2:增加补偿电容C?
3:输出线圈反了,同名端如下图
4:匝数有误,按你现在的规格VCC=19.16V,Vout=45.7V
4.1:Nout改为11Ts,则Vout=35.8V,但是此时反射电压150V,加上漏感可能超过210V,主开关管耐压没有余量.
4.2:Nb为9Ts,Nout为16Ts,则Vout=34.6V,此时反射电压为100V.
![](http://u.dianyuan.com/bbs/u/26/1108923306.gif)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/26/1108923306.gif');}" onmousewheel="return imgzoom(this);">
