请问 这款电源用什么方案做,用什么IC,请看下面 SPEC !!!
1. Input
1.1 Input voltage: 100-240VAC Type, Max operates range at 85- 264Vac.
1.2 Frequency Range 50-60Hz Type
1.3 Primary current: 0.3A max
1.4 Idle state input power 0.5W max
1.5 Inrush current <37A @264 V AC input.
2. Output
2.1 Output Voltage: 5V & 24.0V
2.2 Output Loading: 0-1A @ 5V, 0-0.2A @ 24V
2.3 Tolerance: +/-5% @ 5V & 24V
2.4 Ripple & Noise (Vp-p): < 1% of rated output voltage.
Note: The measurement for differential ripple and noise the output will be using oscilloscope, with 20MHz bandwidth. A 10uF electrolytic capacitor and a 0.1uF ceramic capacitor should be parallel with output load.
3. General characteristics
3.1 Efficiency: >82% @ AC100-240V full load.
3.2 Protection function:
3.2.1 Output short circuit protection auto-recovery
3.2.2 Output over voltage protection 6.8V max @ 5V output and 32V max @ 24V output (auto recovery)
3.2.3 Over temperature protection 88-100℃ Component temperature
auto-recovery
3.2.4 Output over current protection 1.1-1.3A at 5V output and 0.25-0.35A at 24V output auto-recovery during input AC100-240V, Output full load estate.
3.2.5 Input under voltage lockout (UVLO) Under 40-- 60 V AC
4. Hi-pot
4.1 Input to output 3000 V AC 50Hz for leakage 5mA at 1 minute.
4.2 Input to case 3000 V AC 50Hz for leakage 5mA at 1 minute.
全部回复(4)
普通的反激就行了呗,FSD210就可以办了,SPEC方案好像只能用在非隔离电路上
samsonsu
@buhuichongfu
有什么好的方按
到时 我联系你 ,,,
samsonsu
@samsonsu
有什么好的方按到时我联系你,,,
我要做10W 和15W 呢... 有两路输出..
各位老兄 ,,有什么好建议 有什么IC 是最合适的
请推荐下了..
samsonsu
@samsonsu
我要做10W和15W呢...有两路输出..各位老兄,,有什么好建议有什么IC是最合适的请推荐下了..
efficiency can meet specification 82% ?
any suggestions on it ?
