我需要一个电源板,用来驱动微型电机的.不需要任何保护不需要输出精确电压,装在密封盒子里,但启动次数与时间非常少,唯一要求是体积越小越好.但我先后用TOP257YN和TOP247YN在软件上设计了两套做了两个试验,功率都只能达到30%.变压器是专业生产商那定的,我采用三端模式,反馈环节省略了光藕,将4.7Ω电阻直接接在了控制引脚C上.省略了后级滤波电容、电感.请工程师们帮帮忙,给个方案~~谢谢!!
我的要求是220V市电输入195-255V 实际使用输出功率是24V 2.2A,只要求体积越小越好!
求助PI工程师!!!!!急
全部回复(5)
你好,你可以给我们联系啊.我们竭诚为你服务,给你全方位的技术支持!
电话:0755-27909184
手机:13534168067/吕 13480936839
QQ: 403336969
有用PI的朋友请看下面希望能给你有所帮助!
Product Description
DAK-16A AC-DC adapter
Output: 5.5 V @ 2.75 W
LinkSwitch
Samples and Complete Documentation
DAK-21A DC-DC converter
Output: 5 V @ 30 W
DPA-Switch
DAK-34 AC-DC power supply
Output: 12 V @ 30 W
TOPSwitch-GX
DAK-54 AC-DC adapter
LinkSwitch
DAK-68A PoE DC-DC Converter - Class 0
Output: 3.3 V @ 6.6 W
DPA-Switch
DAK-71A DC-DC Converter
DPA-Switch
DAK-85 AC-DC Linear Charger Replacement
Output: 6V @ 2 W
LinkSwitch-LP
DAK-89 AC-DC Adapter
Output: 6.2 V @ 2 W
LinkSwitch-XT
RDK-91 AC-DC Adapter
Output: 12 V @ 12 W
TinySwitch-III
DAK-93 AC-DC peak mode power supply
Output: 30 V @ 32 W continuous, 89 W peak (50 ms)
PeakSwitch
DAK-86 PoE DC-DC Converter - Class selectable
DPA-Switch
RDK-83 1.75 W CV Cordless Phone Adapter
85-265 VAC Input, 7.3 V, 240 mA Output
LinkSwitch-LP
RDK-131 LED Halogen Bulb Retrofit Kit
85-265 VAC Input, 3 W Output
LinkSwitch-TN
RDK-115 Multiple Output DVD, Set-top box Power Supply
Universal Input Voltage, 85-265 VAC Input, 7.5 W Output (13W Peak)
TinySwitch-PK
RDK-128 Variable Speed Motor Drive
90-265 VAC Input, 36 W Output (72W PeaK)
PeakSwitch
RDK-142 LCD Monitor Power Supply
90-265 VAC Input, 12 V, 2 A and 5V, 2.2A Outputs
TOPSwitch-HX
RDK-138 Non-Isolated, Dual Output Buck / Buck-Derived Power Supply
Output: 5 V, 12 V @ 1.2 W
LinkSwitch-TN
RDK-160 Three Low Power Chargers
5 V, 1 A / 5V, 700 mA / 6V, 300 mA
LinkSwitch-II
RDK-201 Constant Voltage (CV) Adapter
90 – 265 VAC Input; 5 V, 1.2 A Output
LinkSwitch-CV
Part Number Description Package
DPA422PN 10 W (36-75 VDC input) DIP-8
DPA422GN 10 W (36-75 VDC input) SMD-8
DPA422GN-TL 10 W (36-75 VDC input) SMD-8, T&R
DPA423PN 13 W (36-75 VDC input) DIP-8
DPA423GN 13 W (36-75 VDC input) SMD-8
DPA423GN-TL 13 W (36-75 VDC input) SMD-8, T&R
DPA423R 18 W (36 - 75 VDC input) TO-263
DPA423R-TL 18 W (36 - 75 VDC input) TO-263 T&R
DPA424PN 24 W (36-75 VDC input) DIP-8
DPA424GN 24 W (36-75 VDC input) SMD-8
DPA424GN-TL 24 W (36-75 VDC input) SMD-8, T&R
DPA424R 35 W (36 - 75 VDC input) TO-263
DPA424R-TL 35 W (36 - 75 VDC input) TO-263 T&R
DPA425PN 25.5 W (36-75 VDC input) DIP-8
DPA425GN 25.5 W (36-75 VDC input) SMD-8
DPA425GN-TL 25.5 W (36-75 VDC input) SMD-8, T&R
DPA425R 70 W (36 - 75 VDC input) TO-263
DPA425R-TL 70 W (36 - 75 VDC input) TO-263 T&R
DPA426R 100 W (36 - 75 VDC input) TO-263
DPA426R-TL 100 W (36 - 75 VDC input) TO-263 T&R
LNK302PN 63 mA (MDCM) 80 mA (CCM) DIP-8
LNK302GN 63 mA (MDCM) 80 mA (CCM) SMD-8
LNK302GN-TL 63 mA (MDCM) 80 mA (CCM) SMD-8 T&R
LNK302DN 63 mA (MDCM) 80 mA (CCM) SO-8
LNK302DN-TL 63 mA (MDCM) 80 mA (CCM) SO-8 T&R
LNK302DG 63 mA (MDCM) 80 mA (CCM) SO-8
LNK302DG-TL 63 mA (MDCM) 80 mA (CCM) SO-8 T&R
LNK304PN 120 mA (MDCM) 170 mA (CCM) DIP-8
LNK304GN 120 mA (MDCM) 170 mA (CCM) SMD-8
LNK304GN-TL 120 mA (MDCM) 170 mA (CCM) SMD-8 T&R
LNK304DN 120 mA (MDCM) 170 mA (CCM) SO-8
LNK304DN-TL 120 mA (MDCM) 170 mA (CCM) SO-8 T&R
LNK304DG 120 mA (MDCM) 170 mA (CCM) SO-8
LNK304DG-TL 120 mA (MDCM) 170 mA (CCM) SO-8 T&R
LNK305PN 175 mA (MDCM) 280 mA (CCM) DIP-8
LNK305GN 175 mA (MDCM) 280 mA (CCM) SMD-8
LNK305GN-TL 175 mA (MDCM) 280 mA (CCM) SMD-8 T&R
LNK305DN 175 mA (MDCM) 280 mA (CCM) SO-8
LNK305DN-TL 175 mA (MDCM) 280 mA (CCM) SO-8 T&R
LNK305DG 175 mA (MDCM) 280 mA (CCM) SO-8
LNK305DG-TL 175 mA (MDCM) 280 mA (CCM) SO-8 T&R
LNK306PN 225 mA (MDCM) 360 mA (CCM) DIP-8
LNK306GN 225 mA (MDCM) 360 mA (CCM) SMD-8
LNK306GN-TL 225 mA (MDCM) 360 mA (CCM) SMD-8 T&R
LNK306DN 225 mA (MDCM) 360 mA (CCM) SO-8
LNK306DN-TL 225 mA (MDCM) 360 mA (CCM) SO-8 T&R
LNK306DG 225 mA (MDCM) 360 mA (CCM) SO-8
LNK306DG-TL 225 mA (MDCM) 360 mA (CCM) SO-8 T&R
LNK353PN 3 W (85-265 VAC) 4 W (230 VAC) DIP-8
LNK353GN 3 W (85-265 VAC) 4 W (230 VAC) SMD-8
LNK353GN-TL 3 W (85-265 VAC) 4 W (230 VAC) SMD-8 T&R
LNK354PN 4.5 W (85-265 VAC) 5 W (230 VAC) DIP-8
LNK354GN 4.5 W (85-265 VAC) 5 W (230 VAC) SMD-8
LNK354GN-TL 4.5 W (85-265 VAC) 5 W (230 VAC) SMD-8 T&R
LNK362PN 2.6 W (85-265 VAC) 2.8 W (230 VAC) DIP-8
LNK362PG 2.6 W (85-265 VAC) 2.8 W (230 VAC) DIP-8
LNK362GN 2.6 W (85-265 VAC) 2.8 W (230 VAC) SMD-8
LNK362GN-TL 2.6 W (85-265 VAC) 2.8 W (230 VAC) SMD-8 T&R
LNK362DN 2.6 W (85-265 VAC) 2.8 W (230 VAC) SO-8
LNK362DN-TL 2.6 W (85-265 VAC) 2.8 W (230 VAC) SO-8, T&R
LNK362DG 2.6 W (85-265 VAC) 2.8 W (230 VAC) SO-8
LNK362DG-TL 2.6 W (85-265 VAC) 2.8 W (230 VAC) SO-8, T&R
LNK363PN 4.7 W (85-265 VAC) 7.5 W (230 VAC) DIP-8
LNK363PG 4.7 W (85-265 VAC) 7.5 W (230 VAC) DIP-8
LNK363GN 4.7 W (85-265 VAC) 7.5 W (230 VAC) SMD-8
LNK363GN-TL 4.7 W (85-265 VAC) 7.5 W (230 VAC) SMD-8 T&R
LNK363DN 4.7 W (85-265 VAC) 7.5 W (230 VAC) SO-8
