AMC7150 PT4115 AMC7135
提供LED驱动IC和方案,AMC7150 A718 PT4115 AX2002 ACT111 PT4107 A704 AMC7140 AMC7135 等IC及样品!13620209261 QQ573887789
全部回复(2)
@banliujia
LED方案及样品提供!
LED Driver IC Series for High power LED lighting <<< Back
Low DC Voltage Buck DC/DC Converter for LED Constant Current(低压LED降压恒流驱动)
Current(Max.) Part No. Vin Dimming Frequency Vfb
Standby Eff. Package App.
电流(最大值) 型号 输入电压 调光方式 频率 反馈 待机 效率 封装 应用
700mA AMC7150 4~40V PWM,DC 200kHz 1V 200uA 85% TO-252-5 MR-16,Automotive etc.
1A A718 6~42V PWM,DC 225kHz 0.2V 95uA 95% SOP/EP-8(LM3404) MR-16,Automotive etc.
1.2A PT4115 8~30V PWM.DC 1MHz 0.1V 60uA 97% SOT89-5,MSOP8 MR-16,Automotive,etc.
1.5A ACT111 4.5~30V PWM.DC 1.4MHz 0.1V 30uA 95% SOT23-6 MR-16,Automotive,etc.
2A(+MOS) SM5241 5.5~36V PWM,DC 2MHz 0.2V 10uA 92% SOT23-6 MR-16,back-up lighting
2A AX2002 4.5~20V PWM,DC 330kHz 0.25V 2uA 92% SOP-8 LED lighting
3A AX2003 4.5~23V PWM,DC 500kHz 0.25V 2uA 92% SOP-8 LED lighting
High AC Voltage(AC 85~265V) Buck DC/DC Converter for LED Constant Current(高压市电LED降压恒流驱动)
24W(1A) PT4107 110V/220V PWM,DC 200kHz 市电非隔离 88% SOP-8,DIP-8 GU10,EE27,LED日光灯
24W(1A) A704 110V/220V PWM,DC 65kHz 市电非隔离 88% SOT23-5 GU10,EE27,LED Daylighting
1-3W(0.5A)
OB2211/OB2535/ACT353 50kHz 市电隔离 75% SOP-8 无光耦,431,GU10,EE27
1-300W ACT30/OB2353/OB2263/OB2269/SD484X+FP103... 80% - 市电LED照明,GU10,EE27
Linear LED Constant Current(线性LED降压恒流驱动)
20mA*3 AMC7110 2.7~5.5V PWM -AMC7110/AMC7111/AMC7113 SOT23-6 手机、PDA、PMP背光
15(20)mA*3(4) PT4401/2 2.7~5.5V PWM -PT4401/PT4402 SOT23-6 手机、PDA、PMP背光
40mA*6 A701 4~6V PWM -A701/A702/A703/A704/A705/A706 MSOP-10 手机、PDA、PMP背光
240/260/280/320/330/350mA SM7135 -SM7135E24/E26/E28/E30/E33/E35 SOT-89 矿灯、手电筒
320~340mA AMC7135 2.7~5.5V - -AMC7135PKFAT SOT-89 矿灯、手电筒
0~400mA ADJ SM7136 2.7~5.5V - -SM7136(Adj Current) SOT-89-5 矿灯、手电筒
0~500mA ADJ LED1113 >3.3V - Vout:2.5~28V SOT-89 大功率LED照明
0~700mA ADJ AMC7140 5-50V PWM -AMC7140DLFT(Adj Current) TO-252-5 台灯、LED照明灯
LED Backlight(LED背光) Boost DC/DC Converter for LED Constant Current(LED升压恒流驱动)
Isw(Max.) Part No. Vin Dimming Frequency Vfb Standby Mis. Package Replace
5~40mA A706 4.5~50V PWM.DC 1.5Mhz --- 0.1uA 92% QFN4*4-20 6通道升压LED背光
320mA SP1937 2.5~5.5V PWM.DC 1.2MHz 0.095V 0.1uA 88% SOT25,SOT353 MP4,PMP,PDA,手机背光
400mA PT4101 2.5~5.5V PWM.DC 1.2MHz 0.104V 0.1uA 88% SOT23-6 数码相框等背光OVP20V
