Processing Rule : Hole Size Constraint (Min=0.0254mm) (Max=2.54mm) (On the board )
Rule Violations :0
Processing Rule : Width Constraint (Min=0.254mm) (Max=0.254mm) (Prefered=0.254mm) (On the board )
Violation Track (283.464mm,162.56mm)(287.02mm,166.116mm) TopLayer Actual Width = 1mm
Violation Track (281.94mm,192.532mm)(281.94mm,206.756mm) TopLayer Actual Width = 1mm
Violation Track (281.94mm,206.756mm)(293.116mm,206.756mm) TopLayer Actual Width = 1mm
Violation Track (271.272mm,206.756mm)(281.94mm,206.756mm) TopLayer Actual Width = 1mm
Violation Track (271.272mm,167.64mm)(284.48mm,180.848mm) TopLayer Actual Width = 1mm
Violation Track (284.48mm,180.848mm)(284.48mm,192.532mm) TopLayer Actual Width = 1mm
Violation Track (251.46mm,172.72mm)(266.192mm,172.72mm) TopLayer Actual Width = 1mm
Violation Track (266.192mm,172.72mm)(271.272mm,167.64mm) TopLayer Actual Width = 1mm
Violation Track (253.492mm,212.344mm)(265.684mm,212.344mm) TopLayer Actual Width = 1mm
Violation Track (265.684mm,212.344mm)(271.272mm,206.756mm) TopLayer Actual Width = 1mm
Violation Track (293.116mm,206.756mm)(295.656mm,209.296mm) TopLayer Actual Width = 1mm
Violation Track (283.464mm,158.496mm)(283.464mm,162.56mm) TopLayer Actual Width = 1mm
Violation Track (287.02mm,166.116mm)(296.164mm,166.116mm) TopLayer Actual Width = 1mm
Violation Track (251.46mm,162.56mm)(271.272mm,162.56mm) TopLayer Actual Width = 1mm
Violation Track (253.492mm,202.184mm)(270.764mm,202.184mm) TopLayer Actual Width = 1mm
Violation Track (281.94mm,182.88mm)(281.94mm,192.532mm) BottomLayer Actual Width = 1mm
Violation Track (277.622mm,156.21mm)(282.194mm,156.21mm) BottomLayer Actual Width = 1mm
Violation Track (283.464mm,158.496mm)(283.464mm,181.356mm) BottomLayer Actual Width = 1mm
Violation Track (283.464mm,157.48mm)(283.464mm,158.496mm) BottomLayer Actual Width = 1mm
Violation Track (295.656mm,201.168mm)(295.656mm,204.216mm) BottomLayer Actual Width = 1mm
Violation Track (287.02mm,192.532mm)(295.656mm,201.168mm) BottomLayer Actual Width = 1mm
Violation Track (286.004mm,158.496mm)(286.004mm,161.036mm) BottomLayer Actual Width = 1mm
Violation Track (286.004mm,161.036mm)(296.164mm,171.196mm) BottomLayer Actual Width = 1mm
Violation Track (281.94mm,182.88mm)(283.464mm,181.356mm) BottomLayer Actual Width = 1mm
Violation Track (282.194mm,156.21mm)(283.464mm,157.48mm) BottomLayer Actual Width = 1mm
Violation Track (271.272mm,162.56mm)(277.622mm,156.21mm) BottomLayer Actual Width = 1mm
Violation Track (271.272mm,171.958mm)(271.272mm,201.676mm) BottomLayer Actual Width = 1mm
Violation Track (271.272mm,171.958mm)(280.924mm,162.306mm) BottomLayer Actual Width = 1mm
Violation Track (280.924mm,158.496mm)(280.924mm,162.306mm) BottomLayer Actual Width = 1mm
我划完板子进行DRC检查时出现的问题,,我新手,,就是把板子的电源线变粗了,,请问这些问题是可以不计的不??还是这些东西是错误,,必须修改,..我个人认为是可以忽视的..也就是板子本来是正确的,,是不是??还请权威解答
这是错误还是什么
全部回复(28)
Actual Width = 1mm
上面的意思是你的规则设置画线的时候最小是0.254mm最大也是0.254mm(一般这种设置是系统默认的规则),而你手动改动了已经画好的线条(就是把板子的电源线变粗了),你手动的线条和你规则设置的线条大小有冲突,不过没关系的,这不影响你线路的正确性.
你可能还不懂规则设置,规则设置作用很大,特别是在自动布线时很重要,你一定要懂一些规则设置,有空我把具体操作在贴上来...
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/69/254041221034107.gif');}" onmousewheel="return imgzoom(this);">
Actual Width = 1mm
![](http://u.dianyuan.com/bbs/u/69/254041221034107.gif)
@fzhlpp
(Min=0.254mm)(Max=0.254mm)ActualWidth=1mm上面的意思是你的规则设置画线的时候最小是0.254mm最大也是0.254mm(一般这种设置是系统默认的规则),而你手动改动了已经画好的线条(就是把板子的电源线变粗了),你手动的线条和你规则设置的线条大小有冲突,不过没关系的,这不影响你线路的正确性.你可能还不懂规则设置,规则设置作用很大,特别是在自动布线时很重要,你一定要懂一些规则设置,有空我把具体操作在贴上来...[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/69/254041221034107.gif');}"onmousewheel="returnimgzoom(this);">
多谢回答,,最后一个关键问题,,尽管出现了我所搞的那种报警,,我把这个带报警的板子到厂家去做,,可以通过不??也就是我让这个报警存在,,然后到厂里做板子,,仍然是正确的不??是或者不是?请高手选择
@zhuzhouren
请高手选择:1.仍然是正确的2.有问题,,必须修改,,否则别人做不出来哪个
呵呵,我选1
你的报警提醒你目前实际的布线和你规则里设定的布线规则有冲突,比如你规则里线条和线条之间的距离设定成0.7mm,而你画好的板子上的线条和线条之间有小于0.7的距离那么系统就要报警.比如你规则里线条宽度设定成最大和最小都是0.254mm(一般默认),而你画好的板子上的线条宽度有大于或小于0.254的那么系统就要报警,但是线路板厂家是可以做的出来的,只要线条宽度和线条之间的间距不要太小,一般0.254mm都可以做,做不出的或做不好的那么说明这家做线路板的工艺太落后了.
@fzhlpp
呵呵,我选1你的报警提醒你目前实际的布线和你规则里设定的布线规则有冲突,比如你规则里线条和线条之间的距离设定成0.7mm,而你画好的板子上的线条和线条之间有小于0.7的距离那么系统就要报警.比如你规则里线条宽度设定成最大和最小都是0.254mm(一般默认),而你画好的板子上的线条宽度有大于或小于0.254的那么系统就要报警,但是线路板厂家是可以做的出来的,只要线条宽度和线条之间的间距不要太小,一般0.254mm都可以做,做不出的或做不好的那么说明这家做线路板的工艺太落后了.
下面是规则设置的步骤:
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/69/254041221098474.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/69/254041221098711.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/69/254041221099122.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/69/254041221099360.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/69/254041221099482.gif');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/69/254041221098474.gif)
![](http://u.dianyuan.com/bbs/u/69/254041221098711.gif)
![](http://u.dianyuan.com/bbs/u/69/254041221099122.gif)
![](http://u.dianyuan.com/bbs/u/69/254041221099360.gif)
![](http://u.dianyuan.com/bbs/u/69/254041221099482.gif)
精华推荐 换一换
