来讨论下效率
怎样确定我们做的电源效率呢?或者说我们怎么样来根据效率来选所需要的线路呢?高手指点一下.
全部回复(10)
@temp1234
DearLZ,efficiency=Inputpower/outputpower,soonlymeasurementcanmakesureyourefficiency!Fornextquestion?Isay"efficiencyisonlysmallfactorforcircuitselection!!".
I think I am uncertain, choice of circuit determine working way their just, but decision of efficiency is it lean against their design means and quality of the part determine to a great extent to have
@janysophia
那效率怎么说呢?难道跟说选的线路没什么关系吗?
In gemerally knowledge, Flyback has highest efficiency in high-voltage/10W level. Forward has highest effiecncy in low voltage/100W level. Half-Bridge is best for high-voltage/ 100Wlevel. Full-Bridge is best choice for Kilo-Watts! So the other key factors are more important, such as MTBF, Size, and personal ability!
@temp1234
Ingemerallyknowledge,Flybackhashighestefficiencyinhigh-voltage/10Wlevel.Forwardhashighesteffiecncyinlowvoltage/100Wlevel.Half-Bridgeisbestforhigh-voltage/100Wlevel.Full-BridgeisbestchoiceforKilo-Watts!Sotheotherkeyfactorsaremoreimportant,suchasMTBF,Size,andpersonalability!
Yes, I agree to”temp1234 “statement.. Every kind of circuit wants its pluses and minuses. Their power limits the range too.
Unless but it is the real the important, it can only consult..
@temp1234
why half-Bridge is best for high-voltage/ 100Wlevel
is it very diffent from full-bridge in low powe rang
@humburge
why half-Bridgeisbestforhigh-voltage/100Wlevelisitverydiffentfromfull-bridgeinlowpowerang
IN two-ends topologies, the output stage needs only half withstand-voltage of the signle-end topologies! And for 100Ws, the FB is a little bit too complex! So it is depends, you know one topology better then it will dominate more, and your ability is higher then the power-range will extend more!!