LNK363DN-TL 4.7 W (85-265 VAC) 7.5 W (230 VAC) SO-8, T&R
LNK363DG 4.7 W (85-265 VAC) 7.5 W (230 VAC) SO-8
LNK363DG-TL 4.7 W (85-265 VAC) 7.5 W (230 VAC) SO-8, T&R
LNK364PN 6 W (85-265 VAC) 9 W (230 VAC) DIP-8
LNK364PG 6 W (85-265 VAC) 9 W (230 VAC) DIP-8
LNK364GN 6 W (85-265 VAC) 9 W (230 VAC) SMD-8
LNK364GN-TL 6 W (85-265 VAC) 9 W (230 VAC) SMD-8 T&R
LNK364DN 6 W (85-265 VAC) 9 W (230 VAC) SO-8
LNK364DN-TL 6 W (85-265 VAC) 9 W (230 VAC) SO-8, T&R
LNK364DG 6 W (85-265 VAC) 9 W (230 VAC) SO-8
LNK364DG-TL 6 W (85-265 VAC) 9 W (230 VAC) SO-8, T&R
LNK500PN 3 W (85-265 VAC) 4 W (230 VAC) DIP-8
LNK500GN 3 W (85-265 VAC) 4 W (230 VAC) SMD-8
LNK500GN-TL 3 W (85-265 VAC) 4 W (230 VAC) SMD-8, T&R
LNK501PN 3 W (85-265 VAC) 4 W (230 VAC) DIP-8
LNK501GN 3 W (85-265 VAC) 4 W (230 VAC) SMD-8
LNK501GN-TL 3 W (85-265 VAC) 4 W (230 VAC) SMD-8, T&R
LNK520PN 3 W (85-265 VAC) 4 W (230 VAC) DIP-8
LNK520GN 3 W (85-265 VAC) 4 W (230 VAC) SMD-8
LNK520GN-TL 3 W (85-265 VAC) 4 W (230 VAC) SMD-8, T&R
LNK562PN 1.9 W (85-265 VAC) 1.9 W (230 VAC) DIP-8
LNK562PG 1.9 W (85-265 VAC) 1.9 W (230 VAC) DIP-8
LNK562GN 1.9 W (85-265 VAC) 1.9 W (230 VAC) SMD-8
LNK562GN-TL 1.9 W (85-265 VAC) 1.9 W (230 VAC) SMD-8, T&R
LNK562DN 1.9 W (85-265 VAC) 1.9 W (230 VAC) SO-8
LNK562DN-TL 1.9 W (85-265 VAC) 1.9 W (230 VAC) SO-8, T&R
LNK562DG 1.9 W (85-265 VAC) 1.9 W (230 VAC) SO-8
LNK562DG-TL 1.9 W (85-265 VAC) 1.9 W (230 VAC) SO-8, T&R
LNK563PN 2.5 W (85-265 VAC) 2.5 W (230 VAC) DIP-8
LNK563PG 2.5 W (85-265 VAC) 2.5 W (230 VAC) DIP-8
LNK563GN 2.5 W (85-265 VAC) 2.5 W (230 VAC) SMD-8
LNK563GN-TL 2.5 W (85-265 VAC) 2.5 W (230 VAC) SMD-8, T&R
LNK563DN 2.5 W (85-265 VAC) 2.5 W (230 VAC) SO-8
LNK563DN-TL 2.5 W (85-265 VAC) 2.5 W (230 VAC) SO-8, T&R
LNK563DG 2.5 W (85-265 VAC) 2.5 W (230 VAC) SO-8
LNK563DG-TL 2.5 W (85-265 VAC) 2.5 W (230 VAC) SO-8, T&R
LNK564PN 3 W (85-265 VAC) 3 W (230 VAC) DIP-8
LNK564PG 3 W (85-265 VAC) 3 W (230 VAC) DIP-8
LNK564GN 3 W (85-265 VAC) 3 W (230 VAC) SMD-8
LNK564GN-TL 3 W (85-265 VAC) 3 W (230 VAC) SMD-8, T&R
LNK564DN 3 W (85-265 VAC) 3 W (230 VAC) SO-8
LNK564DN-TL 3 W (85-265 VAC) 3 W (230 VAC) SO-8, T&R
LNK564DG 3 W (85-265 VAC) 3 W (230 VAC) SO-8
LNK564DG-TL 3 W (85-265 VAC) 3 W (230 VAC) SO-8, T&R
LNK603PG 2.5 W (85-265 VAC) DIP-8
LNK603DG 2.5 W (85-265 VAC) SO-8
LNK603DG-TL 2.5 W (85-265 VAC) SO-8 T&R
LNK613PG 2.5 W (85-265 VAC) DIP-8
LNK613DG 2.5 W (85-265 VAC) SO-8
LNK613DG-TL 2.5 W (85-265 VAC) SO-8 T&R
LNK604PG 3.5 W (85-265 VAC) DIP-8
LNK604DG 3.5 W (85-265 VAC) SO-8
LNK604DG-TL 3.5 W (85-265 VAC) SO-8 T&R
LNK614PG 3.5 W (85-265 VAC) DIP-8
LNK614DG 3.5 W (85-265 VAC) SO-8
LNK614DG-TL 3.5 W (85-265 VAC) SO-8 T&R
LNK605PG 4.5 W (85-265 VAC) DIP-8
LNK605DG 4.5 W (85-265 VAC) SO-8
LNK605DG-TL 4.5 W (85-265 VAC) SO-8 T&R
LNK615PG 4.5 W (85-265 VAC) DIP-8
LNK615DG 4.5 W (85-265 VAC) SO-8
LNK615DG-TL 4.5 W (85-265 VAC) SO-8 T&R
LNK606PG 5.5 W (85-265 VAC) DIP-8
LNK606GG 5.5 W (85-265 VAC) SMD-8
LNK606GG-TL 5.5 W (85-265 VAC) SMD-8 T&R
LNK616PG 5.5 W (85-265 VAC) DIP-8
LNK616GG 5.5 W (85-265 VAC) SMD-8
LNK616GG-TL 5.5 W (85-265 VAC) SMD-8 T&R
LNK623PG 5.0 W (85-265 VAC) DIP-8
LNK623DG 5.0 W (85-265 VAC) SO-8
LNK623DG-TL 5.0 W (85-265 VAC) SO-8 T&R
LNK624PG 5.5 W (85-265 VAC) DIP-8
LNK624DG 5.5 W (85-265 VAC) SO-8
LNK624DG-TL 5.5 W (85-265 VAC) SO-8 T&R
LNK625PG 6.5 W (85-265 VAC) DIP-8
LNK625DG 6.5 W (85-265 VAC) SO-8
LNK625DG-TL 6.5 W (85-265 VAC) SO-8 T&R
LNK626PG 8.5 W (85-265 VAC) DIP-8
PKS603PN 9 W/25 W Pk (85-265 VAC) 13 W/32 W Pk (230 VAC) DIP-8
PKS604FN 23 W/44 W Pk (85-265 VAC) 35 W/56 W Pk (230 VAC) TO-262
PKS604PN 16 W/44 W Pk (85-265 VAC) 23 W/56 W Pk (230 VAC) DIP-8
PKS604YN 23 W/44 W Pk (85-265 VAC) 35 W/56 W Pk (230 VAC) TO-220
PKS605FN 30 W/58 W Pk (85-265 VAC) 46 W/79 W Pk (230 VAC) TO-262
PKS605PN 21 W/44 W Pk (85-265 VAC) 31 W/60 W Pk (230 VAC) DIP-8
PKS605YN 30 W/58 W Pk (85-265 VAC) 46 W/79 W Pk (230 VAC) TO-220
PKS606FN 45 W/86 W Pk (85-265 VAC) 68 W/117 W Pk (230 VAC) TO-262
PKS606PN 25 W/46 W Pk (85-265 VAC) 35 W/66 W Pk (230 VAC) DIP-8
PKS606YN 45 W/86 W Pk (85-265 VAC) 68 W/117 W Pk (230 VAC) TO-220
PKS607FN 50W/93 W Pk (85-265 VAC) 75 W/126 W Pk (230 VAC) TO-262
PKS607YN 50W/93 W Pk (85-265 VAC) 75 W/126 W Pk (230 VAC) TO-220
TNY253PN 2 W (85 - 265 VAC) 4 W (100/115/230 VAC) DIP-8
TNY253GN 2 W (85 - 265 VAC) 4 W (100/115/230 VAC) SMD-8
TNY253GN-TL 2 W (85 - 265 VAC) 4 W (100/115/230 VAC) SMD-8 T&R
TNY254PN 4 W (85 - 265 VAC) 5 W (100/115/230 VAC) DIP-8
TNY254GN 4 W (85 - 265 VAC) 5 W (100/115/230 VAC) SMD-8
TNY254GN-TL 4 W (85 - 265 VAC) 5 W (100/115/230 VAC) SMD-8 T&R
TNY255PN 6.5 W (85-265 VAC) 10 W (100/115/230 VAC) DIP-8
TNY255GN 6.5 W (85-265 VAC) 10 W (100/115/230 VAC) SMD-8
TNY255GN-TL 6.5 W (85-265 VAC) 10 W (100/115/230 VAC) SMD-8 T&R
TNY256PN 10 W (85-265 VAC) 15 W (100/115/230 VAC) DIP-8
TNY256GN 10 W (85-265 VAC) 15 W (100/115/230 VAC) SMD-8
TNY256GN-TL 10 W (85-265 VAC) 15 W (100/115/230 VAC) SMD-8 T&R
