![](http://img.mydigit.net/Mon_1801/148_2228550_69ac94c0b1007e8.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
先看下外表吧 体积(高?宽?深) 132mm?86mm?330mm 重量 3kg
![](http://img.mydigit.net/Mon_1801/148_2228550_798b55534f7b806.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
侧面
![](http://img.mydigit.net/Mon_1801/148_2228550_d1bbcadef5c6cad.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
![](http://img.mydigit.net/Mon_1801/148_2228550_8266f499bf8924c.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
![](http://img.mydigit.net/Mon_1801/148_2228550_cc75bd1ff24e55f.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
尾部图片
![](http://img.mydigit.net/Mon_1801/148_2228550_4ce3c001d7d48bc.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
底部可安装脚垫
![](http://img.mydigit.net/Mon_1801/148_2228550_07f647726993236.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
内部图片 线是改装我焊上去的
![](http://img.mydigit.net/Mon_1801/148_2228550_09942ecbb2cd1ed.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
加工面板 量好数码管尺寸 从第二个灯孔右边用小刀划好界限 多划几次基本可以有很深的划痕了 开孔先开稍微小一点的 用小刀或锉刀加工边缘部分 达到与表头数码管吻合 有铣床的就更加好加工了 顺便吧内框底部的菱角剪平 接线柱用的尺寸是4.3总高 螺丝直径6mm的 用小钻即可开孔固定
![](http://img.mydigit.net/Mon_1801/148_2228550_29e355b60babbfd.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
![](http://img.mydigit.net/Mon_1801/148_2228550_8182d292109828a.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
![](http://img.mydigit.net/Mon_1801/148_2228550_a95a9e1e35f00f3.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
安装表头后 PCB边往下可以刚好装下风扇
![](http://img.mydigit.net/Mon_1801/148_2228550_e0a2f69eb98654d.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
加工网罩 对应位置开槽
![](http://img.mydigit.net/Mon_1801/148_2228550_9d170847cbfdb8d.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
网罩要保留一个卡扣
![](http://img.mydigit.net/Mon_1801/148_2228550_cc99704395f42e5.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
慢工出细活吧
![](http://img.mydigit.net/Mon_1801/148_2228550_45375b73da8e707.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
擦拭一下
![](http://img.mydigit.net/Mon_1801/148_2228550_32a4a346931979a.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
焊接固定螺丝柱 锰铜线表头连线等
并联四根锰铜线代替分流器
![](http://img.mydigit.net/Mon_1801/148_2228550_1fbfbd067f183f7.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
![](http://img.mydigit.net/Mon_1801/148_2228550_37876d9d1889bec.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
可以根据自己喜爱调整接线柱的位置 或焊接难易度调整接线柱位置 锰铜线可先少加锡焊接 后期调整电流表再适当加锡 初步焊锡位置在卡扣以外
建议使用硬实心6平方铜线 焊接比较精准简单 软线在这里焊接时候不好把握焊接点
组装电位器
开孔为11mm直径 可以安装3590电位器至根部 开孔不够大可能导致安装不到位 致使电位器不平或组装面板时电位器超出面板2mm左右
![](http://img.mydigit.net/Mon_1801/148_2228550_5c36dbbb09f6d7d.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
引线 有孔位可以放好引出DC线
![](http://img.mydigit.net/Mon_1801/148_2228550_0ea4fb989c450f5.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
建议使用6平方实心铜线
![](http://img.mydigit.net/Mon_1801/148_2228550_9f2a4a1c468c95c.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
加工尾部 原来的剪去黑色座子 黑色座子是两块压合在一起的 可以剪掉一半
![](http://img.mydigit.net/Mon_1801/148_2228550_c9cde149189c90c.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
剪掉后
另外剪掉DC端子 再点掉一点黑胶座 焊线不会凸起
不凸起后可以用塑胶板粘在那里 比较美观安全
![](http://img.mydigit.net/Mon_1801/148_2228550_05bd66e8a898dd7.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
加工铝合金外壳
![](http://img.mydigit.net/Mon_1801/148_2228550_1f2393a4fd68b08.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
剪后
![](http://img.mydigit.net/Mon_1801/148_2228550_a516f71861139ce.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
组装风扇前 需先固定面板与机体上 此时需要固定好铝合金外壳先
组装风扇可将接头塞进上面 这样线不会被风扇压住 可以让面板尽量往里面压进去一点
![](http://img.mydigit.net/Mon_1801/148_2228550_7dc4eccdf43dfc5.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
电流可以固定柱最大值 根据需要DIY吧 由于滤波电容耐压最大80V 故输出调至65V吧
低电压电流还是美中不足吧 12V10A 20V14A 24V17A 30V20A 36V22A 36V以上可以满载25A或30A 60V20A 63V19A 65V9A 没有专业仪器 可能有小误差
由于技术有限 希望坛友交流一起研究吧 有需要的朋友来本店吧:淘爱的小屋淘爱的小屋
![](http://img.mydigit.net/Mon_1801/148_2228550_6221ebb71b85c0e.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
![](http://img.mydigit.net/Mon_1801/148_2228550_3fb50351647630e.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
![](http://img.mydigit.net/Mon_1801/148_2228550_7e41cfabc98158d.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
