Qty Type Value Rating Tolerance Reference
1 Bridge Rectifier 1A 1000V BR1
1 X2 Capacitor 0.22uF 275VAC C1
2 Capacitor 0.1uF 400V C2,CDC
2 Capacitor 0.01uF 25V C3,CVCO
1 Capacitor 0.68uF 25V C4
1 Capacitor 0.47uF 25V C5
1 DC Bus Capacitor 10uF 450V CBUS
1 Capacitor 220pF 25V CCS
4 Capacitor 0.1uF 25V CMIN,CVCC1,CBOOT,CSD
1 Capacitor .27uF 25V CPH
1 Resonant Capacitor .01uF 1500V 5% CRES
1 Snubber Capacitor 1.5nF 630V CSNUB
1 Capacitor 4.7uF 25V CVCC2
1 Y Capacitor 2.2nF 250VAC CY
1 Diode 1N4148 D1
1 Bootstrap Diode 600V 1A DBOOT
1 Charge Pump Zener 17V 500mW DCP1
1 Charge Pump Diode 1N4148 DCP2
1 PFC Diode 600V 1A DPFC
1 Fuse 2A 250VAC F1
1 Dimming Control IC IR21592 IC BALLAST
1 PFC IC L6561 IC PFC
1 Common-mode Line Filter 2x10mH 0.2A L1
1 Differential-mode Line Filter 470uH 0.2A L2
1 PFC Inductor 1.2mH 0.8 Apk 5% LPFC:A
1 Secondary Winding 10 Turns LPFC:B
1 Resonant Inductor 2.3mH 2.2 Apk 5% LRES
2 Half-Bridge MOSFET IRF820 MHS,MLS
1 PFC MOSFET IRF830 MPFC
4 Resistor 820K Ohm 200V R1,R2,R3,R4
3 Resistor 100K Ohm R5,RDC,RSD
1 Resistor 22K Ohm R6
3 Resistor 20 Ohm R7,RHO,RLO
1 Resistor 10.3K Ohm R9
1 Current Sense Resistor .82 Ohm 1% RCS
1 Resistor 5.1K Ohm RDIM
1 Resistor 51K Ohm 1% RFMIN
1 Resistor 1K Ohm RLIM1
2 Resistor 10 Ohm RLIM2,RLIM3
1 Resistor 16K Ohm 1% RMAX
2 Resistor 36K Ohm 1% RMIN,RIPH
1 Resistor 9.1K Ohm RMULT
1 Resistor 1M Ohm RPU
1 Resistor .75 Ohm 1% RS
1 Resistor 270K Ohm 400V RSUPPLY
1 Varistor 470V RV1
1 Resistor 1M Ohm 400V RVAC
1 Resistor 56K Ohm RVDC
请问:这些元器件大概多少钱?
全部回复(8)
您好,我公司专业生产全系列直插电阻,可以为您提供电阻方面的价格,
质优价廉.
欢迎来电恰谈.
0755-26701747 13714528106
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/30/1119172497.jpg');}" onmousewheel="return imgzoom(this);">
质优价廉.
欢迎来电恰谈.
