margining在开关电源里是什么参数啊
还有overall reg
adjustment range
全部回复(6)
@jack.sparrow
Adjustmentrange ±10%minimumalloutput ±10%Margining ±4-6%nominal实际值的±4-6%Overallreg 0.4%or20mVmaximum(36Wmodules$%maximum)关键是这三个参数都代表什么含义啊,我附上参数具体内容了
Adjustment range ±10% minimum all output ±10%
****就是调节范围为+/-%, 比如说normal value is 10v ,min is 9V ,max is 11V.
Margining ±4-6% nominal 实际值的±4-6%
****叫做余量,如比说客户要求值是9~11V, 其余量为9*0.94%~11*1.06%