TNY256YN 10 W (85-265 VAC) 15 W (100/115/230 VAC) TO-220
TNY263PN 4.7 W (85-265 VAC) 7.5 W (230 VAC) DIP-8
TNY263PG 4.7 W (85-265 VAC) 7.5 W (230 VAC) DIP-8
TNY263GN 4.7 W (85-265 VAC) 7.5 W (230 VAC) SMD-8
TNY263GN-TL 4.7 W (85-265 VAC) 7.5 W (230 VAC) SMD-8, T&R
TNY264PN 6 W (85-265 VAC) 9 W (230 VAC) DIP-8
TNY264PG 6 W (85-265 VAC) 9 W (230 VAC) DIP-8
TNY264GN 6 W (85-265 VAC) 9 W (230 VAC) SMD-8
TNY264GN-TL 6 W (85-265 VAC) 9 W (230 VAC) SMD-8, T&R
TNY265PN 7.5 W (85-265 VAC) 11 W (230 VAC) DIP-8
TNY265PG 7.5 W (85-265 VAC) 11 W (230 VAC) DIP-8
TNY265GN 7.5 W (85-265 VAC) 11 W (230 VAC) SMD-8
TNY265GN-TL 7.5 W (85-265 VAC) 11 W (230 VAC) SMD-8, T&R
TNY266PN 9.5 W (85-265 VAC) 15 W (230 VAC) DIP-8
TNY266PG 9.5 W (85-265 VAC) 15 W (230 VAC) DIP-8
TNY266GN 9.5 W (85-265 VAC) 15 W (230 VAC) SMD-8
TNY266GN-TL 9.5 W (85-265 VAC) 15 W (230 VAC) SMD-8, T&R
TNY267PN 12 W (85-265 VAC) 19 W (230 VAC) DIP-8
TNY267GN 12 W (85-265 VAC) 19 W (230 VAC) SMD-8
TNY267GN-TL 12 W (85-265 VAC) 19 W (230 VAC) SMD-8, T&R
TNY268PN 15 W (85-265 VAC) 23 W (230 VAC) DIP-8
TNY268GN 15 W (85-265 VAC) 23 W (230 VAC) SMD-8
TNY268GN-TL 15 W (85-265 VAC) 23 W (230 VAC) SMD-8, T&R
TNY274PN 8.5 W (85-265 VAC) 11 W (230 VAC) DIP-8
TNY274PG 8.5 W (85-265 VAC) 11 W (230 VAC) DIP-8
TNY274GN 8.5 W (85-265 VAC) 11 W (230 VAC) SMD-8
TNY274GN-TL 8.5 W (85-265 VAC) 11 W (230 VAC) SMD-8, T&R
TNY275PN 11.5 W (85-265 VAC) 15 W (230 VAC) DIP-8
TNY275PG 11.5 W (85-265 VAC) 15 W (230 VAC) DIP-8
TNY275GN 11.5 W (85-265 VAC) 15 W (230 VAC) SMD-8
TNY275GN-TL 11.5 W (85-265 VAC) 15 W (230 VAC) SMD-8, T&R
TNY276PN 15 W (85-265 VAC) 19 W (230 VAC) DIP-8
TNY276GN 15 W (85-265 VAC) 19 W (230 VAC) SMD-8
TNY276GN-TL 15 W (85-265 VAC) 19 W (230 VAC) SMD-8, T&R
TNY277PN 18 W (85-265 VAC) 23.5 W (230 VAC) DIP-8
TNY277PG 18 W (85-265 VAC) 23.5 W (230 VAC) DIP-8
TNY277GN 18 W (85-265 VAC) 23.5 W (230 VAC) SMD-8
TNY277GN-TL 18 W (85-265 VAC) 23.5 W (230 VAC) SMD-8, T&R
TNY278PN 21.5 W (85-265 VAC) 28 W (230 VAC) DIP-8
TNY278GN 21.5 W (85-265 VAC) 28 W (230 VAC) SMD-8
TNY278GN-TL 21.5 W (85-265 VAC) 28 W (230 VAC) SMD-8, T&R
TNY279PN 25 W (85-265 VAC) 32 W (230 VAC) DIP-8
TNY279GN 25 W (85-265 VAC) 32 W (230 VAC) SMD-8
TNY279GN-TL 25 W (85-265 VAC) 32 W (230 VAC) SMD-8, T&R
TNY280PN 28.5 W (85-265 VAC) 36.5 W (230 VAC) DIP-8
TNY280GN 28.5 W (85-265 VAC) 36.5 W (230 VAC) SMD-8
TNY280GN-TL 28.5 W (85-265 VAC) 36.5 W (230 VAC) SMD-8, T&R
TNY375PN 12 W (85-265 VAC) 16.5 W (230 VAC) DIP-8
TNY375GN 12 W (85-265 VAC) 16.5 W (230 VAC) SMD-8
TNY375GN-TL 12 W (85-265 VAC) 16.5 W (230 VAC) SMD-8, T&R
TNY376PN 17 W (85-265 VAC) 22 W (230 VAC) DIP-8
TNY376GN 17 W (85-265 VAC) 22 W (230 VAC) SMD-8
TNY376GN-TL 17 W (85-265 VAC) 22 W (230 VAC) SMD-8, T&R
TNY377PN 23 W (85-265 VAC) 28 W (230 VAC) DIP-8
TNY377GN 23 W (85-265 VAC) 28 W (230 VAC) SMD-8
TNY377GN-TL 23 W (85-265 VAC) 28 W (230 VAC) SMD-8, T&R
TNY378PN 27 W (85-265 VAC) 34 W (230 VAC) DIP-8
TNY378GN 27 W (85-265 VAC) 34 W (230 VAC) SMD-8
TNY378GN-TL 27 W (85-265 VAC) 34 W (230 VAC) SMD-8, T&R
TNY379PN 31 W (85-265 VAC) 39 W (230 VAC) DIP-8
TNY379GN 31 W (85-265 VAC) 39 W (230 VAC) SMD-8
TNY379GN-TL 31 W (85-265 VAC) 39 W (230 VAC) SMD-8, T&R
TNY380PN 35 W (85-265 VAC) 45 W (230 VAC) DIP-8
TNY380GN 35 W (85-265 VAC) 45 W (230 VAC) SMD-8
TNY380GN-TL 35 W (85-265 VAC) 45 W (230 VAC) SMD-8, T&R
TOP100YN 0-20 W (100/110 VAC) TO-220
TOP101YN 15-35 W (100/110 VAC) TO-220
TOP102YN 20-45 W (100/110 VAC) TO-220
TOP103YN 25-55 W (100/110 VAC) TO-220
TOP104YN 30-60 W (100/110 VAC) TO-220
TOP200YN 5-12 W (85-265 VAC) 10-25 W (100/115/230 VAC) TO-220
TOP201YN 0-22 W (85-265 VAC) 20-45 W (100/115/230 VAC) TO-220
TOP202YN 15-30 W (85-265 VAC) 30-60 W (100/115/230 VAC) TO-220
TOP203YN 20-35 W (85-265 VAC) 40-70 W (100-115/230 VAC) TO-220
TOP204YN 30-50 W (85-265 VAC) 60-100 W (100/115/230 VAC) TO-220
TOP209PN 2 W (85-265 VAC) 4 W (100/115/230 VAC) DIP-8
TOP209GN 2 W (85-265 VAC) 4 W (100/115/230 VAC) SMD-8
TOP209GN-TL 2 W (85-265 VAC) 4 W (100/115/230 VAC) SMD-8 T&R
TOP210PN 5 W (85-265 VAC) 8 W (100/115/230 VAC) DIP-8
TOP210GN 5 W (85-265 VAC) 8 W (100/115/230 VAC) SMD-8
TOP210GN-TL 5 W (85-265 VAC) 8 W (100/115/230 VAC) SMD-8 T&R
TOP214YN 25-42 W (85-265 VAC) 50-85 W (100/115/230 VAC) TO-220
TOP221PN 6 W (85-265 VAC) 9 W (100/115/230 VAC) DIP-8
TOP221GN 6 W (85-265 VAC) 9 W (100/115/230 VAC) SMD-8
TOP221GN-TL 6 W (85-265 VAC) 9 W (100/115/230 VAC) SMD-8 T&R
TOP221YN 7 W (85-265 VAC) 12 W (100/115/230 VAC) TO-220
TOP222PN 10 W (85-265 VAC) 15 W (100/115/230 VAC) DIP-8
TOP222GN 10 W (85-265 VAC) 15 W (100/115/230 VAC) SMD-8
TOP222GN-TL 10 W (85-265 VAC) 15 W (100/115/230 VAC) SMD-8 T&R
TOP222YN 15 W (85-265 VAC) 25 W (100/115/230 VAC) TO-220
TOP223PN 15 W (85-265 VAC) 25 W (100/115/230 VAC) DIP-8
TOP223GN 15 W (85-265 VAC) 25 W (100/115/230 VAC) SMD-8
TOP223GN-TL 15 W (85-265 VAC) 25 W (100/115/230 VAC) SMD-8 T&R
