如果 您是大虾 麻烦您了 帮小妹翻译一下
SMR mainternance
since the SMRs are fully controlled by the Minicsu there is no need for any adjustments to parameter Howere some regular checks can be an early warning of problems warning to happen
8.1 current Sharing
under normai conditions the currents contributed by every rectifer should be within+2amps(-2amps)of each other It is possible however for internal loop parameters to change to such an extent that a unit dose not share to the extent that it should .
if the lack of sharing is extreme then either a current limit or no load alarm will be active and the operator should then refer to the next section
if ,however , the current sharing is not so extreme as to generate an alarm ,a regular check of the current sharing among the rectifiers can lead to early detection of any units which may be developing a fault.
English for communication power supply
全部回复(6)
@hereliu
一定要大虾吗?我是是小吓,斗胆试一下: SMR的维护 因为SMRs完全由Miniscu控制,所以没必要调整参数.但是,常规检查可以及早发现一些问题.8.1电流分享正常条件下,每个整流器贡献的电流应在+2A(-2A)以内.但有可能内部环路参数改变而使得一个整流器不能分享到它应该分享的电流.如果这种分享不足的程度很严重,那么电流极限报警或者空载报警就回被激活,(遇到这种情况)请参考下一节(说明).然儿,如果电流分享不足不是严重到报警的程度,那么对整流器电流分享的常规检查能够及早发现那些可能发展出故障的整流器.
大虾:先行谢过了!!!
