跨接在产品输入的LN之间的压敏电阻,此压敏电阻已经过了VDE,UL认证.
我们的L,N没有加保险的
请教DX们,这样要短路吗?
求教各位大虾:压敏电阻需要做短路测试吗
全部回复(13)
@lovelhy
怎么没人顶呢
我来顶顶!!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/65/1837631210935328.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/65/1837631210935360.jpg');}" onmousewheel="return imgzoom(this);">
@cafetea
压敏电阻是非线性元件,如果长期挂在LN之间,可能会因逐渐老化而失效(表现为短路状态).因此,在压敏电阻前最好放保险管.压敏的老化是材料本身特性,和VDE或UL认证没有关系.
保险管选择250 10A的,过流时熔断,防止燃烧.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/65/1837631211033985.jpg');}" onmousewheel="return imgzoom(this);">
@ljjwhut
压敏电阻要做短路测试的,所以压敏电阻最好放在保险丝之后.
L/N之间的surge arrestor 在IEC 60950-1里面叫functional insulation.
fuse一般是管总的电路的,在L线或N线上,而surge arrestor一般是并联在L/N间,
标准上说:an interrupting means having an adequate breaking capacity shall be connected in series with the VDR.
这个中断装置是直接与VDR串联的,可以是discharge tube 或者thermal cut-out等.因为:
NOTE 2 During the lifetime of a VDR the leakage current incrases with the number of switching cycles in the VDR. this leakage current causes a permanent and continuously incrasing temperature strss, which can cause the VDR to burn or burst.