TOP223YN 30 W (85-265 VAC) 50 W (100/115/230 VAC) TO-220
TOP224PN 20 W (85-265 VAC) 30 W (100/115/230 VAC) DIP-8
TOP224GN 20 W (85-265 VAC) 30 W (100/115/230 VAC) SMD-8
TOP224GN-TL 20 W (85-265 VAC) 30 W (100/115/230 VAC) SMD-8 T&R
TOP224YN 45 W (85-265 VAC) 75 W (100/115/230 VAC) TO-220
TOP225YN 60 W (85-265 VAC) 100 W (100/115/230 VAC) TO-220
TOP226YN 75 W (85-265 VAC) 125 W (100/115/230 VAC) TO-220
TOP227YN 90 W (85-265 VAC) 150 W (100/115/230 VAC) TO-220
TOP232PN 10 W (85-265 VAC) 15W (230 VAC) DIP-8
TOP232GN 10 W (85-265 VAC) 15W (230 VAC) SMD-8
TOP232GN-TL 10 W (85-265 VAC) 15W (230 VAC) SMD-8 T&R
TOP232YN 15 W (85-265 VAC) 25 W (230 VAC) TO-220
TOP233PN 15 W (85-265 VAC) 25W (230 VAC) DIP-8
TOP233GN 15 W (85-265 VAC) 25W (230 VAC) SMD-8
TOP233GN-TL 15 W (85-265 VAC) 25W (230 VAC) SMD-8 T&R
TOP233YN 30 W (85-265 VAC) 50 W (230 VAC) TO-220
TOP234PN 20 W (85-265 VAC) 30 W (230 VAC) DIP-8
TOP234GN 20 W (85-265 VAC) 30 W (230 VAC) SMD-8
TOP234GN-TL 20 W (85-265 VAC) 30 W (230 VAC) SMD-8 T&R
TOP234YN 45 W (85-265 VAC) 75 W (230 VAC) TO-220
TOP242FN 10 W (85-265 VAC) 15 W (230 VAC) TO-262
TOP242PN 10 W (85-265 VAC) 15 W (230 VAC) DIP-8
TOP242GN 10 W (85-265 VAC) 15 W (230 VAC) SMD-8
TOP242GN-TL 10 W (85-265 VAC) 15 W (230 VAC) SMD-8 T&R
TOP242R-TL 14 W (85-265 VAC) 22 W (230 VAC) TO-263 T&R
TOP242YN 14 W (85-265 VAC) 22 W (230 VAC) TO-220
TOP243FN 30 W (85-265 VAC) 45 W (230 VAC) TO-262
TOP243PN 15 W (85-265 VAC) 25W (230 VAC) DIP-8
TOP243GN 15 W (85-265 VAC) 25W (230 VAC) SMD-8
TOP243GN-TL 15 W (85-265 VAC) 25W (230 VAC) SMD-8 T&R
TOP243R-TL 23 W (85-265 VAC) 45 W (230 VAC) TO-263 T&R
TOP243YN 30 W (85-265 VAC) 45 W (230 VAC) TO-220
TOP244FN 45 W (85-265 VAC) 65 W (230 VAC) TO-262
TOP244PN 20 W (85-265 VAC) 28 W (230 VAC) DIP-8
TOP244GN 20 W (85-265 VAC) 28 W (230 VAC) SMD-8
TOP244GN-TL 20 W (85-265 VAC) 28 W (230 VAC) SMD-8 T&R
TOP244R-TL 28 W (85-265 VAC) 50 W (230 VAC) TO-263 T&R
TOP244YN 45 W (85-265 VAC) 65 W (230 VAC) TO-220
TOP245FN 60W (85-265 VAC) 85 W (230 VAC) TO-262
TOP245PN 22W (85-265 VAC) 30 W (230 VAC) DIP-8
TOP245GN 22W (85-265 VAC) 30 W (230 VAC) SMD-8
TOP245GN-TL 22W (85-265 VAC) 30 W (230 VAC) SMD-8 T&R
TOP245R-TL 33W (85-265 VAC) 57 W (230 VAC) TO-263 T&R
TOP245YN 60W (85-265 VAC) 85 W (230 VAC) TO-220
TOP246FN 90 W (85-265 VAC) 125 W (230 VAC) TO-262
TOP246PN 26 W (85-265 VAC) 34 W (230 VAC) DIP-8
TOP246GN 26 W (85-265 VAC) 34 W (230 VAC) SMD-8
TOP246GN-TL 26 W (85-265 VAC) 34 W (230 VAC) SMD-8 T&R
TOP246R-TL 38 W (85-265 VAC) 64 W (230 VAC) TO-263 T&R
TOP246YN 90 W (85-265 VAC) 125 W (230 VAC) TO-220
TOP247FN 125 W (85-265 VAC) 165 W (230 VAC) TO-262
TOP247R-TL 43 W (85-265 VAC) 70 W (230 VAC) TO-263 T&R
TOP247YN 125 W (85-265 VAC) 165 W (230 VAC) TO-220
TOP248FN 155 W (85-265 VAC) 205 W (230 VAC) TO-262
TOP248R-TL 48 W (85-265 VAC) 75 W (230 VAC) TO-263 T&R
TOP248YN 155 W (85-265 VAC) 205 W (230 VAC) TO-220
TOP249FN 180 W (85-265 VAC) 250 W (230 VAC) TO-262
TOP249R-TL 53 W (85-265 VAC) 79 W (230 VAC) TO-263 T&R
TOP249YN 180 W (85-265 VAC) 250 W (230 VAC) TO-220
TOP250FN 210 W (85-265 VAC) 290 W (230 VAC) TO-262
TOP250R-TL 55 W (85-265 VAC) 82 W (230 VAC) TO-263 T&R
TOP250YN 210 W (85-265 VAC) 290 W (230 VAC) TO-220
TOP252PN 10W/13W PK (85-264V AC) 15W/21W PK (230V AC) DIP-8
TOP252GN 10W/13W PK (85-264V AC) 15W/21W PK (230V AC) SMD-8
TOP252GN-TL 10W/13W PK (85-264V AC) 15W/21W PK (230V AC) SMD-8, T&R
TOP252MN 10W/13W PK (85-264V AC) 15W/21W PK (230V AC) SDIP-10
TOP252EN 13W (85-264V AC) 21W (230V AC) eSIP-7C
TOP253PN 15W/25W PK (85-264V AC) 25W/38W PK (230V AC) DIP-8
TOP253GN 15W/25W PK (85-264V AC) 25W/38W PK (230V AC) SMD-8
TOP253GN-TL 15W/25W PK (85-264V AC) 25W/38W PK (230V AC) SMD-8, T&R
TOP253MN 15W/29W PK (85-264V AC) 25W/43W PK (230V AC) SDIP-10
TOP253EN 29W (85-264V AC) 43W (230V AC) eSIP-7C
TOP254PN 20W/30W PK (85-264V AC) 28W/47W PK (230V AC) DIP-8
TOP254GN 20W/30W PK (85-264V AC) 28W/47W PK (230V AC) SMD-8
TOP254GN-TL 20W/30W PK (85-264V AC) 28W/47W PK (230V AC) SMD-8, T&R
TOP254MN 20W/40W PK (85-264V AC) 28W/62W PK (230V AC) SDIP-10
TOP254YN 43W (85-264V AC) 62W (230V AC) TO-220
TOP254EN 43W (85-264V AC) 62W (230V AC) eSIP-7C
TOP255PN 22W/35W PK (85-264V AC) 30W/54W PK (230V AC) DIP-8
TOP255GN 22W/35W PK (85-264V AC) 30W/54W PK (230V AC) SMD-8
TOP255GN-TL 22W/35W PK (85-264V AC) 30W/54W PK (230V AC) SMD-8, T&R
TOP255MN 22W/52W PK (85-264V AC) 30W/81W PK (230V AC) SDIP-10
TOP255YN 57W (85-264V AC) 81W (230V AC) TO-220
TOP255EN 57W (85-264V AC) 81W (230V AC) eSIP-7C
TOP255LN 57W (85-264V AC) 81W (230V AC) eSIP-7F
TOP256PN 26W/40W PK (85-264V AC) 34W/63W PK (230V AC) DIP-8
TOP256GN 26W/40W PK (85-264V AC) 34W/63W PK (230V AC) SMD-8
TOP256GN-TL 26W/40W PK (85-264V AC) 34W/63W PK (230V AC) SMD-8, T&R
TOP256MN 26W/64W PK (85-264V AC) 34W/98W PK (230V AC) SDIP-10
TOP256YN 86W (85-264V AC) 119W (230V AC) TO-220
TOP256EN 86W (85-264V AC) 119W (230V AC) eSIP-7C
TOP256EG 86W (85-264V AC) 119W (230V AC) eSIP-7C
