Current draw就是指电流吗
Power Requirements
– AC Power Version Single Auto-sensing AC
Power supply – 90-132 VAC or 170-264 VAC, Frequency range: 47-63 Hz
Current draw, maximum 3.8A @90 VAC
– DC Power Version Two Redundant DC
power entry points -39 VDC to –58 VDC
Current draw, maximum 7.6A @-40 VDC
看到一个产品的介绍上写的,不太明白“Single Auto-sensing ”是什么功能,我的理解是电源自动检测输入电压范围,然后自动切换.
另外“Current draw”是电流吗?
全部回复(0)
