118/000293 UV-C BALLAST 9 W PL
Input : 230V / ~50Hz 0,17A
Cable prim.: Type: H05 RN-F 3 x 0,75 mm²
Length: 1,0m Schuko plug splash proof IP44
Cable sek.: Type: H05 RN-F 3 x 0,75 mm²
Length: 5,0m 70 mm jacket removed
10 mm not insulated and solder-coated
Housing: Dimensions: 154 x 63 x 58 mm, with bottom plate, complete potted with epoxy
For UV-C lamp Type: PL-S 9W
如果有这类产品的 请联系我 童诚 13586876118