TOP256LN 64W (85-264V AC) 88W (230V AC) eSIP-7F
TOP257PN 30W/45W PK (85-264V AC) 41W/70W PK (230V AC) DIP-8
TOP257GN 30W/45W PK (85-264V AC) 41W/70W PK (230V AC) SMD-8
TOP257GN-TL 30W/45W PK (85-264V AC) 41W/70W PK (230V AC) SMD-8, T&R
TOP257MN 30W/78W PK (85-264V AC) 41W/119W PK (230V AC) SDIP-10
TOP257YN 119W (85-264V AC) 157W (230V AC) TO-220
TOP257EN 119W (85-264V AC) 157W (230V AC) eSIP-7C
TOP257LN 78W (85-264V AC) 105W (230V AC) eSIP-7F
TOP258PN 35W/50W PK (85-264V AC) 48W/77W PK (230V AC) DIP-8
TOP258GN 35W/50W PK (85-264V AC) 48W/77W PK (230V AC) SMD-8
TOP258GN-TL 35W/50W PK (85-264V AC) 48W/77W PK (230V AC) SMD-8, T&R
TOP258MN 35W/92W PK (85-264V AC) 48W/140W PK (230V AC) SDIP-10
TOP258YN 148W (85-264V AC) 195W (230V AC) TO-220
TOP258EN 148W (85-264V AC) 195W (230V AC) eSIP-7C
TOP258LN 92W (85-264V AC) 122W (230V AC) eSIP-7F
TOP259YN 171W (85-264V AC) 238W (230V AC) TO-220
TOP259EN 171W (85-264V AC) 238W (230V AC) eSIP-7C
TOP259LN 120W (85-264V AC) 162W (230V AC) eSIP-7F
TOP260YN 200W (85-264V AC) 275W (230V AC) TO-220
TOP260EN 200W (85-264V AC) 275W (230V AC) eSIP-7C
TOP260LN 140W (85-264V AC) 190W (230V AC) eSIP-7F
TOP261YN 254W (85-264V AC) 333W (230V AC) TO-220
TOP261EN 254W (85-264V AC) 333W (230V AC) eSIP-7C
TOP261LN 177W (85-264V AC) 244W (230V AC) eSIP-7F
TOP262EN 254W (85-264V AC) 333W (230V AC) eSIP-7C
TOP262LN 177W (85-264V AC) 244W (230V AC) eSIP-7F
TOP412GN 9 W (48 VDC) SMD-8
TOP412GN-TL 9 W (48 VDC) SMD-8 T&R
TOP414GN 12 W (48 VDC) SMD-8
TOP414GN-TL 12 W (48 VDC) SMD-8 T&R
电话:0755-27909184
QQ: 403336969
Product Description
LinkSwitch
Output: 5 V @ 30 W
DPA-Switch
Output: 12 V @ 30 W
TOPSwitch-GX
LinkSwitch
DPA-Switch
DPA-Switch
Output: 6V @ 2 W
LinkSwitch-LP
Output: 6.2 V @ 2 W
LinkSwitch-XT
Output: 12 V @ 12 W
TinySwitch-III
PeakSwitch
DPA-Switch
LinkSwitch-LP
LinkSwitch-TN
TinySwitch-PK
PeakSwitch
TOPSwitch-HX
LinkSwitch-TN
LinkSwitch-II
LinkSwitch-CV
@lang4lee
你好,你可以给我们联系啊.我们竭诚为你服务,给你全方位的技术支持!电话:0755-27909184手机:13534168067/吕 13480936839QQ: 403336969有用PI的朋友请看下面希望能给你有所帮助!ProductDescriptionDAK-16AAC-DCadapterOutput:5.5V@2.75WLinkSwitchSamplesandCompleteDocumentationDAK-21ADC-DCconverterOutput:5V@30WDPA-SwitchSamplesandCompleteDocumentationDAK-34AC-DCpowersupplyOutput:12V@30WTOPSwitch-GXSamplesandCompleteDocumentationDAK-54AC-DCadapterOutput:5.5V@2.75WLinkSwitchSamplesandCompleteDocumentationDAK-68APoEDC-DCConverter-Class0Output:3.3V@6.6WDPA-SwitchSamplesandCompleteDocumentationDAK-71ADC-DCConverterOutput:3.3V@6.6WDPA-SwitchSamplesandCompleteDocumentationDAK-85AC-DCLinearChargerReplacementOutput:6V@2WLinkSwitch-LPSamplesandCompleteDocumentationDAK-89AC-DCAdapterOutput:6.2V@2WLinkSwitch-XTSamplesandCompleteDocumentationRDK-91AC-DCAdapterOutput:12V@12WTinySwitch-IIISamplesandCompleteDocumentationDAK-93AC-DCpeakmodepowersupplyOutput:30V@32Wcontinuous,89Wpeak(50ms)PeakSwitchSamplesandCompleteDocumentationDAK-86PoEDC-DCConverter-ClassselectableOutput:3.3V@6.6WDPA-SwitchSamplesandCompleteDocumentationRDK-831.75WCVCordlessPhoneAdapter85-265VACInput, 7.3V, 240mAOutputLinkSwitch-LPSamplesandCompleteDocumentationRDK-131LEDHalogenBulbRetrofitKit85-265VACInput, 3WOutputLinkSwitch-TNSamplesandCompleteDocumentationRDK-115MultipleOutputDVD,Set-topboxPowerSupplyUniversalInputVoltage,85-265VACInput, 7.5WOutput (13WPeak)TinySwitch-PKSamplesandCompleteDocumentationRDK-128VariableSpeedMotorDrive90-265VACInput, 36WOutput (72WPeaK)PeakSwitchSamplesandCompleteDocumentationRDK-142LCDMonitorPowerSupply90-265VACInput,12V,2Aand5V,2.2AOutputs TOPSwitch-HXSamplesandCompleteDocumentationRDK-138Non-Isolated,DualOutputBuck/Buck-DerivedPowerSupplyOutput:5V,12V@1.2WLinkSwitch-TNSamplesandCompleteDocumentationRDK-160ThreeLowPowerChargers5V,1A/5V,700mA/6V,300mALinkSwitch-IISamplesandCompleteDocumentationRDK-201ConstantVoltage(CV)Adapter90–265VACInput;5V,1.2AOutputLinkSwitch-CVPartNumberDescriptionPackageDPA422PN10W(36-75VDCinput)DIP-8DPA422GN10W(36-75VDCinput)SMD-8DPA422GN-TL10W(36-75VDCinput)SMD-8,T&RDPA423PN13W(36-75VDCinput)DIP-8DPA423GN13W(36-75VDCinput)SMD-8DPA423GN-TL13W(36-75VDCinput)SMD-8,T&RDPA423R18W(36-75VDCinput)TO-263DPA423R-TL18W(36-75VDCinput)TO-263T&RDPA424PN24W(36-75VDCinput)DIP-8DPA424GN24W(36-75VDCinput)SMD-8DPA424GN-TL24W(36-75VDCinput)SMD-8,T&RDPA424R35W(36-75VDCinput)TO-263DPA424R-TL35W(36-75VDCinput)TO-263T&RDPA425PN25.5W(36-75VDCinput)DIP-8DPA425GN25.5W(36-75VDCinput)SMD-8DPA425GN-TL25.5W(36-75VDCinput)SMD-8,T&RDPA425R70W(36-75VDCinput)TO-263DPA425R-TL70W(36-75VDCinput)TO-263T&RDPA426R100W(36-75VDCinput)TO-263DPA426R-TL100W(36-75VDCinput)TO-263T&RLNK302PN63mA(MDCM)80mA(CCM)DIP-8LNK302GN63mA(MDCM)80mA(CCM)SMD-8LNK302GN-TL63mA(MDCM)80mA(CCM)SMD-8T&RLNK302DN63mA(MDCM)80mA(CCM)SO-8LNK302DN-TL63mA(MDCM)80mA(CCM)SO-8T&RLNK302DG63mA(MDCM)80mA(CCM)SO-8LNK302DG-TL63mA(MDCM)80mA(CCM)SO-8T&RLNK304PN120mA(MDCM)170mA(CCM)DIP-8LNK304GN120mA(MDCM)170mA(CCM)SMD-8LNK304GN-TL120mA(MDCM)170mA(CCM)SMD-8T&RLNK304DN120mA(MDCM)170mA(CCM)