我有一款环型变压器,功率:990VA 初级220V铜线Ø1.2MM 485T 次级有4组:52X2(8.7A) 铜线Ø1.6MM 115T 18X2(1.5A)铜线Ø0.69MM 40T 11X2(1.2A)铜线Ø0.59MM 24T 5V(1A)铜线Ø0.55MM 11T 铁芯:75X70X110
三个小时温升试验150度, 请大家帮我分析一下,是什么问题?
环型变压器温升问题?
全部回复(10)
按你的要求铁心用小了,线用细了
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/72/659501228992662.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/72/659501228992662.jpg?x-oss-process=image/format,webp)
改用80-80/120铁心,线径圈数如下
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/72/659501228992808.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/72/659501228992808.jpg?x-oss-process=image/format,webp)
@风风
温升要求:90度,不知道次级线径1.6改成:1.68的,温升会不会下升
铁心尺寸与圈数不变,线径改变,温升也要超过100度
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/72/659501229092330.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/72/659501229092330.jpg?x-oss-process=image/format,webp)
