OB2005WKCP SOP8, OB2005WKCPA SOP8, OB2005VKCP SOP8, OB2005VKCPA SOP8, OB2005ZKCP SOP8, OB2005ZKCPA SOP8,
OB2005WKCP SOP8, Halogen-free in Tube
OB2005WKCPA SOP8, Halogen-free in T&R
OB2005VKCP SOP8, Halogen-free in Tube
OB2005VKCPA SOP8, Halogen-free in T&R
OB2005ZKCP SOP8, Halogen-free in Tube
OB2005ZKCPA SOP8, Halogen-free in T&R
GENERAL DESCRIPTION
OB2005
Shenzhen city core beauty technology co., LTD
General description of the
OB2005xK is high-performance and tightlyIntegrated secondary side synchronous rectifierSwitch mode power supply system. It is a combination of aA lower voltage drop n-channel MOSFETImitating the traditional diode rectifierReturn the secondary side converter, it can beReduce the heat, increase the output currentCapacity and efficiency and simplify the heatDesign. OB2005xK can support lower the system outputThe voltage drop to 2 v in constant current mode.Suitable for multiple model applicationIncluding the discontinuous conduction mode,Quasi resonant mode. Its versatility andOptimization, OB2005xK can be used in a variety ofSwitching power supply topology including modeSecondary side control topology and primary sideControl topology.From the secondary side informationGenerate an isolation transformer, OB2005xKDrive signal and the time of deathWill integrate Ncha primary side PWM signal
深圳市芯美力科技有限公司
般的描述  
OB2005xK是高性能和紧密  集成二次侧同步整流器  开关模式电源系统。它结合了一个  更低的电压降n沟道MOSFET  模仿传统的二极管整流器  二次侧的回程的转换器,它可以  减少散热,增加输出电流  能力和效率和简化热  设计。OB2005xK可以支持较低的系统输出  电压降至2 v在恒流模式。  适用于多个模式应用程序  包括不连续导电模式,  准谐振模式。它的多功能性和  优化,OB2005xK可用于各种  开关电源拓扑结构包括模式  二次侧控制拓扑和主面  控制拓扑。  从信息的二次侧  隔离变压器,OB2005xK生成一个  驱动信号与死亡时间的  将集成Ncha主面PWM信号
OB2500
深圳市芯美力科技有限公司
 元器件首选供应商家
 上百家原厂渠道合作
  诚  信  合  作
全部回复(0)