400mA PT4103 2.5~5.5V PWM.DC 1.2MHz 0.104V 0.1uA 88% SOT23-6 数码相框等背光 OVP30V
1.5A PT4110 2.5~5.5V PWM.DC 1.2MHz 0.3V 0.1uA 88% SOT89-5,SOP-8 大尺寸LED背光
1.5A AMC3202+AMC7110/AMC7140/A702 Vin:2.7~30V/Vout:4~40V SOP-8 大尺寸LED背光
2A FP6201 3~18V PWM.DC 250KHz 0.5V 0.1uA 92% SOP-8 大尺寸LCD-LED背光驱动
2A PT4108 2~4.2V --- 500KHz 0.2V 0.01uA 90% SOT89-5,MSOP8 1*3W 3*1W,便携产品照明
0.3~5A(+MOS) FP5138 1.8~15V PWM.DC 500KHz 0.5V 0.1uA 92% SOP-8,TSSOP8 大尺寸LCD-LED背光驱动
Charge Pump LED driver (电荷泵LED驱动IC)
Current Part No. Vin Dimming Frequency - Standby Mis. Package Replace
20mA×4 PT4301 2.7~5.5V PWM 1MHz - <1uA <3% QFN4*4-16 RT9360,SC604
350mA(1W) PT4302 2.5~5.5V PWM 1MHz - <1uA <2% SOT23-6 AAT3120(DSC闪光灯)
350mA(1W) PT4305 2.5~5.5V PWM 1MHz - <1uA <2% DFN10,MSOP10 1W LED驱动,闪光灯
100mA EMD3001 2.5~4.5V PWM 2MHz - <1uA <2% SOT23,MSOP8 AT3110,CP2128
80mA*4 EMD2794 2.5~5.5V Analog 1.3MHz - <1uA <0.5% FBP-16 LM2794便携产品LED背光
Buck-Boost DC/DC Converter(升降压IC)
3A FP5138 1.8~15V PWM,DC 500kHz 0.5V 0.1uA 92% SOP-8,TSSOP-8 大尺寸LCD-LED背光驱动
按应用分类
LED手电筒、矿灯 SM7135,SM7136,AMC7135,A705,AMC7110,PT4105,PT4302,PT4305(锂电池,AA电池,镍氢电池应用)
MR-16杯灯、射灯 PT4105,PT4115,AMC7150,PT6101,AX2002(AC/DC 12V/24V 1W&3W&5W应用)
LED闪光灯 AMC7124,PT4302,PT4305,EMD2794,EMD2795(手机,数码相机LED闪光灯应用)
LED屏幕背光(小尺寸) SP1937,PT4101,PT4102,AX5110,AMC7110,PT4401,PT4402,EMD2794(手机,PDA,MP3,PMP背光)
LED屏幕背光(大尺寸) AMC3202,FP5138,PT6101,PT6102,AX2002,AX2003,PT4115,AX2101,AX2102,AX2103(液晶显示器)
市电LED照明(路灯/GU10) PT4107,ACT353,ACT30,OB2353,OB2211,OB2535,OB2263,CM6800,CM6807,CM6900...
我司生产以下成品线路板,可以根据客户要求开发订做:
锂电池LED矿灯板 ﹡输入电压:4.5~15V 充电电流:30mA~1.5A
﹡充电指示灯,充电时红色,充满时绿色
﹡LED恒流可调(20~400mA)或固定输出200/220/240/260/280/300/320/330/350mA
﹡可根据客户要求开发定制
MR-16杯灯、射灯 ﹡输入电压AC/DC 12V/24V通用
﹡可驱动单颗1W&3W或3颗1W串连MR-16杯灯/射灯
﹡高效率:最高效率92%
﹡DC&PWM 调光(可在板上预留)
﹡保护功能:热保护 短路保护 LED开路保护
市电LED照明(GU10/EE27) ﹡AC85~265V宽电压输入,输出电流50~700mA可调(1W&3W&5W)
﹡变压器安全隔离,一次侧控制,无光耦431,超小体积
﹡> 75%效率,可过CE,UL认证
﹡过电压、欠压保护 ﹡超低EMI﹡总体成本低
市电LED照明(路灯) ﹡Vin: AC85~265V ,PF>95%@230VAC Full Load
﹡Efficiency >91% @230VAC Full Load
﹡Iout: 4A~8A(hundreds of LEDs)
﹡Voltage Ripple Noise: 300mV
﹡Current Ripple <0.1A,Stand-by <0.5W
E-mail:sales@micro-bridge.com QQ咨询: 贸易通咨询: >>> 在线申请样品
版权所有 Copyright @ Micro Bridge Technology Co.,Ltd. All rights reserved.
1-3W(0.5A)
按应用分类
﹡充电指示灯,充电时红色,充满时绿色
﹡可根据客户要求开发定制
﹡高效率:最高效率92%
﹡DC&PWM 调光(可在板上预留)
﹡> 75%效率,可过CE,UL认证