SO-8LNK304DN-TL120mA(MDCM)170mA(CCM)SO-8T&RLNK304DG120mA(MDCM)170mA(CCM)SO-8LNK304DG-TL120mA(MDCM)170mA(CCM)SO-8T&RLNK305PN175mA(MDCM)280mA(CCM)DIP-8LNK305GN175mA(MDCM)280mA(CCM)SMD-8LNK305GN-TL175mA(MDCM)280mA(CCM)SMD-8T&RLNK305DN175mA(MDCM)280mA(CCM)SO-8LNK305DN-TL175mA(MDCM)280mA(CCM)SO-8T&RLNK305DG175mA(MDCM)280mA(CCM)SO-8LNK305DG-TL175mA(MDCM)280mA(CCM)SO-8T&RLNK306PN225mA(MDCM)360mA(CCM)DIP-8LNK306GN225mA(MDCM)360mA(CCM)SMD-8LNK306GN-TL225mA(MDCM)360mA(CCM)SMD-8T&RLNK306DN225mA(MDCM)360mA(CCM)SO-8LNK306DN-TL225mA(MDCM)360mA(CCM)SO-8T&RLNK306DG225mA(MDCM)360mA(CCM)SO-8LNK306DG-TL225mA(MDCM)360mA(CCM)SO-8T&RLNK353PN3W(85-265VAC)4W(230VAC)DIP-8LNK353GN3W(85-265VAC)4W(230VAC)SMD-8LNK353GN-TL3W(85-265VAC)4W(230VAC)SMD-8T&RLNK354PN4.5W(85-265VAC)5W(230VAC)DIP-8LNK354GN4.5W(85-265VAC)5W(230VAC)SMD-8LNK354GN-TL4.5W(85-265VAC)5W(230VAC)SMD-8T&RLNK362PN2.6W(85-265VAC)2.8W(230VAC)DIP-8LNK362PG2.6W(85-265VAC)2.8W(230VAC)DIP-8LNK362GN2.6W(85-265VAC)2.8W(230VAC)SMD-8LNK362GN-TL2.6W(85-265VAC)2.8W(230VAC)SMD-8T&RLNK362DN2.6W(85-265VAC)2.8W(230VAC)SO-8LNK362DN-TL2.6W(85-265VAC)2.8W(230VAC)SO-8,T&RLNK362DG2.6W(85-265VAC)2.8W(230VAC)SO-8LNK362DG-TL2.6W(85-265VAC)2.8W(230VAC)SO-8,T&RLNK363PN4.7W(85-265VAC)7.5W(230VAC)DIP-8LNK363PG4.7W(85-265VAC)7.5W(230VAC)DIP-8LNK363GN4.7W(85-265VAC)7.5W(230VAC)SMD-8LNK363GN-TL4.7W(85-265VAC)7.5W(230VAC)SMD-8T&RLNK363DN4.7W(85-265VAC)7.5W(230VAC)SO-8LNK363DN-TL4.7W(85-265VAC)7.5W(230VAC)SO-8,T&RLNK363DG4.7W(85-265VAC)7.5W(230VAC)SO-8LNK363DG-TL4.7W(85-265VAC)7.5W(230VAC)SO-8,T&RLNK364PN6W(85-265VAC)9W(230VAC)DIP-8LNK364PG6W(85-265VAC)9W(230VAC)DIP-8LNK364GN6W(85-265VAC)9W(230VAC)SMD-8LNK364GN-TL6W(85-265VAC)9W(230VAC)SMD-8T&RLNK364DN6W(85-265VAC)9W(230VAC)SO-8LNK364DN-TL6W(85-265VAC)9W(230VAC)SO-8,T&RLNK364DG6W(85-265VAC)9W(230VAC)SO-8LNK364DG-TL6W(85-265VAC)9W(230VAC)SO-8,T&RLNK500PN3W(85-265VAC)4W(230VAC)DIP-8LNK500GN3W(85-265VAC)4W(230VAC)SMD-8LNK500GN-TL3W(85-265VAC)4W(230VAC)SMD-8,T&RLNK501PN3W(85-265VAC)4W(230VAC)DIP-8LNK501GN3W(85-265VAC)4W(230VAC)SMD-8LNK501GN-TL3W(85-265VAC)4W(230VAC)SMD-8,T&RLNK520PN3W(85-265VAC)4W(230VAC)DIP-8LNK520GN3W(85-265VAC)4W(230VAC)SMD-8LNK520GN-TL3W(85-265VAC)4W(230VAC)SMD-8,T&RLNK562PN1.9W(85-265VAC)1.9W(230VAC)DIP-8LNK562PG1.9W(85-265VAC)1.9W(230VAC)DIP-8LNK562GN1.9W(85-265VAC)1.9W(230VAC)SMD-8LNK562GN-TL1.9W(85-265VAC)1.9W(230VAC)SMD-8,T&RLNK562DN1.9W(85-265VAC)1.9W(230VAC)SO-8LNK562DN-TL1.9W(85-265VAC)1.9W(230VAC)SO-8,T&RLNK562DG1.9W(85-265VAC)1.9W(230VAC)SO-8LNK562DG-TL1.9W(85-265VAC)1.9W(230VAC)SO-8,T&RLNK563PN2.5W(85-265VAC)2.5W(230VAC)DIP-8LNK563PG2.5W(85-265VAC)2.5W(230VAC)DIP-8LNK563GN2.5W(85-265VAC)2.5W(230VAC)SMD-8LNK563GN-TL2.5W(85-265VAC)2.5W(230VAC)SMD-8,T&RLNK563DN2.5W(85-265VAC)2.5W(230VAC)SO-8LNK563DN-TL2.5W(85-265VAC)2.5W(230VAC)SO-8,T&RLNK563DG2.5W(85-265VAC)2.5W(230VAC)SO-8LNK563DG-TL2.5W(85-265VAC)2.5W(230VAC)SO-8,T&RLNK564PN3W(85-265VAC)3W(230VAC)DIP-8LNK564PG3W(85-265VAC)3W(230VAC)DIP-8LNK564GN3W(85-265VAC)3W(230VAC)SMD-8LNK564GN-TL3W(85-265VAC)3W(230VAC)SMD-8,T&RLNK564DN3W(85-265VAC)3W(230VAC)SO-8LNK564DN-TL3W(85-265VAC)3W(230VAC)SO-8,T&RLNK564DG3W(85-265VAC)3W(230VAC)SO-8LNK564DG-TL3W(85-265VAC)3W(230VAC)SO-8,T&RPartNumberDescriptionPackageLNK603PG2.5W(85-265VAC)DIP-8LNK603DG2.5W(85-265VAC)SO-8LNK603DG-TL2.5W(85-265VAC)SO-8T&RLNK613PG2.5W(85-265VAC)DIP-8LNK613DG2.5W(85-265VAC)SO-8LNK613DG-TL2.5W(85-265VAC)SO-8T&RLNK604PG3.5W(85-265VAC)DIP-8LNK604DG3.5W(85-265VAC)SO-8LNK604DG-TL3.5W(85-265VAC)SO-8T&RLNK614PG3.5W(85-265VAC)DIP-8LNK614DG3.5W(85-265VAC)SO-8LNK614DG-TL3.5W(85-265VAC)SO-8T&RLNK605PG4.5W(85-265VAC)DIP-8LNK605DG4.5W(85-265VAC)SO-8LNK605DG-TL4.5W(85-265VAC)SO-8T&RLNK615PG4.5W(85-265VAC)DIP-8LNK615DG4.5W(85-265VAC)SO-8LNK615DG-TL4.5W(85-265VAC)SO-8T&RLNK606PG5.5W(85-265VAC)DIP-8LNK606GG5.5W(85-265VAC)SMD-8LNK606GG-TL5.5W(85-265VAC)SMD-8T&RLNK616PG5.5W(85-265VAC)DIP-8LNK616GG5.5W(85-265VAC)SMD-8LNK616GG-TL5.5W(85-265VAC)SMD-8T&RLNK623PG5.0W(85-265VAC)DIP-8LNK623DG5.0W(85-265VAC)SO-8LNK623DG-TL5.0W(85-265VAC)SO-8T&RLNK624PG5.5 W(85-265VAC)DIP-8LNK624DG5.5W(85-265VAC)SO-8LNK624DG-TL5.5W(85-265VAC)SO-8T&RLNK625PG6.5W(85-265VAC)DIP-8LNK625DG6.5W(85-265VAC)SO-8LNK625DG-TL6.5W(85-265VAC)SO-8T&RLNK626PG8.5W(85-265VAC)DIP-8PKS603PN9W/25WPk(85-265VAC)13W/32WPk(230VAC)DIP-8PKS604FN23W/44WPk(85-265VAC)35W/56WPk(230VAC)TO-262PKS604PN16W/44WPk(85-265VAC)23W/56WPk(230VAC)DIP-8PKS604YN23W/44WPk(85-265VAC)35W/56WPk(230VAC)TO-220PKS605FN30W/58WPk(85-265VAC)46W/79WPk(230VAC)TO-262PKS605PN21W/44WPk(85-265VAC)31W/60WPk(230VAC)DIP-8PKS605YN30W/58WPk(85-265VAC)46W/79WPk(230VAC)TO-220PKS606FN45W/86WPk(85-265VAC)68W/117WPk(230VAC)TO-262PKS606PN25W/46WPk(85-265VAC)35W/66WPk(230VAC)DIP-8PKS606YN45W/86WPk(85-265VAC)68W/117WPk(230VAC)TO-220PKS607FN50W/93WPk(85-265VAC)75W/126WPk(230VAC)TO-262PKS607YN50W/93WPk(85-265VAC)75W/126WPk(230VAC)TO-220TNY253PN2W(85-265VAC)4W(100/115/230VAC)DIP-8TNY253GN2W(85-265VAC)4W(100/115/230VAC)SMD-8TNY253GN-TL2W(85-265VAC)4W(100