POWER PCB 5.0中如何写中文?
在POWER LOGIC4.0和POWER PCB5.0中有没有办法写中文吗?谢谢!
全部回复(21)
@dgcfq
能否告诉我去那里先载
哦,忘了,是BMP2ASC的转换软件,一定是黑白图象,才可以转换,具体使用如下:
Usage in DOS:
BMP2ASC inputfilename outputfilename integerscale levelnumber integerXoffset integerYoffset
e.g. BMP2ASC mtl.bmp mtl.asc 2 0 0 0
Note: The bitmap image for conversion needs to be monochrome and colours need to be inverted.
Usage in DOS:
@szxhb
哦,忘了,是BMP2ASC的转换软件,一定是黑白图象,才可以转换,具体使用如下: UsageinDOS:BMP2ASCinputfilenameoutputfilenameintegerscalelevelnumberintegerXoffsetintegerYoffsete.g.BMP2ASCmtl.bmpmtl.asc2000Note:Thebitmapimageforconversionneedstobemonochromeandcoloursneedtobeinverted.
谢谢,能否在WONDOWSXP下用,因我的系统是XP
@dgcfq
能否告诉小弟怎样放中文,谢谢.
参考以下步骤,希望你能搞定。
1(
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/31/1121733729.jpg');}" onmousewheel="return imgzoom(this);">)
2(
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/31/1121733745.jpg');}" onmousewheel="return imgzoom(this);">)
3(
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/31/1121733754.jpg');}" onmousewheel="return imgzoom(this);">)
4(
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/31/1121733762.jpg');}" onmousewheel="return imgzoom(this);">)
1(
2(
3(
4(
@siyixing
参考以下步骤,希望你能搞定。1([图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/31/1121733729.jpg');}"onmousewheel="returnimgzoom(this);">)2([图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/31/1121733745.jpg');}"onmousewheel="returnimgzoom(this);">)3([图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/31/1121733754.jpg');}"onmousewheel="returnimgzoom(this);">)4([图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/31/1121733762.jpg');}"onmousewheel="returnimgzoom(this);">)
此方法是可以放上去,但是不能制板,不能放于哪一层,在打印预览时也看不见。
@renjiu
没大家讲的如此麻烦,我知道有好事者把常用汉字做成了库文件,可以直接调用,当然没有的汉字你也可以在POWERPCB中自己画出来,好像这是唯一的方法。
没大家讲的麻烦,有人将常用汉字做成了库,可直接调用,当然没有的汉字那就要你自己去POWERPCB画了.1121926196.zip
