管理特性:
●集成电源管理
●正常、比例跟踪
●通电断电排序
●电压边限
●电压电流监控
●内部外部临时监控
●完善的故障管理
●用于存储定制配置的片上非易失性内存(NVM)
ZL2105 产品介绍:
Digital-DC 3A 同步降压直流到直流转换器
6*6MM size 36-lead QFN
应用 电信设备、存储设备、高密度服务器、测试测量设备、工业控制设备
电源特性:
◇高达3A 的输出电流
◇整合的功率MOSFET 开关
◇输入电压介于4.5V-14V
◇输出电压介于0.6V-5.5V
◇±1% 的输出电压精度
◇200KHZ -2Mhz 的开关频率
◇支持相交错
◇更少的分离元件
电源管理特性:
◇可轻松配置,无需编程
◇精确的数字软启动、终止
◇电源安全、启用
◇电压跟踪、排序及边限
◇I2C/SMBUS 通信总线
◇符合PMBUS 规范
◇输出电压电流监控
◇热监控与关断
◇与其他digital DC 器件的无缝兼容
ZL2106 产品介绍:
Digital-DC 6A 同步降压直流到直流转换器
电源特性和电源管理特性同上
谢谢您我的介绍完了,希望本产品对贵公司产品的质量和功能提升有帮助,或是能够为贵公司降低成本有帮助.
如有问题或是需要请按以下地址电话联系我,再次感谢您!
佰丽思国际贸易上海有限公司
李恒一 hy.lee
技术市场部FAE主管
上海大连路990号海上海新城10号楼1002室
邮编:200092
电话:021-51692828-819
     13524698341
传真:021-33772878
E-MAIL: hy.lee@plexus-group.com.cn
真搞不明白你是不是学电的?一根线,,,,,,怎么可能?
@到处看看
你还真说对了,我还真不是学电的,请问高手是学啥的?
@241388
是不是你的叙述有问题?一进一出就不能叫一根线!??你的原意是否利用电流取出电压??首先要有足够的电流强度(还要看你的负载情况)!!你也看到了我是学徒!不到之处请见谅?
@到处看看
我是说真的,是没学过,后来有人带我出来的.是我叙述的问题,不过这个我都解决拉.谢谢你的关注