/115/230VAC)SMD-8T&RTNY254PN4W(85-265VAC)5W(100/115/230VAC)DIP-8TNY254GN4W(85-265VAC)5W(100/115/230VAC)SMD-8TNY254GN-TL4W(85-265VAC)5W(100/115/230VAC)SMD-8T&RTNY255PN6.5W(85-265VAC)10W(100/115/230VAC)DIP-8TNY255GN6.5W(85-265VAC)10W(100/115/230VAC)SMD-8TNY255GN-TL6.5W(85-265VAC)10W(100/115/230VAC)SMD-8T&RTNY256PN10W(85-265VAC)15W(100/115/230VAC)DIP-8TNY256GN10W(85-265VAC)15W(100/115/230VAC)SMD-8TNY256GN-TL10W(85-265VAC)15W(100/115/230VAC)SMD-8T&RTNY256YN10W(85-265VAC)15W(100/115/230VAC)TO-220TNY263PN4.7W(85-265VAC)7.5W(230VAC)DIP-8TNY263PG4.7W(85-265VAC)7.5W(230VAC)DIP-8TNY263GN4.7W(85-265VAC)7.5W(230VAC)SMD-8TNY263GN-TL4.7W(85-265VAC)7.5W(230VAC)SMD-8,T&RTNY264PN6W(85-265VAC)9W(230VAC)DIP-8TNY264PG6W(85-265VAC)9W(230VAC)DIP-8TNY264GN6W(85-265VAC)9W(230VAC)SMD-8TNY264GN-TL6W(85-265VAC)9W(230VAC)SMD-8,T&RTNY265PN7.5W(85-265VAC)11W(230VAC)DIP-8TNY265PG7.5W(85-265VAC)11W(230VAC)DIP-8TNY265GN7.5W(85-265VAC)11W(230VAC)SMD-8TNY265GN-TL7.5W(85-265VAC)11W(230VAC)SMD-8,T&RTNY266PN9.5W(85-265VAC)15W(230VAC)DIP-8TNY266PG9.5W(85-265VAC)15W(230VAC)DIP-8TNY266GN9.5W(85-265VAC)15W(230VAC)SMD-8TNY266GN-TL9.5W(85-265VAC)15W(230VAC)SMD-8,T&RTNY267PN12W(85-265VAC)19W(230VAC)DIP-8TNY267GN12W(85-265VAC)19W(230VAC)SMD-8TNY267GN-TL12W(85-265VAC)19W(230VAC)SMD-8,T&RTNY268PN15W(85-265VAC)23W(230VAC)DIP-8TNY268GN15W(85-265VAC)23W(230VAC)SMD-8TNY268GN-TL15W(85-265VAC)23W(230VAC)SMD-8,T&RTNY274PN8.5W(85-265VAC)11W(230VAC)DIP-8TNY274PG8.5W(85-265VAC)11W(230VAC)DIP-8TNY274GN8.5W(85-265VAC)11W(230VAC)SMD-8TNY274GN-TL8.5W(85-265VAC)11W(230VAC)SMD-8,T&RTNY275PN11.5W(85-265VAC)15W(230VAC)DIP-8TNY275PG11.5W(85-265VAC)15W(230VAC)DIP-8TNY275GN11.5W(85-265VAC)15W(230VAC)SMD-8TNY275GN-TL11.5W(85-265VAC)15W(230VAC)SMD-8,T&RTNY276PN15W(85-265VAC)19W(230VAC)DIP-8TNY276GN15W(85-265VAC)19W(230VAC)SMD-8TNY276GN-TL15W(85-265VAC)19W(230VAC)SMD-8,T&RTNY277PN18W(85-265VAC)23.5W(230VAC)DIP-8TNY277PG18W(85-265VAC)23.5W(230VAC)DIP-8TNY277GN18W(85-265VAC)23.5W(230VAC)SMD-8TNY277GN-TL18W(85-265VAC)23.5W(230VAC)SMD-8,T&RTNY278PN21.5W(85-265VAC)28W(230VAC)DIP-8TNY278GN21.5W(85-265VAC)28W(230VAC)SMD-8TNY278GN-TL21.5W(85-265VAC)28W(230VAC)SMD-8,T&RTNY279PN25W(85-265VAC)32W(230VAC)DIP-8TNY279GN25W(85-265VAC)32W(230VAC)SMD-8TNY279GN-TL25W(85-265VAC)32W(230VAC)SMD-8,T&RTNY280PN28.5W(85-265VAC)36.5W(230VAC)DIP-8TNY280GN28.5W(85-265VAC)36.5W(230VAC)SMD-8TNY280GN-TL28.5W(85-265VAC)36.5W(230VAC)SMD-8,T&RPartNumberDescriptionPackageTNY375PN12W(85-265VAC)16.5W(230VAC)DIP-8TNY375GN12W(85-265VAC)16.5W(230VAC)SMD-8TNY375GN-TL12W(85-265VAC)16.5W(230VAC)SMD-8,T&RTNY376PN17W(85-265VAC)22W(230VAC)DIP-8TNY376GN17W(85-265VAC)22W(230VAC)SMD-8TNY376GN-TL17W(85-265VAC)22W(230VAC)SMD-8,T&RTNY377PN23W(85-265VAC)28W(230VAC)DIP-8TNY377GN23W(85-265VAC)28W(230VAC)SMD-8TNY377GN-TL23W(85-265VAC)28W(230VAC)SMD-8,T&RTNY378PN27W(85-265VAC)34W(230VAC)DIP-8TNY378GN27W(85-265VAC)34W(230VAC)SMD-8TNY378GN-TL27W(85-265VAC)34W(230VAC)SMD-8,T&RTNY379PN31W(85-265VAC)39W(230VAC)DIP-8TNY379GN31W(85-265VAC)39W(230VAC)SMD-8TNY379GN-TL31W(85-265VAC)39W(230VAC)SMD-8,T&RTNY380PN35W(85-265VAC)45W(230VAC)DIP-8TNY380GN35W(85-265VAC)45W(230VAC)SMD-8TNY380GN-TL35W(85-265VAC)45W(230VAC)SMD-8,T&RTOP100YN0-20W(100/110VAC)TO-220TOP101YN15-35W(100/110VAC)TO-220TOP102YN20-45W(100/110VAC)TO-220TOP103YN25-55W(100/110VAC)TO-220TOP104YN30-60W(100/110VAC)TO-220TOP200YN5-12W(85-265VAC)10-25W(100/115/230VAC)TO-220TOP201YN0-22W(85-265VAC)20-45W(100/115/230VAC)TO-220TOP202YN15-30W(85-265VAC)30-60W(100/115/230VAC)TO-220TOP203YN20-35W(85-265VAC)40-70W(100-115/230VAC)TO-220TOP204YN30-50W(85-265VAC)60-100W(100/115/230VAC)TO-220TOP209PN2W(85-265VAC)4W(100/115/230VAC)DIP-8TOP209GN2W(85-265VAC)4W(100/115/230VAC)SMD-8TOP209GN-TL2W(85-265VAC)4W(100/115/230VAC)SMD-8T&RTOP210PN5W(85-265VAC)8W(100/115/230VAC)DIP-8TOP210GN5W(85-265VAC)8W(100/115/230VAC)SMD-8TOP210GN-TL5W(85-265VAC)8W(100/115/230VAC)SMD-8T&RTOP214YN25-42W(85-265VAC)50-85W(100/115/230VAC)TO-220TOP221PN6W(85-265VAC)9W(100/115/230VAC)DIP-8TOP221GN6W(85-265VAC)9W(100/115/230VAC)SMD-8TOP221GN-TL6W(85-265VAC)9W(100/115/230VAC)SMD-8T&RTOP221YN7W(85-265VAC)12W(100/115/230VAC)TO-220TOP222PN10W(85-265VAC)15W(100/115/230VAC)DIP-8TOP222GN10W(85-265VAC)15W(100/115/230VAC)SMD-8TOP222GN-TL10W(85-265VAC)15W(100/115/230VAC)SMD-8T&RTOP222YN15W(85-265VAC)25W(100/115/230VAC)TO-220TOP223PN15W(85-265VAC)25W(100/115/230VAC)DIP-8TOP223GN15W(85-265VAC)25W(100/115/230VAC)SMD-8TOP223GN-TL15W(85-265VAC)25W(100/115/230VAC)SMD-8T&RTOP223YN30W(85-265VAC)50W(100/115/230VAC)TO-220TOP224PN20W(85-265VAC)30W(100/115/230VAC)DIP-8TOP224GN20W(85-265VAC)30W(100/115/230VAC)SMD-8TOP224GN-TL20W(85-265VAC)30W(100/115/230VAC)SMD-8T&RTOP224YN45W(85-265VAC)75W(100/115/230VAC)TO-220TOP225YN60W(85-265VAC)100W(100/115/230VAC)TO-220TOP226YN75W(85-265VAC)125W(100/115/230VAC)TO-220TOP227YN90W(85-265VAC)150W(100/115/230VAC)TO-220TOP232PN10W(85-265VAC)15W(230VAC)DIP-8TOP232GN10W(85-265VAC)15W(230VAC)SMD-8 