![](http://u.dianyuan.com/bbs/u/72/2342061230469996.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/72/2342061230469996.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">这是DVD出仓电机驱动的一路,电机不转动,管子迅速发热,测得各点电压值在红方框内.括号数值是另一路正常值.断开A点,芯片输出电压和另一路断开后的电压相同3.2v.测试各管没有损坏,怀疑性能不良更换管子无济于事,各贴片电阻阻值误差在正常范围.请高手指点!!
