OB3375 昂宝降压型准谐振DCDC驱动芯片
OB3375 昂宝降压型准谐振DCDC驱动芯片,OB3375CPA 高性价比,宽输入、输出电压范围,高效率、低系统成本,优异电磁兼容性,多种MOSFET内置驱动芯片。OB3375 OB3375CPA-H OB3375PCP-E 系列型号。OB3375 采用峰值电流模式以满足宽输入、输出电压范围,从而达到高效率、低系统成本及很好的电磁兼容性。OB3375支持PWM调光和PWM转模拟调光两种调光模式,可以轻松达到1%~100%的调光范围;同时提供完善的保护功能,包括:LED开路保护、LED短路保护、LED负对地短路保护、降压驱动电感/二极管短路保护、降压驱动MOSFET短路保护、芯片过温保护等。在驱动发生异常时,OB3375在自身可靠保护的同时,提供异常输出信号告知前级ACDC电源,保证电源系统的可靠性。OB3375也有MOSFET内置驱动芯片,包含100V/150V/200V多种MOSFET规格,可以驱动32寸~65寸TV,进一步节省了PCB空间,降低系统成本。
驱动芯片供应:0755-82584090、134 1845 9109(微信同号)力索 微电子.
OB3375CPA-H OB3375PCP-E OB3398PAP OB3398TAP OB3398EPAP OB3398VAP-H OB3398PJPA OB3398TJPA-H OB3639CPA OB3639ACPA OB5269CPA OB5269BCPA OB2262MP OB3397MEP OB3619AMP OB3619CMP OB3635ENCPA OB5682MMKP-H OB5682MWUP-H OB5682PASP OB2368MP OB3330XCPA OB3331CPA OB3652PAP OB2500CPA OB2500POPA OB2560MP OB2560CMP OB2550MP OB2550QMP SN03ACP OB3600PJPA-J OB5628AJPA OB3639ACP OB3639CP OB6566LMP OB6566MP OB2533CPA OB5682NJPA-H OB5682PASP OB5682TASP OB5682MMKP-H OB5682PJPA OB6561PAP OB3398HTAP OB2288CPA OB6563AP OB3330XCPA OB3331CPA OB3652PAP SN03AAP OB2210MP OBGZ25CPA OB2222MCPA OB3399PAP OB3399TAP OB3399MP OB2226AP OB2372CPA OB2225NCPA OB2230CPA OB3330XCPA OB2263MP OB2223FAP OB2223CPA  OB2223KCPA OB2223FCPA OB2263MP OB2281AMP OB2281MP OB2361MP OB2362AMP OB25163JPA OB2365TAP-H OB25136BCPA  OB2535CPA OB233FBAP  OB3613YCPA  SM11N65EQP  SM4N65EQP SM4N70EIPA OB2222MCPA OB2263MP  OB2273AMP OB2281AMP OB2362AMP OB2576ATCPA OB2571LTCPA-H OB2576TCPA OB2571ATCPA-H OB2576ATCPA OB2571PCPA OB5269CPA OB5269BCPA OB5282CPA OB5282ACPA OB5283CPA OB6561PXCPA OB2576AMP OB2576MP  OB2576TCPA OB2576ATCPA OB2576BTCPA OB2576PCPA OB2576APCPA OB2576BPCPA OB2576CPCPA OB2576DPCPA OB2576EPCPA OB2576FPCPA OB2576GPCPAOB2576TCPA OB2576AMP OB2576MP OB2576TCPA OB2576ATCPA OB2576BTCPA OB6683CGPA OB2273MP OB2273AMP OB2273BMP OB2273CMP OB3619ETJPA-H OB3619CMP OB2550MP OB2550QMP OB2576PCPA OB2235NCPA-H OB3332PCPA-J OB3635ETCPA  OB3600CPA  OB3332BRCPA-H OB3652MCPA 可提供产品资料,应用方案,欢迎交流。
全部回复(0)