TOP232GN-TL10W(85-265VAC)15W(230VAC)SMD-8T&RTOP232YN15W(85-265VAC)25W(230VAC)TO-220TOP233PN15W(85-265VAC)25W(230VAC)DIP-8TOP233GN15W(85-265VAC)25W(230VAC)SMD-8TOP233GN-TL15W(85-265VAC)25W(230VAC)SMD-8T&RTOP233YN30W(85-265VAC)50W(230VAC)TO-220TOP234PN20W(85-265VAC)30W(230VAC)DIP-8TOP234GN20W(85-265VAC)30W(230VAC)SMD-8TOP234GN-TL20W(85-265VAC)30W(230VAC)SMD-8T&RTOP234YN45W(85-265VAC)75W(230VAC)TO-220TOP242FN10W(85-265VAC)15W(230VAC)TO-262TOP242PN10W(85-265VAC)15W(230VAC)DIP-8TOP242GN10W(85-265VAC)15W(230VAC)SMD-8 TOP242GN-TL10W(85-265VAC)15W(230VAC)SMD-8T&RTOP242R-TL14W(85-265VAC)22W(230VAC)TO-263T&RTOP242YN14W(85-265VAC)22W(230VAC)TO-220TOP243FN30W(85-265VAC)45W(230VAC)TO-262TOP243PN15W(85-265VAC)25W(230VAC)DIP-8TOP243GN15W(85-265VAC)25W(230VAC)SMD-8TOP243GN-TL15W(85-265VAC)25W(230VAC)SMD-8T&RTOP243R-TL23W(85-265VAC)45W(230VAC)TO-263T&RTOP243YN30W(85-265VAC)45W(230VAC)TO-220TOP244FN45W(85-265VAC)65W(230VAC)TO-262TOP244PN20W(85-265VAC)28W(230VAC)DIP-8TOP244GN20W(85-265VAC)28W(230VAC)SMD-8TOP244GN-TL20W(85-265VAC)28W(230VAC)SMD-8T&RTOP244R-TL28W(85-265VAC)50W(230VAC)TO-263T&RTOP244YN45W(85-265VAC)65W(230VAC)TO-220TOP245FN60W(85-265VAC)85W(230VAC)TO-262TOP245PN22W(85-265VAC)30W(230VAC)DIP-8TOP245GN22W(85-265VAC)30W(230VAC)SMD-8TOP245GN-TL22W(85-265VAC)30W(230VAC)SMD-8T&RTOP245R-TL33W(85-265VAC)57W(230VAC)TO-263T&RTOP245YN60W(85-265VAC)85W(230VAC)TO-220TOP246FN90W(85-265VAC)125W(230VAC)TO-262TOP246PN26W(85-265VAC)34W(230VAC)DIP-8TOP246GN26W(85-265VAC)34W(230VAC)SMD-8TOP246GN-TL26W(85-265VAC)34W(230VAC)SMD-8T&RTOP246R-TL38W(85-265VAC)64W(230VAC)TO-263T&RTOP246YN90W(85-265VAC)125W(230VAC)TO-220TOP247FN125W(85-265VAC)165W(230VAC)TO-262TOP247R-TL43W(85-265VAC)70W(230VAC)TO-263T&RTOP247YN125W(85-265VAC)165W(230VAC)TO-220TOP248FN155W(85-265VAC)205W(230VAC)TO-262TOP248R-TL48W(85-265VAC)75W(230VAC)TO-263T&RTOP248YN155W(85-265VAC)205W(230VAC)TO-220TOP249FN180W(85-265VAC)250W(230VAC)TO-262TOP249R-TL53W(85-265VAC)79W(230VAC)TO-263T&RTOP249YN180W(85-265VAC)250W(230VAC)TO-220TOP250FN210W(85-265VAC)290W(230VAC)TO-262TOP250R-TL55W(85-265VAC)82W(230VAC)TO-263T&RTOP250YN210W(85-265VAC)290W(230VAC)TO-220TOP252PN10W/13WPK(85-264VAC)15W/21WPK(230VAC)DIP-8TOP252GN10W/13WPK(85-264VAC)15W/21WPK(230VAC)SMD-8TOP252GN-TL10W/13WPK(85-264VAC)15W/21WPK(230VAC)SMD-8,T&RTOP252MN10W/13WPK(85-264VAC)15W/21WPK(230VAC)SDIP-10TOP252EN13W(85-264VAC)21W(230VAC)eSIP-7CTOP253PN15W/25WPK(85-264VAC)25W/38WPK(230VAC)DIP-8TOP253GN15W/25WPK(85-264VAC)25W/38WPK(230VAC)SMD-8TOP253GN-TL15W/25WPK(85-264VAC)25W/38WPK(230VAC)SMD-8,T&RTOP253MN15W/29WPK(85-264VAC)25W/43WPK(230VAC)SDIP-10TOP253EN29W(85-264VAC)43W(230VAC)eSIP-7CTOP254PN20W/30WPK(85-264VAC)28W/47WPK(230VAC)DIP-8TOP254GN20W/30WPK(85-264VAC)28W/47WPK(230VAC)SMD-8TOP254GN-TL20W/30WPK(85-264VAC)28W/47WPK(230VAC)SMD-8,T&RTOP254MN20W/40WPK(85-264VAC)28W/62WPK(230VAC)SDIP-10TOP254YN43W(85-264VAC)62W(230VAC)TO-220TOP254EN43W(85-264VAC)62W(230VAC)eSIP-7CTOP255PN22W/35WPK(85-264VAC)30W/54WPK(230VAC)DIP-8TOP255GN22W/35WPK(85-264VAC)30W/54WPK(230VAC)SMD-8TOP255GN-TL22W/35WPK(85-264VAC)30W/54WPK(230VAC)SMD-8,T&RTOP255MN22W/52WPK(85-264VAC)30W/81WPK(230VAC)SDIP-10TOP255YN57W(85-264VAC)81W(230VAC)TO-220TOP255EN57W(85-264VAC)81W(230VAC)eSIP-7CTOP255LN57W(85-264VAC)81W(230VAC)eSIP-7FTOP256PN26W/40WPK(85-264VAC)34W/63WPK(230VAC)DIP-8TOP256GN26W/40WPK(85-264VAC)34W/63WPK(230VAC)SMD-8TOP256GN-TL26W/40WPK(85-264VAC)34W/63WPK(230VAC)SMD-8,T&RTOP256MN26W/64WPK(85-264VAC)34W/98WPK(230VAC)SDIP-10TOP256YN86W(85-264VAC)119W(230VAC)TO-220TOP256EN86W(85-264VAC)119W(230VAC)eSIP-7CTOP256EG86W(85-264VAC)119W(230VAC)eSIP-7CTOP256LN64W(85-264VAC)88W(230VAC)eSIP-7FTOP257PN30W/45WPK(85-264VAC)41W/70WPK(230VAC)DIP-8TOP257GN30W/45WPK(85-264VAC)41W/70WPK(230VAC)SMD-8TOP257GN-TL30W/45WPK(85-264VAC)41W/70WPK(230VAC)SMD-8,T&RTOP257MN30W/78WPK(85-264VAC)41W/119WPK(230VAC)SDIP-10TOP257YN119W(85-264VAC)157W(230VAC)TO-220TOP257EN119W(85-264VAC)157W(230VAC)eSIP-7CTOP257LN78W(85-264VAC)105W(230VAC)eSIP-7FTOP258PN35W/50WPK(85-264VAC)48W/77WPK(230VAC)DIP-8TOP258GN35W/50WPK(85-264VAC)48W/77WPK(230VAC)SMD-8TOP258GN-TL35W/50WPK(85-264VAC)48W/77WPK(230VAC)SMD-8,T&RTOP258MN35W/92WPK(85-264VAC)48W/140WPK(230VAC)SDIP-10TOP258YN148W(85-264VAC)195W(230VAC)TO-220TOP258EN148W(85-264VAC)195W(230VAC)eSIP-7CTOP258LN92W(85-264VAC)122W(230VAC)eSIP-7FTOP259YN171W(85-264VAC)238W(230VAC)TO-220TOP259EN171W(85-264VAC)238W(230VAC)eSIP-7CTOP259LN120W(85-264VAC)162W(230VAC)eSIP-7FTOP260YN200W(85-264VAC)275W(230VAC)TO-220TOP260EN200W(85-264VAC)275W(230VAC)eSIP-7CTOP260LN140W(85-264VAC)190W(230VAC)eSIP-7FTOP261YN254W(85-264VAC)333W(230VAC)TO-220TOP261EN254W(85-264VAC)333W(230VAC)eSIP-7CTOP261LN177W(85-264VAC)244W(230VAC)eSIP-7FTOP262EN254W(85-264VAC)333W(230VAC)eSIP-7CTOP262LN177W(85-264VAC)244W(230VAC)eSIP-7FTOP412GN9W(48VDC)SMD-8TOP412GN-TL9W(48VDC)SMD-8T&RTOP414GN12W(48VDC)SMD-8TOP414GN-TL12W(48VDC)SMD-8T&R
我用TOP248Y设计一个电源,输入是ac195--265v, 输出是dc 1-28v.3A; 2-12V1.5A; 3-5V2A,线路板尺寸为107X87,固定线路板的孔位为93X65的3MM孔,望各位高人指点,QQ997656723
