1119940697.pdf
PCB板:
![](http://u.dianyuan.com/bbs/u/30/1119953388.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
![](http://u.dianyuan.com/bbs/u/30/1119953421.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
1.说明Description
GCQC368锂电池保护方案,包括GC1318和两片X3100/01,可以管理6/7/8/9/10 节锂电池,智能实现锂电池的测量、保护、平衡等管理功能.
通过测量电池的电压、电流和温度,准确计算电池电量,控制平衡电路的平衡动作,执行电压、电流和温度的保护.
各种工作和保护的参数可以进行灵活设定,并在内部保存于GC1318的EEPROM中.
系统自动进行电量智能调整、记录充放电循环次数(cycle)和电量自学习等功能,实现系统参数数据的自动管理.
Solution GCQC368 is using 1 GC1318 and 2 X3100/01 to manage 6/7/8/9/10 Li-ion battery in series. The solution provides smart battery control function such as battery voltage/current/capacity measurement, battery over/under voltage, over current short circuit protection, battery cell-balancing management.
Every parameter of the protection such as voltage, current, temperature, can be stored in the EEPROM of GC1318 with the GC-SmartLoader and GC-PackManager.
The solution, can smartly calculate the battery capacity, record the charging/discharging cycle, and provide the FCC capacity re-learning function.
2. 特性Characteristic,
*使用GC1318集中管理
*GC1318 centrally control the smart battery management.
*支持多种锂电池电芯(cells)连接方式.
*Provide multi-cell pack connect such as 2Px6/7/8/9/10S.
*强大、完善的双重保护功能.对过压、欠压、过流具有硬件和软件的双重保护.
*Provide the second protection for over/under voltage, over current with software and hardware mechanism.
*系统电量通过电流测量获得,高精确度.
*System capacity is calculated by the accurate current detection.
*各种参数可以进行设定并保存在GC1318的EEPROM中.
*All the protection and battery parameters, are set and protected in the EEPROM of GC1318.
*系统对各种过程数据进行保存.
*All the real-time data is stored and protected in the EEPROM of GC1318.
*可以通过接口读出系统的一些参数和过程、状态参数.
*All the real-time parameters such as temperature, current, voltage, capacity and the battery status, can be read through the SMBus.
*高精度的电压、电流测量.
*High precision detection in voltage and current.
*控制软件可以实现在线更新.
*The GC1318 can provide the In-Application-Programming(IAP). This will provide a good inventory control for different kind of product.
*GC1318智能控制平衡电路,实现有效电池平衡.
*GC1318, can smartly control the cell-balancing circuit.
*GC1318具有多种休眠(sleep)模式,降低系统电力消耗.
*GC1318 has several kind of sleep mode to achieve system in the low power consumption.
*具有可靠的短路、反接保护功能.
*Short-circuit and reverse connection of the battery power terminal, will be protected.
