型号:NY8A050D
封装:23-6 SOP-8
多数应用于小风扇,玩具,简易遥控,喇叭,性价比超高
NY8A050D例程有汇编版本,有C语言版本,可以联系我索取
NY8A050D包含以下例程源码
NY8A050D例程:Checksum
NY8A050D例程:External lnterrupt_Level Change
NY8A050D例程:InterruptGPIOGPIO_Direct lnput
NY8A050D例程:GPIO_LED Pattern
NY8A050D例程:GPIO_Matrix lnput
NY8A050D例程:GPIO_Running LED
NY8A050D例程:GPIO_Running LED_Table
NY8A050D例程:Rolling Code_Custom
NY8A050D例程:Rolling Code_Preset
NY8A050D例程:sleep_WakeupTimer lnterrupt
资料:点击直接下载 NY8A050D_V1.2_PDF
型号:NY8A051D
封装:23-6 SOP-8
050D升级款,适合新手练习,带38k红外输出,62.5K蜂鸣器输出
资料:点击直接下载 NY8A051D_V1.4_PDF
NY8A051D例程有汇编版本,有C语言版本,可以联系我索取
NY8A051D例程:Checksum
NY8A051D例程:External Interrupt_Level Change Interrupt
NY8A051D例程:GPIO
NY8A051D例程:GPIO_Direct lnput
NY8A051D例程:GPIO_LED Pattern
NY8A051D例程:GPIO_Matrix Input
NY8A051D例程:GPIO_Running LED
NY8A051D例程:GPIO_Running LED_Table
NY8A051D例程:Mix Assembly
NY8A051D例程:PWM Output
NY8A051D例程:Rolling Code_custom
NY8A051D例程:Rolling Code_Preset
NY8A051D例程:Sleep_Wakeup
NY8A051D例程:special lO Function
NY8A051D例程:Timer Interrupt_WDT Interrupt
型号:NY8A051F
封装:23-6 SOP-8
NY8A051F是NY8A051D升级款,性能更加卓越,带38k红外输出,62.5K蜂鸣器输出,带11路LVD
NY8A051F例程:Checksum
NY8A051F例程:External Interrupt_Level Change Interrupt
NY8A051F例程:GPIO
NY8A051F例程:GPIO_Direct lnput
NY8A051F例程:GPIO_LED Pattern
NY8A051F例程:GPIO_Matrix InputI
NY8A051F例程:GPIO_Running LED
NY8A051F例程:GPIO_Running LED_Table
NY8A051F例程:LVD
NY8A051F例程:Mix Assembly
NY8A051F例程:PWM Output
NY8A051F例程:Rolling Code_Custom
NY8A051F例程:Rolling Code_Presetsleep_Wakeup
NY8A051F例程:Special lO Function
NY8A051F例程:Timer lnterrupt_WDT Interrupt
资料:点击直接下载 NY8A051F_V1.5_PDF
如果有想自己学习的,以上三款最适合九齐的学习入门,基本上搞定了这三款,小风扇,台灯,小玩具,遥控各种带电池的简单单片机应用都能搞定。
另外九齐的NY8A05系列还包含以下型号,都是有汇编和C语言的例程,性价比最高的就是上面列举的三个,如果需要14-16Pin,和内存需要到2K ,那就要选择054系列了,带AD就需要选择NY8B系列,例如NYB062D另外的帖子单独写出来。
带EEPROM就是NY8AE051D和NY8AE051F这两个是支持掉电记忆的,也是可以反复烧录的,另外的帖子单独介绍
NY8A050D
NY8A051B
NY8A051D
NY8A051E
NY8A051F
NY8A051G
NY8A051H
NY8A053B
NY8A053D
NY8A053E
NY8A054A
NY8A054D
NY8A054E
NY8A056A
如果您还没有接触这个品牌的单片机,又想学习,建议您准备两个硬件,一个是
1:NY8-OTP_Writer 烧录器 (大概400左右)
2:NY8_ADC/COM_COB (大概450左右)
深圳市双宜科技有限公司成立于2012年,我们提供一站式产品服务,方案设计,PCB设计,元器件配套。
有任何问题欢迎联系我们
电话:13823527686(微信同号)
联系人:倪先生
联系我时,请注明是电源网看到联系方式
